3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a "Flexi-Perch" Squirrel-proof birdfeeder for $10 or less
Step 12Put the baffles in the feed holes
Use a pair of pliers to compress each baffle and force it into a feed hole, with the open side down. Leave about 1/3 of the baffle protruding out of the feed hole.
3 comments
Oct 4, 2011. 6:29 PMblueshark says:
Hello. I bought half-inch PVC couplers but only realized after I cut them up, that the 1/2 inch was the inside diameter. The outside diameter is 7/8". If you have to use pliers to force them into the one inch holes, what is the outside diameter of the couplers you used?
Also, what kind of bit did you use to drill the one inch feeder holes?
Thanks.
Oct 10, 2011. 6:10 AMblueshark says:
Hello Bill,
I bought new 3/4" PVC couplers and they worked just fine in the 1" hole... Yes, the instructions did call for 1/2" PVC couplers.
The bird feeder works well. I temporarily suspended it to a wire. It is somewhat too low at about 36" from the ground and squirrels can jump up to it. Most of them slip off but I've seen one that hung to it, probably from the feeder holes. The situation will be corrected soon.
Thank you.
Blueshark.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:billr
