How to build a SOLAR BOTTLE BULB by liwanag
Contest WinnerFeatured
Light up dark areas in your home during daytime using this green and sustainable concept. Recycle used clear plastic soda bottles, add water+bleach, then install. After installation this solar light bulb can provide approximately 55 watts of light from the sun!
The comments below have noted that this is like a solar tube or deck prism.
The communities who benefit from this idea live in areas where the houses hardly have windows and live in darkness even during daytime. Their solution up until this innovation was to turn on the light bulb and use electricity.
Source: www.isanglitrongliwanag.org
Materials:
*PET soda bottle
*Galvanized Iron (GI) sheet
*Rubber sealant
*Bleach
*Filtered Water
Step 1: Cut approximately 9 x 10 inches of GI sheet (corrugated or flat)
(Filipino: Gumupit ng yero na may sukat na 9 x 10 inches.)
*Here is a how-to video
basementhacker says: May 7, 2013. 2:04 AM
Is there something special about PET bottles? Would normal un-PET bottles work too?
contactscolored says: Mar 26, 2013. 3:30 AM
sensational and informative! thanks
softenersreviews says: Mar 2, 2013. 8:50 PM
WOW!
Thank you so much :) You made my day !!
BlueKnyght says: Feb 27, 2013. 5:30 AM
can't we use glass bottles instead of pet bottles??? i think glass will last longer than plastic... or probably forever if left undisturbed.
karlamae657 says: Feb 14, 2013. 6:41 PM
yes!
acachucho says: Jan 29, 2013. 1:08 PM
Could someone please email pdf instructions as I am not a Pro memeber
kdiane says: Jan 27, 2013. 9:07 PM
thanks
aewers says: Jan 27, 2013. 4:44 AM
It isn't anything special just the light being scattered. Kinda like when water drips from a sink and you see little dots of white light flit about the ripples. There is no chemical reaction or luminescence. It only provides light during daylight hours. Hopefully that helps
JensonBut says: Jan 20, 2013. 9:39 PM
WOW!
MartijnD says: Jan 9, 2013. 7:45 AM
I would add some salt and alcohol too, if it freezes the bottle will suffer less forces because the water will not freeze so the water will not turn to ice; ice has a lower density than water so the volume will go up, stress on bottle where the bottle is in contact with the roof-panels.
Adding fluorescent components wiil make it glow a little, not enough to see what you would be doing but maybe nice as an orientation light.
These kind of bottle lights can also be placed in a wall, I saw it in one of the Transformer movies near the Pyramids where megan and shia hide and are found by a bug-transformer, these look more like glass wine bottles glued in a cement wall, looks pretty cool too!
MartijnD says: Jan 9, 2013. 7:42 AM
I would add some salt and alcohol too, if it freezes the bottle will suffer less forces because the water will not freeze which results in ice; ice has a lower density than water so the volume will go up, stress on bottle where the bottle is inside the roof-panels. Adding fluorescent components wiil make it glow a little, not enough to see what you would be doing but maybe nice as an orientation light. These kind of bottle lights can also be placed in a wall, I saw it in one of the Transformer movies near the Pyramids where megan and shia hide and are found by a bug-transformer, these look more like glass wine bottles glued in a cement wall, looks pretty cool too!
jniedo says: Jan 7, 2013. 10:32 PM
Cosmic Electricity
ggarriga says: Jan 1, 2013. 6:36 PM
There are several comments on the use of Glass Vs PET bottles. As I see it your only issue would be with weight of the container and the strength of the adhesive used to fix the bottle to the roof/ceiling; Maybe using smaller PET bottles 1.5 liter/600ml in larger quantities a beter distribution of light can be achieved.
msluka says: Dec 20, 2012. 11:29 PM
..tolle Geschichte!
nmoraga says: Nov 18, 2012. 10:20 PM
just a question , what if i pour half of bottle with bleach and the other half is water, will it be more brighter?
silentarts says: Dec 17, 2012. 6:36 AM
Good Question...
fretted says: Dec 6, 2012. 11:35 AM
Hmm the Bleach keeps the water from stagnet nasty's and the water refracts the light from above to below into the darkness very clever nice Ible
ayyash ahamed says: Oct 31, 2012. 3:45 AM
thank you, how many grams should be added to how many ml of water to make this as we dont get chlorine liquidised.
-t says: Sep 7, 2012. 10:21 AM
I love this idea but I am curious if it could be made more efficient with the use of a Glass bottle and a more reflective piece of sheet metal (like aluminum?).
Any thoughts?
-t says: Sep 7, 2012. 10:18 AM
I am building a houseboat utilizing upcycling techniques and DIY energy harvesting. I love this idea! but I am curious if it would be more efficient with a glass bottle and a more reflective metal (like aluminum).
Any thoughts?
Varenberg says: Aug 28, 2012. 4:15 PM
This may seem like an odd question, but what if you use a bigger bottle, like the 5 liter ones? Would the light distribution become more like a 100 Watts light bulb?
kmasoods says: Aug 13, 2012. 6:12 AM
Great idea...
But i want to clarify somethings.... One.. what if i at some part of the day I dont want the light to be there in the room... How can the light be removed temporarily...
SacredDemon says: Aug 24, 2012. 3:02 PM
Probably some kind of cover would be the best way to block the light with out leaving a big hole in the ceiling.
nmaynite says: Aug 14, 2012. 9:10 PM
hi...this is thine from BSYF (Bagong Silangan Youth Federation)...we went der yesterday po with Asian Bridge Phil and Asian Bridge Korea.... i/we reli lern alot from your foundation..... AJA!
davidkichi says: Jul 30, 2012. 5:45 AM
Great instructable! Not to be silly, but I don't think anyone has addressed the issue with the sun heating the water in which could be used if the container was perhaps bigger (water cooler size) to hold a certain amount for washing dishes or light showers during the summer. You'd need to have a hose going into the top for refilling with fresh water and a hose or shower attachment on the bottom with a release valve.
gowri belawadi says: Jul 11, 2012. 10:08 AM
friendz........does this work???????? i want to do this 4 my exhibition...
Padre Paul says: Nov 3, 2011. 1:43 PM
I was wondering does the solar bottle bulb light in the night? I have read all comments with a view of finding an answer to this question in vain.
garypcom says: Jun 30, 2012. 4:11 PM
It does not work at night. The only way it might work at night is if there is a streetlight near by or there is a really bright full moon. All this does is refract the sunlight into the room. The water does not PRODUCE light, only "bends" existing light into the room.
