3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a "Flexi-Perch" Squirrel-proof birdfeeder for $10 or less
How to build a \"Flexi-Perch\" Squirrel-proof birdfeeder for $10 or less
Anyone who puts up a birdfeeder hoping to to enjoy the birds will soon attract unwanted guests - squirrels. These cute but rapacious little monsters chase off the birds, eat all the seeds, and can chew birdfeeders to bits.
I've been trying to fight off squirrels since 1989, when I put my birdfeeder webcam, SeattleBirdCam.com, online. I tried ultrasound generators, slingshots, and spiking the birdseed with hot peppers - all to no avail. After studying a number of expensive "squirrel-proof" birdfeeder designs on the market, I came up with my own inexpensive patent-pending birdfeeder design which can use cable ties (tie wraps) as flexible plastic perches. These "Flexi-Perches" (tm), combined with PVC pipe of the right length and width, make an inexpensive, easy-to-build, and effective squirrel-proof birdfeeder.
Step 1Materials
Materials
- 4" diameter plastic drain pipe at least 24" long. Quantity: 1 (a 10' pipe cost me $5.48)
- 1/2 " PVC couplers. Quantity 4 ($0.39 each)
- 4" PVC cap. Quantity 1
- PVC glue
- 3/8" sheet metal screws. Quantity 4
- 10 gauge (about 1/10") galvanized wire at least 33" long. Quantity: 1
- 6" cable ties (tie wraps). Quantity: at least 4
- wood block approx 6" high x 6" wide x 1" thick (i.e. a 6" long piece of 1x6 board)
Note on Materials:
The cable ties are critical. When used as perches, they won't support a squirrel's weight.
For maximum anti-squirrel effectiveness, the plastic drain pipe must be at least 24" long so that the squirrel can't reach feed holes while hanging from the top of the feeder.
The pipe must also be at least 4" in diameter so that the squirrel can't cling to the feeder.
The wood block will be cut down to fit into the bottom of the pipe to act as the base plate. It fits flush into the bottom of the pipe so that there are no protrusions for a squirrel to hang on to.
Other dimensions can be changed to suit whatever materials you may have on hand.
166 comments
1-40 of 166next »
May 3, 2010. 4:03 PMJoe Castrianni says:
Hi Bill,
                   Thanks for the reply.  I have included (2) photos of the feeder. One an interior view looking down from the top.  The couplings all were almost 2" in length I installed the first one at full length and when I went to insert the second, third and fourth they would not sit flush with the exterior wall of the PVC because they were butting into the first coupling.  The other three couplings are an 1-1/2" in length.  The wooden plug at the bottom of the feeder is approximately 15/16" from the bottom of the couplings.  I left the overall length of the 4" PVC a bit long so there is a few inches of false overhang at the bottom.  I am look forward to your reply.  Thanks for you help.
May 6, 2010. 9:49 AMJoe Castrianni says:
Hi Bill,
                     Thanks for the reply.  I was indeed using small seed!  I purchased a bag of the black oil sunflower seeds in the shell & filled the feeder the same day I received your message.  The seeds are retained in the feeder.  It has been filled for three days nopw, but I have not as yet seen any birds land on the feeder. Any ideas as to how to attract the birds to the feeder?
Thanks again for all your help.
Regards,
Joe C.
May 15, 2010. 9:01 AMJoe Castrianni says:
Hi Bill,
                 As you have been such a big help, I thought I'd let you know that the birds have finally discovered the feeder.  So have the squirrels but they have not been successful and the birds have been.  Thanks again for your patience & help!
Joe
Jul 22, 2010. 8:50 AMfrenzy says:
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/I-Made-It-Challenge-Is-Back-Win-A-Pro-Membership/
Jun 2, 2011. 12:00 PMlkreisz says:
I have been so frustrated by the squirrels in our yard that my husband and I built a somewhat modified version of this bird feeder. At first I hung it on one of my free-standing flower hangers. Day 1 - I laughed with glee as the squirrels slid down the sides of the feeder. But by day 3 the buggers had figured out that they could cling to the pole with the rear legs and fling themselves at the feeder until they grasped either the perches or the edge of a hole. They would then pull the feeder close enough to literally stick their face in and chow down. Obviously the pole was too close.
