3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a "Flexi-Perch" Squirrel-proof birdfeeder for $10 or less
Step 18Final step & instructions for use
Hold the feeder by the hanging loop and slide the cap onto the top of the pipe. Your feeder is complete!
Hang the feeder so that the bottom is at least 4' off the ground and the feeder at least 18" from the nearest vertical surface. Fill by sliding the top cap up and pour seed into the tube. It doesn't need to be filled up all the way.
8 comments
May 19, 2011. 10:59 AMDavidM45 says:
Finally ... the squirrels are driving me crazy! well thought out, thanks
May 30, 2011. 6:49 PMsuezq says:
I think I'll make one of these and take my roto zip tool, cut a groove in one side about a 1/2" wide x 6" long, roughly 4" up from the bottom. Then I'll cut a strip out of a clear 2 liter pop bottle and glue it to the inside of the pipe over the groove so I can have a window to keep track of the seed level. Maybe it's less trouble just to lift the lid and look...
Nice instructable and quite doable. Thanks!
Mar 21, 2009. 6:42 AMcharlessenf-gm says:
You inspired me BUT - watch out for the hole sizes! Apparently, I made mine just right and gave it to my neighbor to "test" as he had more avian visitors than I. When I went back to check, he had it down on the ground and there were blood stains 'round two of the orifices where the neighbor's son had tried to extricate the little birdies that got their heads stuck! Two died in the process! Just a (pardon the expression) Heads-up.
Mar 22, 2009. 6:18 PMcharlessenf-gm says:
Absolutely no need to be skeptical. Dennis (the neighbor) is a straight shooter as are his wife and son. I would suspect that the holes need to be of a certain size (like they do with bird houses) and sanded smooth to remove "edges" as well. I put ti up again with larger holes and had no difficulty. I suspect that, since I simply drilled the holes and did not try and round over the inside and outside edges, it was the sharp edges as much as the small hole size that caused the problems. Since their feathers grow from head to tail, getting in was no issue, but backing ut may have caught their feathers and prevented them from gracefully exiting with a craw full of seed. I don't know how to attach pictures to these responses, but, if you tell me how, I'll take a picture of the device I made and send it along.
Mar 24, 2009. 11:43 PMcharlessenf-gm says:
Try a jpg
Mar 30, 2009. 6:30 PMcharlessenf-gm says:
"Can you double-check that the baffles have been correctly cut?" Ooops, you are right. I removed the baffles to enlarge the holes the birds had gotten stuck in - forgot that part! I will enlarge the holes a bit more and try inserting some new baffles to hold in the seed better. I'll post a picture later.
Mar 30, 2009. 6:27 PMcharlessenf-gm says:
"what did you use for a top cap" I found these clean out scraps at a construction site. They had a female adapter and a screw-in plug at the end they cut off and tossed when connecting the house plumbing to the city pipes (I assume). The bottom fitting is a temporary cap that fits inside the Sched 40 4" PVC pipe. Its thin translucent plastic cheap, but forget how much! The female adapter and plug, on the other hand are NOT CHEAP - but work great.
Mar 30, 2009. 6:19 PMcharlessenf-gm says:
"the tubes inside the feed holes" Yes, forgot to mention that, to enlarge the holes, I drilled out the tubes entirely. The heads got stuck in the tubes - not since. But, maybe I could make some more tubes/baffles to keep the seed from dropping out (unless in a beak!). Thanks for reminding me about those parts.
Mar 24, 2009. 11:39 PMcharlessenf-gm says:
Never noticed the "add images" tab. Here 'tis
Jan 10, 2009. 12:28 PMwoodfinery says:
Very nice easy to understand simple instructions. This was exactly what I was looking for. Ya gotta love those Squirrels, but not hanging all over the bird feeders!!
Apr 15, 2008. 9:52 PMcharlessenf-gm says:
Great idea. Good detailed instructions and graphics. Love teh image of the finches - how do you do that photography? What do you use, distance, which camera, etc.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:billr
