3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Pizza Oven
Building a woodfired oven with clay or mud
After having built a oven for myself, i think it's a nice to have piece of work in your backyard.
Be warned, it takes quite some time to build, but also to use it. It's no substitute for your Microwave... it's rather in the slowfood class, even if you can bake a pizza in 2-3 minutes.
Step 1What type and size do you want?
Depending on what you want to bake and the space available, you can adjust the size of your oven. The amount of material needed doesn't scale linear. My oven needed 4 times the material of a small but usable oven.
In numbers that was 600 kg of clay powder, around 950kg of sand.
In my case, the size was selected because my main use of it is to bake bread and i wanted to be able to use the cookie pans from my electric oven. I also selected the thickness of my thermal layer to keep the heat long enough to bake multiple batches of bread, without the need to reheat.
As a general guideline, i wouldn't go smaller than 40cm/16inches inner diameter. Mine has 75cm/30inches. The thickness of the thermal layer should be no less than 15cm/6inches. Mine has 20cm/8inches.
At some point you need to decide whether you want a chimney or not. I had the chance to use a oven with a chimney, but decided against it for my oven. The main advantage of a chimney is to take the smoke out of your face. The main disadvantage in a simple design, lots of heat will go out the chimney instead of heating up your oven. It also adds complexity to your design. If you need to add a chimney, because your fire doesn't burn cleanly, you can do it even after finishing your oven.
There are certain ratios between inner oven diameter, inner oven height and oven door height you need to have. The most important here, the oven opening height has to be 63% of the inner dome height. This is essential for a clean burning fire. Further, the inner dome height should be 60-75% of the inner dome diameter. With these ratios and measurements, you can determine the actual measurements for your oven. It's best if you look around for firebricks, before you decide on the size of your oven floor. You should sketch your firebrick layout on a large piece of cardboard 1:1. Then draw the inner and outer shape of your oven on it and cut it out. This will help you in the next step, the form and size of your foundation. You should place the opening of your oven away from the main wind direction. Last but not least you have to plan for a roof of some sort. If you plan to bake in bad weather, make it big enough to shelter you as well as the oven. The oven should be able to breathe, so the moisture can get out.
I would like to strongly suggest for everyone to read the book from Kiko Denzer, "Build your own earth oven". It goes much deeper into the details, he built countless different ovens and shares his knowledge. You will see references to his book throughout this instructable. Don't get me wrong here, you can build a oven with this instructable alone, but maybe you'd like to do it a little different. In this book, you will find different techniques, styles and lots of background information.
Pictures of smaller ovens made at a workshop. One with chimney, made in the sand mound method, the other without chimney was made with the inverted basket method.
109 comments
1-40 of 109next »
Oct 18, 2011. 1:27 AMeric m says:
Too complex.
Simple brick oven = faster.
or temporary mud/clay/earthen oven. Just enough for a year or two's worth.
Mar 14, 2012. 1:58 AMpompeysie says:
I agree. Mine is almost 4 years old now and although it has had quite a battering (I have neglected it a little to be honest) it still works great. Have a look at my latest post and video showing the winter damage:
http://clayoven.wordpress.com/2012/03/12/winter-damage-again/
I fired the oven up immediately afterwards and she worked just like the first day she was built.
S
Jun 29, 2011. 1:27 AMpompeysie says:
Hi clay Pizza oven lovers. aside from my blog (http://clayoven.wordpress.com) I have now produced a downloadable eBook containing everything you need to know in order to build your own oven. Have a look and tell me what you think:
www.clayovenbook.co.uk
Happy building!
Simon
Mar 13, 2012. 2:00 PM13blue says:
Doesn't seem nice to advertise your book on the back of someone else's intructable.
Mar 14, 2012. 1:49 AMpompeysie says:
All of the instructions to build the oven are also still freely available on my blog but I know some people like a good old book. Also, my oven is different to the one featured here.
Simon
Mar 14, 2012. 1:52 AMpompeysie says:
Wow that guy clearly has a pizza obsession! Amazing.
S
Mar 14, 2012. 3:51 AMpompeysie says:
I'm VERY intrigued by this " big bakers kneading machine"!
