And here is the secret to an undefeatable winner: For the pumpkin racer to go straight down the track, the axles have to be perfectly parallel.
For this Instructable I am using five inch soft rubber wheels with a 5/16 axle opening. These instructions are easily adapted to any size wheel.
Don't forget: Being creative is just as important as speed.
MATERIALS LIST:
(1) medium pumpkin
(2) eighteen inch long peices of 5/16 threaded rod
(4) five inch soft rubber wheels, plain bearing
(20) hex nuts 5/16
(8) flat washers 5/16
(4) fender washers 5/16
(4) acorn nuts 5/16
(2) wrenches 1/2 inch
PUMPKIN AXLE PUNCH - check out the Instructable on how to make this.
Remove these ads by
Signing UpStep 1PUNCHING AXLE HOLES
I prefer to insert the end of one steel rod into a drill and drill the axle paths. It is a whole lot less work.
TIP: It is easier to decorate your pumpkin prior to putting the wheels on. Just remember to keep the bottom part of the pumpkin free of any materials. For example, if you do a mummy pumpkin, don't wrap gauze around the part where you will punch the axle holes.
comment
Add Comment
The Papier Boy
says:
Add Comment
