3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a cardboard kayak for less than 40$ (Updated with template)
Step 5Start cutting cardboard like your life depended on it!
We found the trick to getting everything to line up nice, was to use a drywall square (which is optional, but highly recommended) so that each piece was cut square and the seams lined up nice and flush with each other. Also, you want to cut any seams out of the cardboard, so that your sheet is made of only nice, pristine squares of cardboard. We figured the sizes out by just marking out a 6 by 10 rectangle on the floor and then putting our biggest piece down first, and marking the next one by lining it up and marking where the lines of the rectangle on the floor met the cardboard piece we were trimming. you could take the time to measure, but this method worked just fine.
MAKE SURE THE GRAIN IN THE LAYER IS ALL GOING THE SAME WAY! This is crucial, the entire design hinges upon this one element. Cardboard, has a grain direction to it, and each layer must have all the sheets that make it up orientated so that it is all going in the same direction, with each layer having the grain rotated 90 degrees from the one below it.
For a visual break down of the grain orientation of each layer, look at the last few photos. please understand that I did the grain visual break down on a model of each layer, and that in reality, each of your layers will be 6ft by 10ft if you follow my plan to the letter....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:msd8