Tazo says: Nov 29, 2011. 3:15 PM
you've read all comments but you did not read the first line of the instructable itself, you will find the answer there.
akosisamae says: Jun 29, 2012. 11:12 PM
as far as im concerned, for me this project is good and equip for the people. we can use it in our houses. but like what other commentators are asking, how the bottle full of water with bleach lighted? is it becoz of the reflection and exploration of sunlight.?.. can we use this thing in night ? :) thanks
bfk says: Jun 23, 2012. 11:23 AM
This is a great new-tech update of glass deck prisms used aboard ships centuries ago. Perfect for sheds. Thanks.
DURANT says: Jun 19, 2012. 12:36 AM
Is it OK to use this idea in our college research?...
weskeryami says: Apr 2, 2012. 1:04 PM
hola enserio esta cosa prende? jajaja por q ya lo intente para un proyecto pero no nada q brilla y segui al paso todas las instrucciones .... necesito ayuda ....... porfas...... es urgente !!!!
kaalas says: Mar 12, 2012. 11:21 PM
can u please say me the reason how it glows?????
rogiervdheide says: Mar 14, 2012. 9:32 PM
Kalaas, have a look at the comment at the top. The bottle doesn't glow it catches the light of the sun and passes that on into the home. Lighting designers would call this a "solar tube" or something like that...
kaalas says: Mar 15, 2012. 6:34 AM
and i have an another doubt. Will produce light at the night time also? because im presenting dis experiment in my college so that we can help d poor!!!!
ShubhiAgrawal says: Dec 13, 2011. 6:20 AM
I have tried to make a model of this solar bottle bulb for my science exhiibition but I don't know why it is not working... I sealed the bottle properly, used liquid bleach and water but it looks like a simple soda bottle filled with water...need help desperately....plz help..
it your bottle catching any sunlight? It should
sheepborg says: Jan 1, 2012. 12:18 PM
Well, in actuality they are cheating just a little bit.
While the top and bottom of the bottle sticking out it collects and puts out light at a greater angle than just a hole it does not increase the power of the light. So in normally lighted situations it is just that, a soda bottle with water in it.
Since it is the only source of light for the videos it looks really bright (and the cheating i mention was added exposure and contrast on the video)
that being said, you arent doing anything wrong.
As with most of these feel good initiatives and whatnot, they make them look really grand, but they are often less than grand, or at least rather simple.
Not saying it is a bad idea, it is good, but it is being rather over-marketed.
bddeverall says: Jul 27, 2012. 11:27 PM
There's no revenue involved so why take the pains to market it? Even if they were "over-marketing", they need the hype to spread the word and help as many people as possible. You suggest that there is some deceit involved with images and the concept. Everything is enhanced with the technology today so just take it for what it is...something positive.
zszczęsny says: Oct 31, 2011. 10:13 AM
OK, I've read all the comments and explanations and I still do not understand one thing:
Why the hell can't they use full (unopened) bottle of sparkling mineral water?
This would have the following advantages:
- sparkling mineral water coming from beverage manufacturer is aseptic. High CO2 content kills any algae or bacteria.
- internal pressure of CO2 in the bottle prevents shrinking/swelling form changing atmospheric pressure allowing for good roof seal.
- though actually CO2 can migrate through the wall of plastic bottle, the diffusion factor is pretty low, so it will keep internal pressure for at least two years. Original closure by the manufacturer is also pretty tight and leak-proof.
- no need of bleach or other additives - the price of sparkling water PET bottle at the shop is also very low.
kaalas says: Mar 12, 2012. 11:24 PM
i want to know d reason why it glows???? can you explain me?????
rogiervdheide says: Mar 14, 2012. 9:30 PM
It glows because it catches the light of the sun!
hcanonigo says: Nov 19, 2011. 7:31 AM
I agree with beehard44. We don't like to waste stuff. So, we'd rather drink the drinkable water then just put in not-so-clean water(ex:tap water) and bleach which does the same thing.
sokamiwohali says: Feb 15, 2012. 9:05 PM
sir, you and zszczsny seem to be missing the point of the project...these pople to who this man is doing this project for are already poor enough as it is...instead of buying the bottle sealed up from some supermarket (in this case probably just a small town outside food market) and all that fancy stuff, he is re-using an initially useless object which would have been cluttering up the streets as litter, OR sitting in a landfill somewhere just chilling out, and turning it into a VALUABLE resource...Light for those who cannot afford electric lighting...or even afford to buy simple candles during the day. A word to you fellows and everyone else in our instructables community...Most all of us have grown up in an environment where we could afford simple luxuries/commodities...apparently this town is one of those in which only the rich can enjoy them. Stop and think about what you write before you write it about why the person is doing a very special and commendable thing for their people. As far as "wasting" water...well, one could easily replace the lost water by digging a hole in the ground throwing a pot in the middle with green folliage around it, secure a plastic sheet with rocks taughtly over the hole and placing a reasonably sized rock in the middle as to not loosen the plastic. is a day or so, you would have already replaced the water that you used up...maby not efficiently, but you still replaced it. I am not in any way trying to be mean nor have an attitude in this message, so if thats the hint you got, thats not what i was trying to do...i am merely implying an emphasis on the matter.
LIWANAG...you sir have inspired me to instead of using electricity to power lights in a treehouse that i am going to build for my children in the near future, i am going to use your idea of the "Soda Bulb" to provide light for them. thank you so much for this valuable method of not only recycling, but also providing light in a way that halps the environment.
breunor says: Oct 31, 2011. 1:43 PM
Noting the location where this is being done, the cost of an unopened bottle might be a bit too pricey, compared to a discarded bottle that was scavenged from a landfill at no monetary cost. Bleach might also be free to the locals if provided by an NGO aid group, so it's a matter of free materials versus a commercially purchased item that does the same thing.
I agree that using the original would be more stable, but if it was punctured, then you'd have the potentially sticky residue of the drink to deal with too, versus plain water.
zszczęsny says: Oct 31, 2011. 2:32 PM
Sure - we are talking about poverty what has no limits. But taking into account the movie provided by liwanag - he collected the bottles just "in situ" rather than on the landfill, so I presume somebody from the locals had already drunk the content... I presume saving it from drinking and using it "as it is" for lighting can be actually better saving than struggling with leaks and algae...
beehard44 says: Nov 10, 2011. 1:15 AM
Here in the philippines people are very conservative when it comes to food. There's barely any wastage. Which is why we use empty bottles instead of unopened bottles. Why use unopened bottles when you can drink it first and replace it with water with bleach?
