Remove these ads by
Signing UpStep 1DANGER
Also, I don't take any responsibility for you hurting yourself.
This isn't to say that you shouldn't get into high voltage though, its just that if you are planning for this to be your first HV project, its a little to involved. Instead, try out a nice microwave oven transformer, and be safe!
Which model did you use in your's DevCoder?
Does it change if I am using a toroid, sphere, or semishere?
is this one ok?
(use google translate)
1. The electricians here never heard about NSTransformer or the other transformer you have mentioned, so I have no idea what to buy, I could use some pieces of advice (money doesn't matter). (an easy thing would be an example around the house (like some part of a tv or so..) so I could buy from a tv repairing shop (for example).
2. I can get any capacitors I need but I don't know which type, I got one, just to familiarize me with them, which is a 680 uF (and other details wrote on it like : I (or 1) PRS, eg 7475, +VN 63, and on the last row "1 1978")
3. I have a 8-9cm diameter pvc tube which is 1-1.1m long (coiled).
I would like to know for the first coil too, if the 2nd coil is that which I mentioned upper, how should I build the first one? (how long,, coil..)
how do i turn it on or off?
Thanks for hearing my worry
should I use aluminum tape instead of foil?
Click the photo and if it doesn't get bigger right away click the link with the highest resolution.
Thanks.
