How to Build a Feline Pine Self-cleaning Litter Box
77,403
52
37
Posted
Introduction: How to Build a Feline Pine Self-cleaning Litter Box
Make Feline Pine cat litter last even longer with a litter box specifically designed for it.
Cut down on sawdust, tracking, and save pellets.
Step 1: You Will Need
Supplies:
Two litter box pans
 -  They need to be the same size on the perimeter, but one needs to be shallower than the other.  I used my old litter box as the bottom and bought another at the store.  Bring it in with you to test.
Drill and 11/64 sized bit
-  I took one pellet to the hardware store and measured this size to be the perfect size.
Ruler and pen
-  For measuring and marking the holes on the top pan.
Step 2: Measure the Holes
Flip the top pan over and space 6, 3 1/2 inch squares evenly on the surface.  They don't have to be perfect, just use this as a guide when drilling.
In each square, draw a grid spaced 1/4 inch apart.
Where the lines intersect, you will drill a hole.
TIPS:
If you are using an existing litter pan, disinfect before measuring.
Step 3: Drill Holes
This part can be daunting.  Try to guess which square was my last.
Again, your holes don't have to be perfect, but having many holes will allow all the sawdust to sift out effectively.
TIPS:
This will create a lot of debris, have a vacuum close by.
Step 4: How to Use
Place the top pan onto the bottom pan and fill with a bag of Feline Pine or store brand pine litter.
In the bottom pan, place a handful of pellets.  This will absorb and urine that might fall through the top pan.
When cleaning, first scoop out any feces.
To help sift out the sawdust, stir the pellets thoroughly, the sawdust will naturally fall to the bottom while the good pellets will rise to the top.
Bags of litter will last much longer because there is virtually no wasted pellets.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    32 Comments
    You think feline Pine would have had a litter box specifically made for that
    They do, actually, but the boxes are a bit on the small side for Maine Coon sized kitties.
    you can get horse bedding pine pellets for around $8 for 40 lb which lasts a long time, even longer if you don't have to throw out the good pellets
    . I divided up the bag into 3 (used old bags) so it isn't as heavy to lift. I have a big cat 16 lb and got 2 of the large phresh cat litter boxes, then drilled holes and glued pieces of pipe isulation at the 4 corners (on the bottom) and 1 in the center. Hoping this works well
    I have a big cat and found Target has large cat litter boxes for $9 each and bought 2. Since they are the same size I will try cutting about 8 x 1" slices of black pipe insulation, to glue (using contractors glue) on the outer corners on the bottom of the top litter box and also to support it in the middle. I hope it works.
    Hi there, thanks for the demonstration. The guys in Sweden have a product that does this. I am not sure it is available in the US.
    I knew i would have to make it , you just confirmed it LOL
    If anyone finds two boxes that work, please let me know!!
    You're right, it works in reverse compared to other sifting litter pans. Instead of sifting the good litter through the holes, this pan sifts the bad "sawdust" litter through the holes, leaving the good litter and feces that can be scooped out. To answer your other questions, the pine pellets are compressed sawdust and will start to come apart when wet. I like this litter better than corn because it is less dusty and cats don't track it as much. Thanks for the comment!
    Great idea, however doesn't solve the problem of removing feces because the pine pellets won't go through a regular sized scoop.
    I use the stove pellets, and the "scooper" is a pair of plastic salad servers that look like scissors, like these. They work pretty well and let loose pellets fall off/out.