Besides, there's no sparkling water here.
tere bin says: Mar 3, 2012. 2:39 AM
Can any 1 tell me that instead of bleach....if there is any other locally chemical avaible which can make light enter into the space and create a Fascinating space....or there is anyother solution that can make react water to create GLowing and lumincing effect
kaalas says: Mar 12, 2012. 11:23 PM
ya fill it with 10ml of chlorine in a fully filled water bottle!!!!!!!!!!! but i want to know how it glows and why??????
isaacwilk says: Jan 14, 2012. 7:46 PM
What does the bleach do?
I'm assuming rubber sealant is affordable and avalible in poor communities?
It's a good idea for lighting, but I'm not so sure about the green/recycled side of things...
ASCAS says: Jan 28, 2012. 11:38 PM
The bleach is used as an anti-bacterial agent.
lululululu says: Jan 17, 2012. 5:57 AM
Did you think about putting some optical brightener (that we can find in some laundry detergents) in the bottle? http://en.wikipedia.org/wiki/Optical_brightener
it would for shure increase the luminescence of the bottle...
velcro2 says: Oct 16, 2011. 9:41 AM
It sounds great at first but all of you are forgetting barometric pressure. Plastic bottles make very good barometers and they can shrink and expand according to the barometric air pressure at the time. If you make your plastic bottle light during a time of low atmospheric pressure (i.e., lower than 84 cm) and fill the bottle then when you have high atmospheric pressure the plastic bottle will burst. If you keep the water at a lower level to accommodate this you will still end up with a sealant problem with the roof panel. The bottle will expand and contract and reduce the integrity of the weather seal around the bottle (if there was one to begin with) and it will leak when it rains. The mid-tropics get a disproportionate share of the sun's UV light which also has a detrimental effect of the plastic bottles causing embrittlement and cracking. It's back to the "drawing board" on this idea and perhaps a glass liter bottle (like the old coke bottles) might be more durable and longer lasting. The glass coke a cola bottles were thick and fluted and the shape would allow it to be secured easily in a roof panel.
jarikcbol says: Dec 3, 2011. 11:06 PM
this problem can be inhibited by submerging the bottle completely when filling, and capping it while submerged. Zero airspace in the container removes the major portion of barometric effects, as water is essentially non compressible.
vtbeachldy says: Oct 17, 2011. 11:03 AM
I don't see the barometric pressure as a problem. If the bottle shifts enough to fall out of the hole, run for cover before the hurricane hits.
DabeAltis says: Oct 16, 2011. 8:01 PM
I believe you're thinking backward, a high barometric pressure would tend to make the bottle collapse rather than expand or "burst". Either way, if you were careful to trap as little air as possible in the bottle the barometric pressure would have little effect on the dimensional stability as the water will not compress as air does. These bottles are basically polycarbonate, AKA Lexan, and are incredibly strong. I have had over 120 PSI of pressure in them with no detectable deformation! I seriously doubt you will get one to burst with a drop in atmospheric pressure, even if you placed it in a vacuum chamber.
keng says: Oct 16, 2011. 7:48 PM
I think they are ok with this. The research I did when doing a home soda station showed that they will take a little over 200 lbs/square inch.
criggie says: Oct 16, 2011. 11:47 AM
I understand your point, but then these 1.5 and 2 litre PET bottles would be exploding on supermarket shelves. And I've never seen that.
More likely it would split and burst if the temperature drops to below 0 degrees C.
Personally I think one piece of "laserlight" plastic corrugated instead of a sheet of iron, works much better.
Dr.Bill says: Oct 17, 2011. 10:16 PM
I've seen them explode right in the store. It seems the combination of carbonated water and the heat in Hawai'i sent the pressures up and BOOM !
big mess
However, I don't see water and chlorine doing the same even with the heat.
Very good idea BTW.
shortw says: Oct 16, 2011. 7:40 PM
I had those 2 liter bottles outside in sun with soda inside and they become hot to the touch and no explosion.
I also forgot them in the car at -15 C and they froze and there was no damage.
I use a frozen soda bottle of water as a icepack and drink every day for my lunch-box without any problems.
taliran says: Nov 28, 2011. 9:37 AM
NICEE.....go a head!
ShubhiAgrawal says: Nov 28, 2011. 5:20 AM
How does this solar bottle work?
Remag1234 says: Oct 16, 2011. 8:15 AM
Great idea, here's comes the Big BUT.........why not just cut a hole and silicone a piece of Lexan/Glass in place and have the light and not worry about bottles degrading with the possibility of bleach spilling on things below...
Just my 2 cents and what I think is a better way to go GREEN.
asuvas says: Nov 15, 2011. 7:42 PM
The other advantage of the bottle is that it descends into the room and reflects light in all directions, no matter where the sun happens to be striking the top of the bottle. A glazed hole the diameter of a soda bottle would give a fraction of the light, and would not distribute it evenly.
vtbeachldy says: Oct 17, 2011. 10:54 AM
The first I saw of this idea was in the Phillipines in a very, very poor neighborhood. I think recycling a soda bottle is a whole lot greener than paying for Lexan or glass which are probably not available. The great thing about the technique is the metal piece the bottle is inserted into becomes a shingle. Very easy to tuck under where two pieces of wrinkle tin overlap, and the caulking is then minimal. Difficult to seal around a flat piece of Lexan or glass, don't you think?
vtbeachldy says: Oct 20, 2011. 5:07 AM
It occurred to me that if you had Lexan or glass, you'd just build a window the size of the glass. When all you've got is a soda bottle, tin snips, and water, the solar water bottle is an elegant and simple solution.
xenor says: Oct 17, 2011. 4:30 PM
Alternatively, if cost or availability of Lexan is an issue, you could simply cut open a few bottles into sheets and conform them to the corrugations. A little heat would help to soften the plastic to make this easier.
Downside of this is you lose the lens effect of the bottle.
cliberato says: Oct 16, 2011. 10:18 PM
You big BUT doesn's exists. do you think about the money???
General Lee 450 says: Oct 16, 2011. 9:16 PM
I personally would not use bleach. I would use Hydrogen Peroxide as it will do anything that bleach will and it's not harmful to the environment if it happens to leak or get destroyed somehow.
