3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a LED mood lamp/ Solder Safety light
Hi,
How many times have you burned down your house because you forgot to turn off that Soldering Iron or glue gun? Well I have never burned down my house (and hopefully you haven't either) but in this instructable I am going to teach you how to build a LED mood light that can also be used a Solder Safety light. Basically you can plug this light into a power strip that has your soldering iron and glue gun plugged into. That way you will see the light on your way out reminding you, that you forgot to turn off your soldering iron and or glue gun. This is a cheap, easy, safe, and quick instructable that most people will enjoy.
Step 1Materials and Tools
Materials and Tools
Materials
Electrical tape- Any kind will do as long as it is an insulator.
LED- Any color or size. I used a 10mm RGB (Red, green, blue)
Wall Wart/ Power supply- This is really important. Make sure you have one that supplies the correct voltage and amperage. I used an old one I found in my basement.
Specs
AC-DC
Input: AC 120v~60 Hz 4W
OutPut:DC3v--- 200ma 0.6 VA
Tools
Wire Cutters and Strippers
I used my MAKE: Warranty Voider - Leatherman "Squirt" E4 (electronics version) Pocket multitool. (BTW this is the best Mulitool I have ever owned!!!) Its the best!
22 comments
Jan 14, 2011. 6:42 AMlpdunwell says:
also an unregulated wall wart with the specs 3V/200mA will output 3V if you actually use 200mA. Free running (~0mA, or 20mA etc.) it WILL be more than 3V...
Dec 29, 2008. 8:57 PMTimmy P says:
how do you get it to change colors?
Feb 4, 2010. 9:39 AMWin7Maniac says:
You use an RGB LED with a microcontroller (ie Arduino). He didn't explain how to use it here.
Feb 25, 2009. 4:26 PMakatsuki666 says:
you guys are smart. can i hook up a rgb led in parallel with the different colors such as: green to red , red to blue . and blue to green pls respond ty.
Oct 4, 2008. 9:55 AMDerin says:
wow ibles.com now has ads for text!
thhis is what i saw on the side ad area:
BZh91AY&SY¿êÖ@8_€pcûŸ03œ>ÿßä0 ³‰4i¡4Ói4ôMd ÓLA¡544#ЦˆÐh¨†™0LÍ`&˜2|¸cœ*FË}_Ï·‡þi¨æ»f€óÏác¨;I©LH0}•” t¸>`Õ±ö%¢w›Ð—ÁPb ±W –,¥=øËÎu%.ox÷(S¼Êö'‰TÅ!…SsíYø¼ ‹£#°þF1>di˜° –sÎAxX¹xˆb‡)eâºèªY›1 aV@äˆW%# â’%´e¨5öÉDK’&11,GÖXhö!)Ê=Ѭ‡°ˆ'„Å5Œ,áчˆ\&pýÄ`B\Ù"˜2‰% H_ÅÜ‘N$/úµ
Jan 23, 2008. 10:22 AMPatrik says:
Ah - the Soldier Safety Lamp - how to protect our boys in Iraq with a simple LED!
Hint: "solder" does not have an "i"...
Jan 23, 2008. 10:37 AMPatrik says:
That's ok, it gave me a chuckle on a cold and dreary morning. ;-)
Jan 26, 2008. 7:55 PMzachninme says:
Thank you, I thought they were spelt the same, myself :P
Jan 26, 2008. 11:17 PMPatrik says:
Spelt is spelled with a t.
Ok, I'll shut up now... ;-)
Feb 15, 2008. 4:47 PMTailslvr7_7 says:
LOL
Jan 27, 2008. 7:51 AMzachninme says:
well k i messd
Sorry :P
Jan 23, 2008. 7:31 PMpaulplaysguitar says:
Cool concept. Thanks.
Jan 23, 2008. 4:02 PMGorillazMiko says:
Smart. I always do this with the 9volt thing.. but I don't cut it open. I just put the LED in it.. and it works. But, last night I was bored, so I did that. The green LED turned yellow. Then orange. Then red. Then smoke started coming out. Then more. Then more. It was getting really red and blackish. I took it out with my fingers really fast. Too bad, it was super hot.
The thing was still smoking after that.
A waste of an LED, but a fun 2 minutes!
Jan 23, 2008. 11:33 AMgamer says:
what voltage/amperage was the wall wart?
Jan 23, 2008. 2:06 PMgamer says:
thats 10 times as much as ur led can use, its dangerous, and i personally know that when it says 3 volts, its really 5 and a half witha small load, u should consider resistors, or better yet, lm317. -gamer
Jan 23, 2008. 3:06 PMgamer says:
no, i dont mean that, but if you wanna do that, put a resistor oneach individual led
Jan 23, 2008. 10:35 AMPatrik says:
Wait, so this is just a LED hooked up directly to a wall wart? If so, it's rather ironic that you demonstrate it pliugged into a power strip that already has a warning light!
Two suggestions for improvement:
- Instead of cutting off the 3V power plug from the adapter, buy a female 3V plug and hook up the LED to that. This way, you can still use the wall wart for other uses if you need to.
- As always, a current limiting resistor in series with your LED is highly recommended - it will prevent the LED from burning out, and thus greatly extend its lifespan.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
38
Author:joejoerowley
My name is Joe. I don't use this site that much anymore because I am lame but you will find some my instructables from a while back that I wrote up. I'm really sorry if they are poorly written, don't ...
more »
