The Tagtool is a live performance instrument for drawing and animation. It's similar to a music instrument, only it plugs into a projector instead of the sound system. It is operated collaboratively by an artist drawing the pictures and an animator adding movement to the artwork with a gamepad.
What is a Tagtool Mini?
The Mini is a separate device with the Tagtool controls that is used together with a computer and a graphics tablet. With this setup, you don't have a compact instrument, but it is nonetheless fully functional. This is recommended for people that don't need a dedicated Tagtool but want to use it with their computer and graphics tablet.
What else do I need to run a Tagtool Mini?
To play with a Tagtool Mini you also need a graphics tablet, a gamepad and a Windows PC with the open source software Nodekit which can be downloaded here.
The Tagtool is typically used with a projector, although any monitor will suffice for playing around with it.
How to use the Tagtool
Usually it is controlled by two people - an illustrator (who draws and uses the Tagtool controls) and an animator (using the gamepad to move the drawings around).
The Tagtool controls consist of 6 faders and a pushbutton. The pushbutton releases a drawing so the animator can move them with the gamepad. There are detailed instructions on how to use the controls here..
To find out more about the Tagtool project, visit Tagtool.org.
Remove these ads by
Signing UpStep 1Materials
1 x Arduino Diecimila
Sources are listed on Arduino.cc
Cost: about 25 Euros
Plywood board
The measurements we used:
2 pieces - 26 x 20 x 0.5 cm
2 pieces - 26 x 4 x 0.5 cm
2 pieces - 19 x 4 x 0.5 cm
+ 1 piece for mounting the Arduino
(sized to fit the Arduino)
Any hardware store
Cost: ca. 4 Euros
1x1cm Slats
4 x 16.7 cm
3 x 24.6 cm
1 x 16.4 cm
1 x 2.5 cm
Any hardware store
Cost: ca. 2 Euros
6 Slide Potentiometers
Sliders 10K, 100mm linear mono (or stereo)
Electronics store, eg. Conrad
Cost: about 7 Euros per slider
High quality faders recommended.
6 Slider Knobs
Electronics store
Cost: 1-2 Euros per button
Some screws
3x10mm for the sliders
3x20mm for the wood
Any hardware store
Cost: a few Euros
2 Spacers for the Arduino board
3mm + fitting screws
Any hardware or computer store.
Cost: a few Euros
1 Resistor (for the pushbutton)
10k Ohm
eg. Conrad
Cost: about 2 Euros for 100 pieces
1 Pushbutton
eg. Allen Bradley 800FM-MM44 + 2 Part Contact Block 800F-PX10
RS Components
Cost: 5,40 Euros
A fairly big button. It is used quite heavily so make sure it has a nice feel.
Some stranded wire
eg. Conrad
Cost: 3 Euros
Ribbon cable
min. 6 wires
Any computer store
Cost: 2 Euros
Some acrylic paint
To make it pretty
Tools and materials
Soldering gun, drill, shrink tubes, plyers, stapler...
Send us some details about your arduino - maybe join our social platforms, to keep us up to date.
cheers,
mat
I guess you are talking about the arduino spacers.
We got inspired by the way how motherboards are mounted in a desktop computer. You can buy them in any "well equipped" computer store - just ask for "motherboard spacers & skrews".
OR you can invent your own way to fix the arduino on the right position. Look at this picture i posted: They didn´t use any spacer, but glued the arduino into the box.
at conrad we ordered these ones: http://shop.conrad.at/ce/ProductDetail.html?productcode=978703
Send us pictures, when you are finished!
greetz,
iink
this is the linck:
http://www.seeedstudio.com/depot/seeeduino-v11-fully-assembled-arduino-compatible-p-114.html?zenid=20c2580a93334ef7945de9349e8de789
thank you very much
Looking at the comments below, COOL!
Those videos are awesome.
But adding them to this Instructable would be cool.
Nice job!
Also there's a photo group on Flickr.
http://www.tagtool.org/