Good Ible !
gzuckier says: Oct 16, 2011. 9:27 PM
I don't think hydrogen peroxide would work. The purpose of the bleach, i'm pretty sure, is just to keep stuff from growing in the water. hydrogen peroxide will leave the water pretty quickly and junk will grow in the bottle, whereas the chlorine will keep the water clean. That much chlorine in that much water isn't very bad, you could probably drink it with no problem. In fact people put small amounts of chlorine bleach in containers of water that they put away for emergencies, just so it will be drinkable a year later when they get to it.
muddog2 says: Oct 19, 2011. 11:37 AM
think of bleach as two parts - chlorine and soap. The chorine will break down with sunlight (check with anyone with a pool or hot tub) while the soap will last quite a while. BUT, the hydrogen peroxide will leave much sooner and will not leave anything behind to help keep things clean. Also, there is the cost of a little bleach or a lot of the peroxide. Just like the cost of the bottles vs the lexan, bleach makes more sense economically.
General Lee 450 says: Oct 19, 2011. 5:39 PM
My bleach and also Hydrogen Peroxide neither one has dissipated inside a closed bottle. Only when I open them to the air do they go away. As long as the bottle is sealed up, I don't think either one will "go away". I've used them both for different reasons, and have found they both will do about the same jobs.
I use the same amount of one as the other and find no difference between them for getting a job done.
Sorry but the HP is cheaper for Me.
I'm not an engineer, just speaking from experience.
kretzlord says: Dec 19, 2011. 9:24 PM
Hydrogen peroxide breaks down under UV exposure (which this would get plenty of). however, chances are the HHO already killed what was in the water and it was sealed, so there shouldn't be anything green in there once the hho breaks down
jgonzalez-2 says: Oct 16, 2011. 11:41 AM
good idea on the lexan. but you got to remember. he basically made it VERY green by the stuff he finds available. , the bottles didnt cost him anything. the lexan on the other hand comes with a price. glass as well. i could make this with no cost to me at all. but with the lexan. if i didnt have it available. like them, ill be without light for a long time.. BUT the lexan/glass idea would let more light in. it would be called a major upgrade in the hood,
Gordyh says: Oct 16, 2011. 9:06 AM
If you watched the video's you saw the economic situation of the people there. The bottles are free. The portion of the bottle of water above the roof acts as a prism bringing in more light than the same size hole with a plexy glass cover would. The smaller hole in the roof has several advantages, one being less caulking to buy, and no need to add structural support under the tin that a larger hole would need. Also with the corrugated roofs they show a larger flat sheet would be way harder to seal and get so that it would not hold rain water at the top edge.
Remag1234 says: Oct 19, 2011. 1:06 PM
Bosch cordless drill price.......cheapest I found is $110.00 plus S&H, tax equals to about $140.00. Cheap tin shears cost is about $15.00. Poor indeed.
hcanonigo says: Nov 19, 2011. 7:27 AM
Have you seen the conditions of the place? The materials (including the tin) they use are scavenged from garbage, plus the drill is probably years old, or is borrowed (I know 'cause some of my relatives live in these places). We Filipinos (especially the ones in the poverty class) tend to keep using the same thing until it quite literally breaks down or until it is absolutely beyond repair.
breunor says: Oct 31, 2011. 2:04 PM
I doubt any of the "home" owners there owned the tools, as you saw the guys had an assembly line going to make dozens of those. Also had a big water tank, the kind aid agencies use to provide drinking water. I wouldn't be surprised if it was CCF or some similar group doing this to improve living conditions in a shanty town.
bob.the.devil says: Oct 16, 2011. 8:24 AM
also an empty bottle is way cheaper than a sheet of glass
bob.the.devil says: Oct 16, 2011. 8:19 AM
yes and no to that. the water helps distribute the light more evenly, it "scatters" it. glass would simple let down a focused beam (that would change direction based on the time of day) also it uses very little bleach and plastic takes a long time to break down.
Adum24 says: Nov 14, 2011. 2:07 PM
Darn it! Of course this guy will win because he has an emotional back story! :)
Best of Luck!
peeps1234 says: Nov 14, 2011. 8:25 AM
Let's think on how this is being created.
firstly, I believe that adding bleach produces lots of nascent [O]. Now since there's nothing to react with, nascent [O] reacts with nascent [O] to produces O2. Excess production of O2 leads to O2 gas bubbles in the solution, leading to lots of Total Internal Reflection. Saying Refraction without providing explanation is not really good, in this case.
Adding Ethanol as an anti-coolant or something wouldn't be good since excess of nascent oxygen would oxidise it to carboxylic acid. Which might erode the bottle if concentration is too large.
peeps1234 says: Nov 14, 2011. 8:28 AM
Also, salt may increase the Refractive Index, but
1)Just TIR at the border of water and plastic or plastic and air will not be enough for such amount of light.
2)Salt also makes it a little translucent.
poppet2 says: Oct 16, 2011. 9:05 AM
I haven't seen the answer to whether or not the bottle is apt to freeze...and if there's any way to avoid it. Love the idea, but live in the north. The inside of the shed might be relatively warm, but wouldn't the outside make the whole thing freeze? If it wouldn't freeze, could one be put in the side of a building? That way it wouldn't be covered with snow in winter.
SentencedToLive says: Nov 9, 2011. 5:48 PM
Let's keep it simple. First, this works by refracting sun light (no sun, no light), so any other substance that refracts light may work. The advantage of the water is that it's cheaper than any other liquid. They add chlorine or bleach to prevent the growth of microbes, thus extending the lifespan of the device.
Now, you have two ways to avoid freezing: adding a modifier or replacing the liquid entirely. As we said, it would make it more expensive to use anything different than water, so an additive would be better. Salt is a good idea, but unpractical, because you need a lot of salt to achieve a useful result. For example, to lower the freezing point to -5ºC you need 2% of salt. Also, the more salt you add, the more turbid the solution gets, so it will lower the effectiveness of the device.
I guess the more convenient way to approach the problem would be a mixture of an anti-coolant and water. The best choices, economically speaking, would be ethylene glycol (the common anti-coolant) and ethanol. You would get almost the same amount of anti-cooling effect with mixtures of these substances and water (in a 50:50 mixture, you would get a freezing point of -37ºC with ethylene glycol and -32ºC with ethanol). The more important thing here is that ethylene glycol is more expensive and is poisonous. Ethanol, on the other hand, is cheaper, but flammable (although, the more water in the mixture, the lower the risk).
If you want, you can take a look at this page:
http://www.engineeringtoolbox.com/ethanol-water-d_989.html
There you'll be able to find the tables with the proportions and the freezing points of ethanol:water mixtures.
One important note: both ethylene glycol and ethanol have preservative properties, so if you use them, there's no need to add bleach or chlorine, specially in the case of ethylene glycol, because the bleach will attack and decompose it.
Hope it helps, see you.
Monsterguy says: Oct 16, 2011. 8:43 PM
I don't drive so I've never taken a close look at antifreeze, but it seems like the obvious answer. Their could be very obvious (to drivers) reasons it's not suitable of course :)
mr.incredible says: Nov 7, 2011. 10:13 AM
You could salt the water and lower the freezing point down to 28 deg. I'm not sure about any chemical reaction, but alcohol would lower it even more. Maybe replace the bleach with alcohol. Too much alcohol might speed up the breakdown process. Even better fill it with mineral oil.
mrosales2 says: Oct 28, 2011. 7:24 PM
First, I found this to be so interesting, of course the simplicity of this I had to try. From my eager try, I find tap water and bleech left in the light does not illuminate. After rereading, filtered water is used. Hope the refrigerater water will be of use.
It is amazing to me that this has been around and it is the first hearing of it.
I am wondering, is it the sunlight that causes the illlumination?
zszczęsny says: Oct 31, 2011. 2:37 PM
IMHO - there is no "amazing phenomenon" of light scattering by bleached water. It is just as in case of plain water - bleach is only used to sanitize water against microorganisms what would make it completely opaque in days taking into account tropical circumstances.
breunor says: Oct 31, 2011. 1:44 PM
Yes you would see the best results when direct sunlight hits the bottle, that is what is being reflected into the room below. If it's overcast or cloudy the results will not be as good.
CrLz says: Oct 18, 2011. 3:59 AM
Brilliant project!
Would love to see designers get a hold of the basic idea and develop products for home owners.
Linksep says: Oct 26, 2011. 2:36 PM
They have, it's called a solar tube or a tube skylight. You can buy one at home improvement centers for well under $200 USD.
beopkik says: Oct 25, 2011. 6:44 PM
So fantastic IDEA!, Does it works at night with moon light? And does it works with a fluorescent lamp or a incandescent lamp instead of sunlight?
diy_bloke says: Oct 16, 2011. 7:00 AM
I am sure you could use another drill as well. Or is the Bosch mandatory? :-)
bob.the.devil says: Oct 16, 2011. 8:27 AM
definitely mandatory :P
diy_bloke says: Oct 17, 2011. 11:26 AM
ok, got to buy a Bosch then. Just to be sure :-)
dpcorpuz says: Oct 20, 2011. 11:53 PM
@diy_bloke & bob.the.devil : guys you don't have to be sarcastic :(
liwanag for sure didn't mean to enforce anybody to use a Bosch brand drill it happens that it was the one he used with this project.
diy_bloke says: Oct 21, 2011. 12:12 AM
@dpcorpuz
Unfortunately it is difficult to convey mood in a reply in instructables. I cannot speak for Bob, but it was in no way my intention to be sarcastic, just to crack a bit of a joke. I try to make that clear by adding the smiley but obviously that did not have the desired effect.
I surely admire this instructable, just as I admire the initiative and in no way did I want to be sarcastic. It was just an open door that I could not resist kicking in.
dpcorpuz says: Oct 21, 2011. 1:20 AM
@diy_bloke
Thanks for your explanation bro. I'm also sorry if I reacted differently with the joke you intended to crack. liwanag project was able to help his fellow kababayan in his area who cannot afford to pay/shoulder the high electricity bill in the Philippines. With his iniative they were able to save a lot.
diy_bloke says: Oct 21, 2011. 2:16 AM
No problem, as said, I also highly value projects like this and in fact will be installing a couple next month in So. Leyte
bob.the.devil says: Oct 21, 2011. 6:47 PM
yeah man same here sorry to have offended you we were just poking a bit of fun at each other/joking around. just a little handy man humor. sorry to have offended.
UrbanNinjaOokami says: Oct 21, 2011. 4:39 PM
Awesome, but how is this survival??
Exocetid says: Oct 16, 2011. 9:19 AM
Clever idea, very green.
As someone pointed out, this is just a modern, very green and inexpensive version of a deck prism.
The bottle will degrade, but five years is not bad.
Forget bleach, salt is a better solution (no pun intended) because of less damage if the bottle develops a leak. Besides, salt will improve the index of refraction, giving a slightly better light piping effect.
Finally, a kit of parts that would include a rubber gasket (instead of the sealant, a gasket would make it easy to replace the bottle), rubber protective cap, bag of salt and a template with instructions. Could be distributed by UNESCO or some other organization.
jmays3 says: Oct 16, 2011. 11:19 AM
"The bottle will degrade, but five years is not bad."
Which means it will still outlast any bulb you could buy at the store, including those florescent bulbs that cost an arm and a leg! ;-)
pfred2 says: Oct 20, 2011. 4:55 AM
Yeah but most burnt out bulbs don't make your roof leak.
Gollocks says: Oct 17, 2011. 12:50 AM
5 years is great. Even with all the labor. I gotta repaint my deck once a year. (had to oil(natural) it twice a year before i switched to paint).
And I seriously doubt Pepsi and Coke are convinced of veggie-plastics yet.
Gollocks says: Oct 17, 2011. 5:44 PM
As it turns out...Coke is using 30% veggi in all their bottles currently. Pepsi, as of March 2011 stated that they "will use" 100% switchgrass in all their future bottles.
Exocetid says: Oct 16, 2011. 12:29 PM
Thinking of the bottle, I wonder if they tried inverting it and if that would give a better, more diffuse light.
kenicai says: Oct 19, 2011. 3:50 PM
Thanks for making this happen liwanag. this simple project of yours will definitely be a big help not only to the filipino community but for everybody as well. :) good job! Mabuhay!
hsah says: Oct 19, 2011. 9:08 AM
What about night, if I want to use it at night, will it help or it can be used only in some specific areas where in day SUN never go
el guajiro82 says: Oct 13, 2011. 7:25 AM
hola, felicitaciones por el invento, esto demuestra que existen maneras verdaderamente sostenibles de generar desarrollo. Vivo en La guajira- Colombia, territorio de la etnia wayuu, comunidad indígena asentada en la frontera Norte, entre Colombia y Venezuela, con una población de mas de 500.000 personas, que viven en zonas rurales con muchas necesidades básicas insatisfechas, entre ellas la electricidad. tengo algunas preguntas respecto a este método de proveer luz de manera ecológica:
el cloro comercial de uso domestico es apropiado para implementarlo en este método???
a pesar de lo obvio tengo la inquietud de saber si la lampara ecológica funciona por las noches???
de que manera podemos replicar este modelo acá entre la población indígena que carece de energía eléctrica y luz???
tankdo says: Oct 13, 2011. 8:55 PM
olvidè decirte algo, es posible que no necesiten la làmina de acero galvanizado, porque no estoy seguro de que aporte màs luz, lo que pasa es que la usan porque es una buena manera de lograr acoplar la botella al techo de las casas con tejas metàlicas, pero creo que podrías hacer una prueba en un techo wayuu (que si mal no recuerdo son de madera)
ude luz says: Oct 18, 2011. 7:37 PM
Saludos desde Colombia, para la gente que necesite esta brillante iniciativa pueden contactarnos al siguiente correo electronico: unlitrodeluzcolombia@gmail.com, somos los representantes oficiales para difundir, ejecutar y promover el proyecto un litro de luz por toda Colombia, si alguien conoce población que lo requiera no duden en ponerse en contacto,
saudos a todos,
Camilo Jose Herrera Díaz
Executive Director / Founder
Fundación Un Litro De Luz Colombia
314 430 79 82
Duitama - Boyacá
tankdo says: Oct 13, 2011. 8:41 PM
hola, yo tambièn soy de Colombia, te respondo algunas cosas:
en un video vi que usaban pastillas de cloro (que venden en droguerías a bajo costo) usaban 2 pastillas por cada litro de agua, es decir, 2 por cada "bombillo".
las bombillas dejan de emitir luz cerca de las 6 de la tarde (o la hora a la que baje el sol)
yo creo que lo más "difícil" de conseguir es la lámina de acero galvanizado, pero seguro en lugares de reciclaje se encuentran làminas baratas, las botellas se consiguen fàcil, lo que sì he visto es que utilizan bastante las de 1 litro, no menos que eso, y que la botella es funcional durante 5 años aproximadamente, lo que hace que no tengas que estar cambiando el agua con frecuencia.
Que estès bien.
el guajiro82 says: Oct 14, 2011. 6:06 AM
gracias a los amigos que a bien tuvieron la amabilidad de despejar mis dudas, en cuanto a los techos de lamina galvanizada, que localmente conocemos como laminas de zinc, ¿saben de que manera se puede implementar en techos de lamina de asbesto-cemento (o eternit), y para las viviendas wayuu que tienen techos de palma o cortezas de arboles como el cardón?, supongo que para estos casos toca recurir a la inventiva indigena para poder implementarlos con optimos resultados.
ude luz says: Oct 18, 2011. 7:36 PM
Tenemos un album con las fotos de la instalación en tejas de fibrocemento, también llamadas Asbesto-Cemento, puedes buscarnos en facebook como:
Un Litro De Luz
recuerda que nos puedes contactar para la instalación en la comunidad wayúu,
Saludos,
Camilo j Herrera
314 430 79-82
jfranco perán says: Oct 14, 2011. 2:05 PM
Para los techos de palma y corteza puedes buscar la forma de ampliar la base de apoyo, puedes coger y unir una estructura de madera a la botella y atornillarla o clavarla a la estructura básica de la vivienda.
panzerfaust379 says: Oct 18, 2011. 4:09 PM
Bleach does start breaking down after a year,but, as long as it works....Nice idea!
FetterChiller says: Oct 18, 2011. 1:09 PM
Add some phosphorescent material and you have a night-light as well :D
Petar92 says: Oct 16, 2011. 11:01 AM
Why bleach? :)
greatlakesdvr says: Oct 16, 2011. 11:41 AM
My thought would be so algae would not grow in the bottle. Thats the only thing I can think of.
tigr87 says: Oct 18, 2011. 3:56 AM
actually algae can grow in sealed water bottles. i use old milk jugs to weigh down the cover and the grow algae unless we out a little soap or bleach in with the water.plus the water starts to stink if you don't use bleach or soap
jmcmurray says: Oct 16, 2011. 11:59 AM
algae needs air to grow
waterworks says: Oct 18, 2011. 1:51 AM
I have seen this idea a number of years back done in the shanty towns of Brazil , and been trying to promoted it among my peers...
Good is on this network... Maybe we will manage to convince more people to take it on and disseminate the concept further in the field...!!!
anyheck says: Oct 16, 2011. 8:07 AM
You have invented a plastic and water deck prism.
http://en.wikipedia.org/wiki/Deck_prism
Nice job. I may put one in my shed that has no electricity.
Monsterguy says: Oct 16, 2011. 8:46 PM
I'd not heard of deck prisms before, but I've seen a lot of light tubes used in eco-friendly houses.
http://en.wikipedia.org/wiki/Light_tube
Which are obviously just a new twist on the old deck prisms. :)
Gary Viveiros says: Oct 17, 2011. 7:29 PM
Why not surround the clear plastic container with a (mainly) white plastic bag which should also be readily available. This will act as a light diffuser, possibly giving a more uniform light with less lens-efect rings of light.
sowaishing says: Oct 13, 2011. 8:39 PM
Can anyone tell me why Bleach + Filtered Water + sunlight can grow light?
rasta_bhoy says: Oct 14, 2011. 2:28 AM
i think that the bleach is just there to keep certain organisms from growing and generally to keep the water as clean and pure as possible :)
jblanton1 says: Oct 17, 2011. 3:07 PM
So, if you want a green tinted light, don't add the bleach... :)
rvogeler says: Oct 17, 2011. 3:04 PM
Love the idea! Thank you for sharing. For some of our friends out there that have not traveled overseas much, plastic bottles, like ones used here are in GREAT abundance, where electricity is not. This is a very doable project overseas for places that are not advanced. I travel and a lot of work with underprivileged places in India, Myanmar and Nepal. Nepal would have the freezing issue to consider, but the others would be a GREAT place to utilize this little jewel! I can think of many places right now to use it. I am very interested too in try to find a way to "charge it up during the day" so that it can provide some light into the evening. Not sure how to merge the two together, but if someone could come up with something, you would literally be helping thousands that I can teach to do this. Very simple and practical! Thanks again!!!
jotage68 says: Oct 17, 2011. 6:58 AM
This idea is not new. Back in 2002, after a long energy blackout, a brazilian mechanic created this to illuminate his workspace and there's even a brazilian government program to use this as an option for poor population. This video is from 2002:
http://www.youtube.com/watch?v=8SsGjjMEEDw&feature=player_embedded
There's another brazilian inventor who used PET bottles with milk package aluminium card to create solar panels to warm water, look at out: http://www.youtube.com/watch?v=jKnSxJ_TnO8&NR=1
Remag1234 says: Oct 16, 2011. 1:08 PM
4 GordyH and others,
I don't want to get into a pissing contest but here goes.
I did watch the video, and the end was particularly interesting. They ask for DONATIONS, I hope you were quick to donate. My motto is Charity begins at Home.
terry2000 says: Oct 16, 2011. 2:51 PM
That doesn't seem very nice to me. But maybe that's just me.
DragonDon says: Oct 16, 2011. 5:45 PM
No, it wasn't a nice way to say "Hey guys, they are looking for donations. Please do so!" and I damn well hope that said person donated cause I just did! Although the donations were in Philipines Pesos so that means for me, it was 41php per Canadian Dollars (not far off from the US though). I firust through I was sending $25 but it turned out to be $0.61! Oops, made a second donations to fix that :)
terry2000 says: Oct 17, 2011. 1:34 AM
I feel this is a place to share with others. And I have enjoyed all that many have been sharing for the good of everyone else. I can not understand why anyone with an attitude of selfish greed is commenting on this site. Apparently this person is a taker not a giver. And that is a shame.
acoleman3 says: Oct 16, 2011. 11:06 PM
im rather impressed at the ingenuity. cheers mate!
Thefrenchlover says: Oct 16, 2011. 11:05 PM
Formidable,
Comme disait Einstein, l'intelligence n'est rien, seule l'imagination compte...
Bravo, superbe idée.
Eric
สชะโลวัฒน์ says: Oct 16, 2011. 10:48 PM
Oh my good!!!! This is a Perfect Idea !!!
mr.incredible says: Oct 12, 2011. 1:52 PM
A lot of soda bottle manufacturers are adding stuff to the PETG now that causes it to break down in sunlight. Some are even not using PETG. They are using a corn based plastic that will disintegrate over time. I don't have any sources for my info but I remember seeing it on one of the tree-hugger TV channels. I actually think it is a good idea to build in the decomposition. Even though I am anti-green. Hopefully that technology will not make it to your part of the world for a while, so you have good long lasting light source.
Monsterguy says: Oct 16, 2011. 8:38 PM
"I am anti-green"
Really? You actually think that looking after the environment is a bad thing?
diy_bloke says: Oct 16, 2011. 6:54 AM
dont have to be a tree-huuger to still be green. Hope for you that you wont need that technology to come to yr part of the world, but in fact it already has, but then called light channels and you pay top dollar for them
nnewdorf says: Oct 14, 2011. 1:55 AM
how can you be "anti-green". like you want to chop down all the trees you see and destroy the environment?
jblanton1 says: Oct 17, 2011. 3:05 PM
How about by chopping down the rainforest in order to BBQ the last of an endangered species... Anti-green enough for you? :)
mr.incredible says: Nov 7, 2011. 10:14 AM
BBQ'd Howler Monkey would be delicious...
liwanag (author) says: Oct 13, 2011. 3:48 AM
Thanks for your feedback. Will publish the FAQ in the website soon. For now we are saying this PET bottle can last more than 5 years. You may have to change the water every 5 years.
In any case, since this is a young project, they can just re-install a new bottle for just under $1 as the cost of the raw materials.
axiesdad says: Oct 16, 2011. 7:12 AM
Great "ible. The idea is the same as the deck prisms used in old time sailing ships, but recycling available materials takes it to a new level. Just out of curiosity, in how many languages are you fluent? I am sadly monolingual and envy those who are not.
keitre says: Oct 16, 2011. 7:07 PM
i am fluent with 2 languages. English and Filipino. Filipino has at least 70 dialects and i speak fluently with 2 vernaculars and understands a bit with another 3 dialects which uses also some similar words as it has evolved. studying it does not need proper education, just learn a word per day.
andrewcaseley says: Oct 15, 2011. 1:11 AM
great idea but would it freeze in winter ? can't work out if it would or not , but at the least would it not act as a heat sink transferring heat outside ?
greatpanda says: Oct 16, 2011. 4:15 PM
*Just* did this research the other day, 50/50 water and methyl alcohol (sold as HEET fuel line antifreeze) will remain clear and have a freezing point of -50F.
Gordyh says: Oct 16, 2011. 8:33 AM
It will freeze in the winter with the water bleach mix if where your at gets freezing temps. Google freezing point of bleach to see if adding more would keep it from freezing, or use vodka instead of water ;-) It's clear and won't freeze to at least -10f, a buddy likes his vodka ice cold and keeps it in the deep freeze all the time.
The thin plastic will offer little to no insulation value and water is a good conductor of heat. So yes this will act as a heat sink if used in a heated area.
bob.the.devil says: Oct 16, 2011. 8:23 AM
if you are installing it in a low temp area you can use alcohol instead of bleach (as the bleach is only for bacteria and algae control) just be careful touching it during the winter as liquids below freezing temperature can be very dangerous (like freezing napalm)
iamargo says: Oct 16, 2011. 8:07 AM
in many countries where corrugated tin are use for roofs bare or never gets to freezing point. those dwelling can feel like ovens in the summer. easily blown-away during typhoon/hurricaine season=== other smart problem solvers - please address low-tech solutions for ventilation and colling as well for these dwellings -- AWESOME ligth by the way -- by the way in the titles art work - means "i litre of light" or illumination....
dpcorpuz says: Oct 21, 2011. 12:02 AM
yes isang litrong liwanag = one liter of light / illumination
diy_bloke says: Oct 16, 2011. 6:51 AM
Add some salt, or clear car antifreeze
camp6ell says: Oct 16, 2011. 6:38 AM
...and if it did transfer heat outside, it would probably be a good thing, considering the (hot) locations in which it would be used.
