How to build a Chain Clock
 by stevemoseley
Featured
Step 9: Motors to run the Three Chains
The gear motors for the project were from from ServoCity (http://www.servocity.com/html/4_rpm_gear_motor.html).  They operate on 3 volts to 12 volts dc.  I ran them at 12 volts dc for the speed of rotation I was looking for, but these gave me the option to run at a slower speed if necessary.
The motors are also somewhat quiet when operating.  I thought this was an important aspect of the clock as I wanted to keep things as quiet as possible.
The sprockets for these motors have 1/2 inch diameter bores but the motors have 6mm (metric) shaft diameters.  In order to make up the difference I used 3/4 inch long sections of 1/2 inch diameter nylon rod and then drilled a 6mm diameter hole for the motor shaft.  Then I set a #4 by 1 inch long machine screw through a hole that I drilled though the motor shaft.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
