Building a cold frame is easy!
The following is a brief explanation on how to build a cold frame and on how to prepare the soil for your winter garden.
Remove these ads by
Signing UpStep 1Initial considerations
you can also use trex, it is a wood alternative used in decks. i think it's plastic or a mixture of plastic and other material, either way it looks like painted wood.
I've read that too great a pitch (slope) causes hot spots that are not conducive to plant growth, while too low a pitch eliminates too much sunlight. In addition, I do wonder why not make a double sided cold frame...kind of a mini green house.
Any insight would be much appreciated as I have some windows that I'd love to incorporate into a cold frame, but am unsure about the pitch issue.
thanks,
james
You can use redbrick and a little sand mix to line the perimeter of the box setting the box on top of your small wall and use caulk to seal between them both this way you could use just about any type of wood preferably oak is what i would use ..
Just A Thought
If you line the inside with polystyrene sheeting it will stay warmer and keep frost out and use white will make it better for light.Reflects it
The biggest problem i have i can never make enough :)
http://www.gardenersworld.com/how-to/projects/cold-frame-insulate/