S
Jan 24, 2012. 4:59 PMAron313 says:
Now i need to learn how to make pizza!!!! HAHA
Jun 3, 2011. 5:16 PMtinker234 says:
hey could i use handmade bricks or ed bricks for this
Jun 5, 2011. 8:55 AMtinker234 says:
oh okay i just love handmade bricks and was wondering hey have you thought of useing a eltric heater as well as fire for heat
Jun 6, 2011. 5:54 AMtinker234 says:
yeah i just meant as a added benfit
May 31, 2011. 9:23 AMtreynolds57 says:
Thomas, that was a FANTASTIC Instructable! Great job and your English is just fine. Thanks for sharing!
May 14, 2011. 3:14 AMbowow0807 says:
i was wondering what is the color of the clay? because in my country we seem to have high rich clay content in our soil. and also would the oven survive heavy rain because 6 months is of the year is the rainy season and we don't have snow so frost is not a problem. and when i dug in my yard i found a hard dark soil under the gravel
May 16, 2011. 4:19 AMbowow0807 says:
thanks ill try that and when i dug in my yard i had to use a pickaxe to get to the dirt because it was so hard that i couldn't use a spade, so maybe its a good sign? and by the way it had rained only a week ago and the dirt is very hard now.
May 16, 2011. 9:13 PMbowow0807 says:
i just made a small ball last night and how its rally hard like a stone and when a dropped it from shoulder height it cracked and broke like a brittle rock and like you said it formed some cracks due to shrinkage. i think that this would be a great material if i let it mix with sand
Apr 4, 2011. 9:48 PMmax-! says:
I have some old concrete 'urbanite' - it has a really high aggregate content - do you think that would work?
Apr 6, 2011. 9:23 AMmax-! says:
Thanks - I'll give it a shot - great instructable.
Apr 2, 2011. 7:58 AMxhalmers_860 says:
hi - I was wondering, the River Cottage Bread book has some instructions on this - and they suggest doing three layers - innner, 'insulating' (with woodchip mixed in the clay' and outer. Any point in doing this?
Jan 23, 2011. 7:24 AMbrowneken says:
I myself will be building two of these this summer. After a lot of reading it appears that your door ratio may be a little on the large size which would result in a large heat loss. Would you agree with this?
Oct 26, 2010. 9:50 PMde Oliveira says:
Hi t.rohner!
You can also build this oven making a mold with fine and wet sand as you want inside. Cover with clay, as you did. When dry, open the door and take the sand out for next building. You may use soil cement in a ratio of 18:1 with bamboo slivers either to build the oven or to cover it. Ok, it's a little bit more expensive.
How much water to use with soil cement? Get in hand some clay and squeeze. Falling just a drop of water is perfect.
To avoid cracks mix sugar with clay. Warning: the mass is slightly softer with sugar. Wait to dry completely and fire strongly. Using cement, don't forget to wet for 3 weeks, to keep cement cold and just use after 30 days. You can use sugar with cement too. Very good!
Then, good pizzas, good breads and much more!
Aug 17, 2010. 10:20 AMpmartinez says:
Dude you AWESOME !!
Jun 15, 2010. 10:38 AMgingboote says:
amazing... thankyou, you've inspired me.... I'm going to start collecting materials and plan for my own oven. Have wanted to make one for about a year but have never been brave enough on my own even with lots of research!! This is a very helpful concise and enjoyable instructable to read...will try to enlist the help of my friends with the promise of pizza and home made champagne!! :-)
May 9, 2010. 2:04 PMlonghairedartist says:
I'm curious why you didn't use quicklime, the fireproofing and waterproofing ingredient i've read about in cob books. I've made mud bricks in Mississippi climate, they just melt away in the rain, without quicklime added. I submerged a quicklime brick in water for over a year and it remained hard.
I'm guessing the temperature of the oven turns the clay into ceramic? But I wonder if the straw burns without the lime to protect it?
May 23, 2010. 7:58 AMlonghairedartist says:
Quicklime repels liquid, but is vapor permeable. This is why it forms a superior mortar for brick, or at least that's what the spokesman bragged about on their visit to my architecture materials class. I purchased two books for building cob homes, both adamantly require at least road grade quicklime, a truckfull from $300. From my experience, i hesitate to call it a cob unless it has quicklime, mudbricks are so different in quality. I remember reading somewhere that the great fires in the times of the plague were the result of having abandoned the use of limewashing. It seems the carbonate structure limits the burning reaction. I can still hardly believe it myself. Would love to see a detailed experiment.
Apr 21, 2010. 8:49 AMCodini says:
Nicely done Instructable! I have the Kiko book and I'm going to build a variation on this some time this summer.
1-40 of 109next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:t.rohner
