loading
Step 4: Remove Microphone Foam
There's a little foam cover over the microphone hole. You can optionally leave it there, especially if your drum kit uses pads.  But, if your drum kit has mesh heads, which are quiet, you'll want to peel the little black foam piece off the microphone to make it more sensitive.
I would highly recommend heat shrink tubing instead of using tape it will not become sticky over time and will look a lot more professional
About This Instructable
5,436views
6favorites
License:
More by pedropete1:How to build a Right Hand Drum Stick
Add instructable to:
