Step 17Assemble the birdfeeder
Pass the wire through the base plate and bend the bottom 1" of the wire to prevent the base plate from sliding off. Make sure the base plate is oriented properly with the tie wraps on top.
Rotate the base plate until it is in proper alignment and thread the ends of the tie wraps into the pipe and out of the perch slots.
Slide the base plate into the bottom of the pipe while guiding the tie wraps out of the perch slots until the base plate hits the retaining screws. The bottom of the base plate should be flush with the bottom of the pipe.
- Billr
