Step 6Attach IR strip
iImage Information
The IR strip lighting should be wrapped around the edges of the EndLighten acrylic layer. You should cut the IR strip once you have gone around, since it tends to get pretty hot when left in a coil at the end. If you are just building a test setup, tape will work fine to adhere the IR strip to the acrylic layer. Otherwise, I recommend purchasing/building a u-channel frame and adhering the IR strip to the frame. That way your acrylic layers will be permanently aligned and in one simple unit that you can drop into your enclosure.
I think this might work. www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
let me know what you think.
In the DSI solution, you can have a layer of glass or abrasion resistant acrylic on top, which protects the surface and makes it much more durable. It is possible to forgo this layer and directly touch the diffusion layer (the rear projection acrylic sheet), but then you might as well go with FTIR.
You can read about the various technologies as well a list of their respective pros and cons: here.
Thx
Chris
