loading
Step 7: Start to Connect the Micrphone to the Stick
Cut a length of duct tape (not the vinyl type, the cloth-like, softer stuff) about 2.5 inches long (for a 5BN stick).  Or, just make the tape a little longer and you can trim it in a later step.  Lay it sticky side up and place the microphone at one edge and the stick opposite, the end facing the mic.  Keep about a 1/4" gap between them (the foam will have to fit in there).  The idea is that the stick must vibrate independent of the mic housing.  For example, if you press the mic directly onto the end of the stick, it will be less sensitive.
I would highly recommend heat shrink tubing instead of using tape it will not become sticky over time and will look a lot more professional
About This Instructable
5,436views
6favorites
License:
More by pedropete1:How to build a Right Hand Drum Stick
Add instructable to:
