Step 2Mounting the Spirit Levels and Project Case
-trim up the level holders to make sure they will mount properly to your base
-create a clean level surface to work on
-mix your 5 minute epoxy
-glue the holders to the base on the tabs that are folded out using the epoxy
-mount the project case to the base on the tab created for it, in this case I used a spare hinge I had laying around since my tab wasn’t long enough
-use epoxy to glue the case to the tab
-drill a small hole in the bottom of the case to run the wires through
-drill holes into the end of the level holders (where the light will shine through)
Add Comment
