3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a Tagtool Suitcase
What is a Tagtool?
The Tagtool is a live performance instrument for drawing and animation. It's similar to a music instrument, only it plugs into a projector instead of the sound system. It is operated collaboratively by an artist drawing the pictures and an animator adding movement to the artwork with a gamepad.
What is a Tagtool Suitcase?
This version integrates the controls and the drawing area into a flight-case, but still needs an external computer.
What else do I need to run a Tagtool Suitcace?
You need a Windows PC with the open-source software Nodekit which can be downloaded here.
How to use the Tagtool
The Tagtool works best with a projector, although any monitor will suffice for playing around with it. Usually it is controlled by two people - an illustrator (who draws and uses the Tagtool controls) and an animator (using the gamepad to move the drawings around).
The Tagtool controls consist of 6 faders and a pushbutton. The pushbutton releases a drawing so the animator can move them with the gamepad. There are detailed instructions on how to use the controls here.
To find out more about the Tagtool project, visit Tagtool.org.
Step 1Materials
Materials
Graphics tablet
Wacom Intuos3 A4 Oversize
Cost: 535 EUR
This is a good size, but different dimensions should work as well.
This guide assumes that you use an A4 Oversize.
Wacom boards are highly recommended.
Flightcase
eg: from Thomann
Measures according to the schematic - the fourth image (the top panel should be about 63x45cm).
Cost: 80 - 180 EUR
For heavy use a good quality case is recommended.
Plywood board
Measures according to the size of the suitcase.
Any hardware store
Cost: ca. 15 EUR
6 Potentiometers
Sliders 10K, 100mm linear mono (or stereo)
Electronics store, eg. Conrad
Cost: about 7 EUR per slider
High quality faders recommended.
Slider Knobs
2X6
Electronics store
Cost: 1 or 2 EUR per button
Piece of Plywood
Measure according to the Arduino board.
Slat
1,5m x 5cm x 5cm
Any hardware store
Cost: around 5 EUR
Screws
10mm x 3mm, 10mm x 5mm
Any hardware store
Cost: 5 EUR
4 Spacers
3mm + fitting screws
Any hardware or computer store.
Cost: 2 EUR
Arduino
NG plus USB
eg. Segor
other sources are listed on arduino.cc
Cost: under 30 EUR
Resistor
10k
eg. Conrad
Cost: about 2 EUR for 100 pieces
Pushbutton
Mushroom Operator
eg. Allen Bradley 800FM-MM44 + 2 Part Contact Block 800F-PX10
eg. RS Components
Cost: 5,40 EUR
A fairly big button. It is used quite heavily so make sure it has a nice feel.
Stranded wire
5mm
eg. Conrad
Cost: 3 EUR
Ribbon cable
min. 6 wires
Any computer store
Cost: 2 EUR
USB wire Typ A - B
Any computer store
Cost: 5 EUR
Gamepad
eg. Logitech
Cost: 19,50 EUR
Any gamepad with 8 buttons and 2 joysticks.
Wireless gamepads are also fine but we have found them to be less reliable.
Soldering tools and materials
Soldering gun, ribbon cable, shrink tubes, plyers, ...
32 comments
Mar 10, 2009. 10:35 AMbakro says:
hi, im from venezuela. i wanna build a tagtool. i order the arduino, but i wanna order the potentiometers. you know any store in usa with exactly model? thanks
Dec 21, 2008. 1:06 PMtudgeanator says:
Sorry to double post but what type of switch is that mushroom switch? Latching? How many poles and throws does it have?
Dec 22, 2008. 8:21 AMtudgeanator says:
More questions. Can you just use a mouse with the tagtool or do you have to use a graphics tablet?
Dec 22, 2008. 9:29 AMtudgeanator says:
Never mind.
Dec 22, 2008. 8:20 AMtudgeanator says:
No prob.I'm sure you've been more help to me than i have to you.Going to order my stuff for this tonight (except the arduino-i'll have to get that from another site at a different time cos iv'e spent all my money on christmas)
Dec 22, 2008. 5:47 AMtudgeanator says:
Thanks alot!That was a really quick responce!
Dec 22, 2008. 7:52 AMtudgeanator says:
And is that latching? I dont think it is but i'm not sure.
Dec 22, 2008. 7:51 AMtudgeanator says:
Cheers,i've got a couple of those hanging aroun in my bits-box.
Dec 21, 2008. 12:00 PMtudgeanator says:
I can't find that arduino here in the UK, but can find: a)The Arduino Duemilanove b)Arduino Nano Board c)Arduino Pro 3.3v/8MHz d)Arduino Pro Mini 3.3v/8MHz e)Arduino Lilypad f)Arduino Xbee and g)USB/serial converter. Will any of these work and if so how? I'm a complete novice with arduino's and am hoping to do this as my first arduino-based project,any help will be much appreciated.
Dec 22, 2008. 5:48 AMtudgeanator says:
Sorry,but what's a 'patch'?
Oct 14, 2008. 6:12 PMdiegosarl says:
Hi!I`m diego form Argentina, I can´t find the exactly the same model of the arduino here, so, can I use for example the Arduino Diecimila (it`s the lastest evolution) or another USB model??. Another question...I have to connect the drawing panel and the joystick directly to the PC? and, can I use any usb drawing panel and joystick?? thanks! excuse me, my english isn`t very god!
Feb 21, 2008. 7:20 AMcurtisseligson says:
I honestly can't find any information on how to run Nodekit. I've been looking for weeks and can't find any tutorials, how-to's, or even a manual. The Tagtool site just shows off people using it and the developers section does little more than give you the source code. More info on how to use Nodekit would be much appreciated. As for this suitcase, I'll defiantly make one as soon as I can use the software (IOW, thanks for the tut!).
Feb 21, 2008. 1:44 PMcurtisseligson says:
Wow, you guys really are on top of this. Thanks a lot for getting back so quickly. I think I'm gonna' hold out for your next version (March I think he said) as I can see you guys are really working on this. Good luck to you all!
Nov 14, 2007. 11:51 PMgeorg.unterweger says:
hi dasgnu! i have an old grafic tablet at home its an "Medion MD9570 USB PC-Grafikpad" may you know if this work as well or i have to buy this one you told from? thanks for any info!
Oct 24, 2007. 3:23 AMpierlo says:
Nice one! Anyway i tried to link 6 10k potis in parallel as you did with the sliders (but mine are dimmers, the rotatory ones) just as you did here - but only the odd ones work - the even ones output no signal at all! What's the matter? Do you have any clue? thanks!
Oct 25, 2007. 6:35 AMpierlo says:
Thanks for helping, anyway i found out ALL my pots were broken... unbelievable but - well - sadly true.
Sep 3, 2007. 2:14 PMNabil says:
Now I Get It.
[[Video(http://youtube.com/watch?v=7fY_o2hzFaw, {width:425, height:350})]
But for me, neither the video o this instructable by themselves explain the concept, together I got a better aproach...
Aug 27, 2007. 1:20 PMcrapflinger says:
a video of the contraption in use would probably make the concept a little clearer
Aug 27, 2007. 3:01 AMWard_Nox says:
this is cool but im not sure what id use it for
Aug 27, 2007. 3:03 AMWard_Nox says:
though if your rigged a projector to it.....
Aug 26, 2007. 9:42 PMswolleneyes says:
This looks cool, what do the sliders do? what does the big mushroom button do? I saw some videos on tagtool.org but not really sure how the artwork is being "generated" live with this tool. thanks for any info!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:dasgnu
