3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Nintendo arcade
This Instructable will show you how I built my Nintendo arcade. It is a bartop cabinet that plays original Nintendo game. The arcade is completely self contained with one power switch for everything.
You can see a video of the arcade in action at Youtube, here.
Things you will need:
1 sheet of 4'x8' 1/4" MDF
1 sheet of plexiglass
1 set of joystick and arcade buttons
1 posterboard
several cans of spray paint
an older PC
an LCD monitor
1 USB keyboard
soldering equipment
nes controller ports (ripped from a four score)
DB-25 connector
2 cases of Diet Coke :)
Inside is an old PC and a 17" LCD monitor. The back of the cabinet has two USB ports and two NES controller ports. You can connect regular, un-modded NES controllers and play with those or use the joystick and buttons on the control panel.
The front end is a simple VB program that auto loads when the PC boots. You never need to connect a mouse or keyboard to load your games. The VB program gives a list of games installed. Using the joystick, you can select the game you want to play.
Also, you can connect a keyboard and mouse to the USB ports in the back and use the set as a regular PC. It has wireless internet built in.
Step 1Building the cabinet
Draw out the arcade shape onto 1/4" MDF. Cut it out with a circular saw, jig saw, etc... Measure and cut out the remaining parts. My cabinet is 24"x18"x 24" (H x W x D). Screw all the pieces together.
364 comments
1-40 of 364next »
May 1, 2012. 9:18 PMjackflash says:
I was wondering how much everything costs to build this ?....
Awsome job btw. SAL
Apr 15, 2012. 11:05 AMcfoster15 says:
Im just going to use a nes system to do this. I know I can't save games but that seems a bit more like a real arcade anyways. I will defiantly use this design (with some modifications obviously) to make a nes arcade machine. Then a Snes arcade machine. Thank god for parents with tools or I might have to buy my own!
now all i need is some diet coke.... oh yeah and all that other stuff
Aug 4, 2011. 1:55 PMx-muts-x says:
But if you're using an LCD or Plasma,
You won't be able to play Duck Hunt...
Which is the best game ever...
And you can't put an old screen in there. They're huge..
Apr 14, 2012. 7:04 AMfarmerboyk says:
Im sure the screen doesn't matter if its LCD/Plasma.
Mar 21, 2012. 10:22 PMcc67 says:
Do you need to install an operating system for this???
Mar 21, 2012. 8:45 PMsofiadragon1979 says:
That thing freaking rocks!!!!!, I'm tinking of versions for other retro systems & include all the games that we all grew up w/.
Jul 11, 2011. 12:40 AMmitch and sean says:
Is the diet coke have to come in later on or is it used for something?
Ples explain
Mar 10, 2012. 11:54 AMthethiny1919 says:
some people dont get the joke
Jul 22, 2011. 10:42 AMpblanscet says:
it is for all the energy. caffiene
Jul 30, 2011. 6:52 PMqneuhalfen says:
Would it be possible to make a Sega arcade the same way
As you have your pc , you are free to do anything with it , just add more buttons!
Oct 6, 2011. 7:32 PMpblanscet says:
Is there a way to get the VB script from ya? still a extremely beginner vb programmer
Mar 10, 2012. 11:51 AMthethiny1919 says:
download an emulator
For Windows XP-Vista-7:
1, click start
2.Click all programs
3.Click STARTUP (folder)
4.put a shortcut to an emulator here
6.enjoy
Oct 28, 2011. 10:33 AMkulak314 says:
what are the measurements for each piece of the box?
Mar 10, 2012. 11:50 AMthethiny1919 says:
depending on your system , for him , he use 4x8
Nov 20, 2011. 9:35 AMapoorveinstein says:
How can i make that VB program, so that it runs on system boot up??
Mar 9, 2012. 7:39 AMthethiny1919 says:
1, click start
4.put a shortcut to your application here
5.The application must be a pre-made VB program or an emulator
6.enjoy
Mar 10, 2012. 8:07 AMapoorveinstein says:
Yeah mann dats really easy...
Bt i want dat VB prog???
make a button that does this action : start "[emulator name here].exe" "[rom name and location here].nes"
I may code it for you!
Mar 10, 2012. 11:46 AMthethiny1919 says:
go make it yourself its easy!
Nov 25, 2011. 7:06 PMDerek Vigil says:
How much money would this cost overall?
Mar 9, 2012. 7:38 AMthethiny1919 says:
350$
I have a question please reply to me @ thethiny@ymail.com
I have found the Ground and Open for all my buttons , now I have everything ready except for one thing, how do I connect them?
I have the buttons and the pins , please tell me step-by-step how-to?
should I get a wire and connect it to the button and open-pin ,then get another wire and connect it to the button and ground-pin? So it would look like this:
|BUTTON|
Ground Pin --------| | --------Open Pin
please help I wont waste my 350$!!!
Feb 24, 2012. 1:40 PMwildmissingNo says:
Unless I'm missing something (which is completely possible since I've only been skimming), wouldn't it be easier to use a pcb from a pc-compatible usb controller? They're really cheap, you can find them anywhere and are much easier to modify than a keyboard.
Feb 23, 2012. 4:11 PMawolf1 says:
Very cool.... Go to fav list.
But Diet Coke??? really?? I think soda is better. ^^
Jan 3, 2012. 8:12 PMpromotions says:
Wow, this is an awesome instructable it really does show how to create a state of the art nintendo arcade.
Nintendo Repair Shop
www.nintendorepairshop.com
Sep 12, 2011. 7:48 PMsboekelman says:
can i use a nes advantige controler for it?
Sep 14, 2011. 5:13 PMT_T_ says:
not without this Chip
Sep 2, 2011. 7:19 PMtrosenau says:
Im hoping to do this for my senior project, so in the upcoming next months :)
Aug 28, 2011. 2:56 PMsuperduperdrew says:
couldn't you just get an old tv,NES,and NES advantage controller?
Aug 19, 2011. 2:52 AMbrainiac1515 says:
how big is your monitor and extra side room so i can adjust the size some
Jul 4, 2011. 6:31 AMcooltool456 says:
Can you use an old mac?
Aug 18, 2011. 7:21 PMbrainiac1515 says:
yes yes you can
Aug 16, 2011. 7:54 PMBr4inFr33z3 says:
Probably not unless you can find A: a compatible emulator program and B: a way to start it on bootup.
Aug 9, 2011. 12:56 PMEkloef says:
I have one word... WOOOOOW! O_O
I have to do this some day! the relssy great part is how easy it word be to use the same machine with various emulators!
You made my head spin with inspiration! Thanks a lot =D
Jul 21, 2011. 3:10 PMpblanscet says:
it would be easier to get a joystick with buttons and use joytokey to configure it to keys
Aug 27, 2009. 8:20 AMorangeguy81 says:
Cool job. I did notice you attached the joystick on the top of the panel. You are supposed to put it under the wood. Otherwise, awesome.
Jul 21, 2011. 2:57 PMpblanscet says:
i think it looks awesome like that. looks retro
Aug 27, 2009. 10:07 AMorangeguy81 says:
ha ha.. I only noticed that because I am building my own stand up cab. awesome job!
1-40 of 364next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:russm313