bbendiksen says: Oct 16, 2011. 6:00 AM
In the tropics, it will not freeze in winter because they dont have winter, So, we can conclude that this solution is not for everybody, It would not work too well in most of USA for instance, in the form they present here from the Philippines. To take your questiion more as: "Can this simple technology work in cold climates?" There is nothing wrong with using a SIMILAR technology, but it wouldn't be quite this low-tech, and it would cost a little more than a dollar or two. Fiber optics for instance springs to mind. If you want to stick to the liquid medium, you could add some anti-freezing agent like you do in the radiator of your car. You would have some energy loss in the dark periods, and during daylight depending on energy input of the sun and temperature difference inside and outside plus the k-value of the bottle+medium, there could be a balancing point where the loss is bigger than the gain. Without looking further into it, I suspect that if you have to worry about such things as freezing water and loss of heat from your house, you are better off with another form of internal lighting. For poor people in hot climates (and not-so-poor people in the same places for that matter, who wants to conserve energy by using this form of daylight indoor lighitng,) it is a great idea! I wish all involved the best of luck! It is better to light a light, than to complain about the darkness.
andrewcaseley says: Oct 16, 2011. 11:56 AM
thank you to everyone for replying on my question .
hoobar says: Oct 16, 2011. 3:05 PM
guys what is the bleach , and where can i get? , and about the selant does the epoxy work? any one reply plz
McNoodle says: Oct 16, 2011. 1:51 PM
I've seen these in Thailand, they're really cool
jmcmurray says: Oct 16, 2011. 11:57 AM
yes cause we all have tin roofs :D
jleighton2 says: Oct 16, 2011. 9:52 AM
How about mixing in glow in the dark paint (phosphorus compounds)? And using a glass bottle since it wont be replaced. with a can on the lower side I could see this lasting indefinitely and directing enough light to read by at night.
in a more useful application, another researcher found pigments and electrolytes together can create a photovoltaic cell from discarded bottles...
eddiedurfee says: Oct 16, 2011. 9:48 AM
Brilliant! And such a simple solution. I don't understand why all you people are turning this into rocket science. (Familiarity breeds contempt I guess.)
0_Nvd_0 says: Oct 16, 2011. 9:42 AM
Regarding the problem of freezing in winters, fill-in the bottle with crushed glass. It will diffract light. Adding pieces of different colors can make the light more interesting. The air trapped between the pieces will act as a heat insulator but glass pieces can still transfer heat.
gomiboy says: Oct 12, 2011. 9:03 AM
I love this idea. Any idea how long the bottle will last with the constant exposure to sunlight and weather? I'm concerned that the plastic will break down and fail.
liwanag (author) says: Oct 13, 2011. 3:51 AM
Thanks for your feedback. We've been told that the bottle and the water inside can last more than 5 years.
After which they can either change the water or just re-install a new bottle for just under $1 (bottle + water + bleach + sealant).
Gordyh says: Oct 16, 2011. 9:17 AM
liwanag,
Have you though of cutting aluminum cans apart (for the shinny inside) to make reflectors out of? This would direct light down away from the roof and rafters, which can absorb much of the light that hits them.
poppet2 says: Oct 16, 2011. 9:06 AM
Just thought of something else. Can bleach be mixed with rubbing alcohol safely? And what would be the proportions to prevent freezing? Could it replace the bleach entirely?
samchamb says: Oct 16, 2011. 7:21 AM
Interesting idea . This is basically an appropriate technology implementation of the light tube type products . I presume that clear corrugated sheet is not available at an affordable price .
Gatecrasher says: Oct 16, 2011. 6:26 AM
Mabuhay Pilipinas!
When I was a Peace Corps volunteer there, I thought this would be a great project after I saw the Brazilian news piece on the Brazilian guy who "invented" this in 2002. Glad to see someone finally decided to make it happen!
blinkyblinky says: Oct 14, 2011. 1:33 PM
This is really cool.
vincent7520 says: Oct 14, 2011. 12:14 PM
Simply BRILLIANT !!!!
Jislizard says: Oct 13, 2011. 8:18 PM
Nice instructable...I have a shed which is crying out for some light.
One question, does the bleach have any optical properties or is it just to stop algae from growing? I know some washing powders have fluorescent chemicals which glow in UV light to make your whites shine brighter and I was wondering if this made any difference.
Thanks
smessud says: Oct 14, 2011. 7:51 AM
Bleach is only for algae control.
Your idea of using additive that collects UV and emits in the visible spectrum is very good. You get added useful light and less UV.
beehard44 says: Oct 14, 2011. 4:47 AM
Good that you guys had the idea to share it with the 'ibles community!
FYI the reason why it is in Filipino is because it's a project in the Philippines
nutsandbolts_64 says: Oct 14, 2011. 4:46 AM
Is this supposed to double as practice for those practicing Filipino? It's just that I find the use of Filipino in an international website somewhat off, although nothing's wrong with it, at the very least.
micraman says: Oct 13, 2011. 11:55 PM
WOW THIS IS SOO COOL! So wait, it works by 'filtering' sun light through the bottle and then lighting up the interior, is that it?
slylee says: Oct 13, 2011. 8:12 PM
Very nice! will be making some very soon
notingkool says: Oct 13, 2011. 8:00 PM
felicitaciones, una exelentisima idea, muy simple y eficaz. Un invento genial.
Espero que en mi pais surjan proyectos asi.
Congratulations, an excellent idea, very simple and effective. A great invention.
I hope that in my country so projects arise.
rsk11584 says: Oct 13, 2011. 5:45 PM
Nice idea had seen this on TV sometime ago,, in news channel, and if am not wrong this will work in daytime only or at night also the charge is there??
ude luz says: Oct 13, 2011. 12:33 PM
saudos a todos,
314 430 79 82
Duitama - Boyacá
calpas-serna says: Oct 13, 2011. 8:20 AM
To answer your question "Randofo", yes. The translation is Tagalog. Quite good translation.
randofo says: Oct 12, 2011. 8:41 AM
This is a good idea. You should include in your intro what exactly this bulb does for people who are not immediately clear... Also, is that translation Tagalog?
liwanag (author) says: Oct 13, 2011. 3:45 AM
Thanks for the feedback! Will include the introduction in a short while.
derte84 says: Oct 13, 2011. 12:55 AM
I love lo-tech solutions
ChrysN says: Oct 12, 2011. 10:08 PM
Nice, simple way to bring light into homes, well done!
aaahotdog says: Oct 12, 2011. 6:41 PM
Very nice, very practical.
bonjo says: Oct 12, 2011. 12:36 PM
My Dear friend I like this idea so much and can see how good this is for people in your country! I was in Davao 18 months ago and i saw in the rural part of the country just how much this is needed, Thank you for posting now i can advise my friends i met there how to cut down their electricity bills. Great job ! Great video !
bertus52x11 says: Oct 12, 2011. 8:20 AM
I like this very much. Good thinking!!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
