3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Pizza Oven
Step 4Building the sand mound
To define the interior shape of your oven, you have to build a sand mound. To do this, you also have to insert your oven door. The easiest way to make your door, is sawing it out of wood. It's best to use some fire resistant wood like oak. Before you close your oven for baking, you can soak it in water.
For my oven, i had to mount the oven door somehow. I got it from my neighbor, he has a whole lot of them around in different shapes and sizes. He's a retired blacksmith who still has his shop and is still working, but only on jobs he likes. I wanted to mount it decoupled from the hot oven, so i mounted it to the concrete plate. This was made because of the different expansion under heat. As a next step, i added a ring made of cardboard in order to have the inner walls going straight up. This way, it's easier to remove the ash and i have more usable space for baking. We added some more cardboard to stabilize the sand mound around the oven door. It is important to use "sharp" sand, no beach or round sand. It also needs the right moisture content, otherwise your mound will fall apart. As a further effort to stabilize the mound, we used paper with paste or goo on it. (I'm not sure about paste or goo. I mean the stuff you use on wallpaper.)
1 comment
Aug 19, 2008. 9:13 AMleoneill says:
Thank you ever so much for taking all the trouble to document this and yr cleAr instructions. You never have to apologetically eexplain you are not originally an English speaker, because yr English puts most of us to shaME! I would like to see pictures & dimensions of your brick moulds & how you made them, the moulds.Did you fire them or just let them dry. Thanks so very much. May you win the lottery tomorrow! --mo
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
51
Author:t.rohner