Now the feeder is hung from a wire suspended between two house corners. It's only a matter of time till these crafty creatures figure out how to get onto the roof and cross the wire but so far so good. As I type there are six squirrels prowling the ground for seed and staring up at the feeder. The young ones are the daredevils.
I had mainly chickadees and smaller birds on my original "squirrel-proof" feeder but since I painted this feeder I've been inundated with Stellar's Jay, Grosbeaks, woodpeckers and finches. I placed some extra perches between the holes for these bigger birds so that they aren't so close to the hole. They've figured out that if they grasp both pieces of the perch it's strong enough to support them.
My first seed fillup lasted 4 days but we do have a forest so the feeder is busy with birds virtually nonstop. I tested it for a couple days before painting it to look like tree bark and the birds didn't seem to like the white.
We made changes to make it simpler to build and refill. The top is just a loose cap that I pop off by hand. The perches are heavy guage weed-whacker line looped through two small holes below the feed holes. I filled in the base cap with a styrofoam block as a false bottom to keep the feed base close to the bottom of the feed holes and drilled a hole in the bottom to drain any potential moisture.
I was too cheap to buy the cleanout and knockout for this first one but I will on my second one. It's just simpler. By the way, the blue and yellow rods are to attract more birds because I read that these are the only colors that birds can see. They love to hang from them while waiting for a perch to land on. My next one will be painted in those colors.
Thanks for the great idea!
Apr 29, 2012. 12:08 PMBullmastif says:
That looks great! Good job.
Feb 18, 2012. 12:53 PMMarcos says:
How about more seed ports/perches? Most commercial tube feeders have several levels, staggered so that none are directly above the others. My mom has one, sequestered in her shed, because the #$%*! squirrels gnawed a hole in it. I guess I need to build another squirrel preventer. Come to think of it, I should probably put 'em on the market!
Jan 26, 2012. 1:24 PMTakhli says:
Your feeder worked like a champ for 3 months then I had a STUCK BIRD trying to get the "last seed", saved the bird and added a 3/4 inch spacer inside on the floor of the feeder so they can't or don't have to reach down to get the "last seed". I would recomend that you put this step in your instructions and perhaps we can save a bird somewhere.
The bird was stuck in the slot in the bottom of the 3/4" coupling.
Jan 26, 2012. 4:18 PMTakhli says:
Giving it further thought, the same thing can be done by turning the base block upside down (wire ties on bottom) leaving the inside floor about 1/4" below the couplings.
Jan 20, 2012. 10:42 AMdoflagie says:
This 'ible has an interesting take on the seed baffles...
http://www.instructables.com/id/Bird-Feeder/
Oct 4, 2011. 6:29 PMblueshark says:
Hello. I bought half-inch PVC couplers but only realized after I cut them up, that the 1/2 inch was the inside diameter. The outside diameter is 7/8". If you have to use pliers to force them into the one inch holes, what is the outside diameter of the couplers you used?
Also, what kind of bit did you use to drill the one inch feeder holes?
Thanks.
Oct 10, 2011. 6:10 AMblueshark says:
Hello Bill,
I bought new 3/4" PVC couplers and they worked just fine in the 1" hole... Yes, the instructions did call for 1/2" PVC couplers.
The bird feeder works well. I temporarily suspended it to a wire. It is somewhat too low at about 36" from the ground and squirrels can jump up to it. Most of them slip off but I've seen one that hung to it, probably from the feeder holes. The situation will be corrected soon.
Thank you.
Blueshark.
May 19, 2011. 10:59 AMDavidM45 says:
Finally ... the squirrels are driving me crazy! well thought out, thanks
May 30, 2011. 6:49 PMsuezq says:
I think I'll make one of these and take my roto zip tool, cut a groove in one side about a 1/2" wide x 6" long, roughly 4" up from the bottom. Then I'll cut a strip out of a clear 2 liter pop bottle and glue it to the inside of the pipe over the groove so I can have a window to keep track of the seed level. Maybe it's less trouble just to lift the lid and look...
Nice instructable and quite doable. Thanks!
Jan 20, 2011. 12:20 PMmyles136 says:
Hello again Bill,
In place of the 10 ga wire, I used 0.30 mig welding wire. This nearly invisible wire drive the squirrels nuts because they can not grip it!
