3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Pizza Oven
Step 2The foundation
The foundation
Since your oven will be pretty heavy, you will need a stable foundation.
In my case, i had a old fireplace that i used as a base for my oven. A friend made a iron reinforced concrete plate for me. It is 130cm/52inches square and 6cm/2.5inches thick weighting around 350kg. This was a heavy lift for 4 persons. I originally wanted it twice as thick and even larger...
If you don't have a fireplace to convert , you need to make your foundation from scratch.
Depending on where you live, you need to make it frost proof. How deep you need to dig for frost proofing, it's best to ask a local builder. I'd dig at least 50cm/20inches in a frost free zone. Then you can build up walls up to the oven floor height. Then fill it up with gravel, and compress it by jumping. Fill the last 10cm/4inches (minimum) with sand. That's where you will put your firebricks as your oven floor.
What bricks you use is up to you. If you have large stones around, use them. Kiko suggests to use "urbanite", that's scrapped concrete you can find at your local dump.
8 comments
Jun 3, 2011. 5:16 PMtinker234 says:
hey could i use handmade bricks or ed bricks for this
Jun 5, 2011. 8:55 AMtinker234 says:
oh okay i just love handmade bricks and was wondering hey have you thought of useing a eltric heater as well as fire for heat
Jun 6, 2011. 5:54 AMtinker234 says:
yeah i just meant as a added benfit
Apr 4, 2011. 9:48 PMmax-! says:
I have some old concrete 'urbanite' - it has a really high aggregate content - do you think that would work?
Apr 6, 2011. 9:23 AMmax-! says:
Thanks - I'll give it a shot - great instructable.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:t.rohner