I have another 6 sided plastic feeder. (the $5.00 Walmart variety) that is also now squirrel proof by adding a "dollar store" 14"diameter serving plate over the top like a baffle. The plate is fastened DOWN to the cheep feeder with short lengths of that 30ga wire that hold the plate rigid over the feeder. Again, it is suspended on mig wire. NO squirrel can climb down that super thin wire!!
Ian
Jan 1, 2011. 6:15 PMDr.Squirrel says:
You guys are sooooooooooo annoying!!!!!!
Oct 29, 2010. 10:19 AMforthebirds says:
Hello Bill and thanks for sharing the plans for your squirrel proof bird feeder. I built one with a few minor modifications and it turned out and works beautifully. I hope you got your patent and are profiting from your idea.
One question if I may. Previously I was feeding from a tray on a pole. My main visitors were cardinals, blue jays and of course squirrels.
After a month the cardinals are still ignoring the feeder. In a attempt to lure them back I added a tray to the same pole the feeder is on. The jays and cardinals are back at the tray but they(cardinals) still ignore the feeder. The jays show no interest in the feeder, but that is ok I built it for the cardinals.
I did not paint the feeder and left it white. Do you think this could possibly be keeping the birds away?. Thanks again! Don Lewis...Grapevine Texas
Oct 23, 2010. 11:05 PMdavele says:
Any success using 3" piping? Any reason why it needs to be painted?
I'm thinking of replacing the wood base with a PVC drain plug (after covering the holes), thoughts?
I'm interested what folks think about the following: To determine when to refill the feeder, I'm planning to drill a small hole near the top, but below the cap. Then by threading a knoted nylon cord through the hole and glueing it to a margarine lid, the lid will free float down as the seeds are eaten. When the lid drops and the string is no longer visable, its refill time!
Aug 19, 2010. 2:07 PMRon Calkins says:
I built 2 of them for my ex-wife...I also substituted using zip ties with nylon weed trimmer line. They work great...but now I need to build her a new "Shepherd's Hook". She has a double-hooked heavy duty hook, but it's not strong enough to support the 2 of them, especially if they're full of seeds...and there's a breeze. Anyway...thanks for the plans, and I will try to attach the photos. Thanks again, Ron :-)
Apr 30, 2010. 5:13 PMJoe Castrianni says:
Hi Bill,
                  I followed your instructables reasonably close, except I used 1" PVC Couplings instead of the 1/2' as siggested after reading some others comments.  I did cut out 1/3 of of the coupling, squeezed them in through the 1" holes that I had drilled with the cuts facing down. After the glue dried and the PVC was painted I couldn't wait to pour on the bird seed and much to my disappointment the seed flowed out of each of the PVC couplings until the PVC pipe was empty.  Can you tell me if I did anything wrong?
Thanks.
Joe C. @ Jcas721@yahoo.com
May 23, 2010. 7:10 PMmyles136 says:
Bill, I am in the prrocess of making one of your feeders now, but I definately want to feed jays and Cardinals so I will experiment with perches. On my existing feeders I have found that Graphite grease smells so bad to a squirrel that they wont get near it, yet the birds don't mind. I am generally not in favor of grease as I don't want to kill squirrels that could ingest it, but as I said, with the graphite, they don't cross it!
Jan 25, 2010. 9:33 PMOldMoose says:
At my local Walmart they have some thin, flexible, cheap cutting board/pastry sheet thingies that we use in the kitchen for food prep that you could drill a hole in and use it above the feeder to keep the squirrels off. They measure 12" X 15" and and are real slickery and flexible. It use them on different types of feeders very effectively. Hope this helps.
Jan 24, 2010. 11:50 PMmr_magicfingers says:
 Great idea, squirrels have been raiding our feeders this year and the 'squirrel-proof' ones we bought just aren't. I shall be making up one of these as soon as I can get the parts together.
Thanks for a great 'ible.
Jan 23, 2010. 12:05 PMSchooniedude says:
are the baffles nessescary?
Jan 25, 2010. 4:20 AMSchooniedude says:
ok thanks
Nov 19, 2009. 12:29 PMBigBoutte says:
very clever
1-40 of 166next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:billr
