3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a cardboard kayak for less than 40$ (Updated with template)
Step 8Weighting, and waiting.....
Weight your cardboard with lots of small, "light" weights. We want each weight to be relatively light so that it does not dent the cardboard, yet heavy enough so that it weighs the cardboard down. We brew our own beer, so we had alot of bottles on hand, so my brother filled them with water, caped them (because a spill would mean the end of our kayak at this point) and we laid them on the sheet. We found that the seams, where two sheets of cardboard would meet, were the most troublesome spots. They seemed to want to warp up for some reason, so this is where we put most of the bottles. If you don't have 140 bottles kicking around, or a capper, just go to the local dump or transfer or recycling center and get alot of soda bottles, and use those instead. Also, you could use books, placed in bags, plastic or paper, does not matter, just helps keep the books from getting glue on them. Or fill sandwich bags with sand, any small weights that you can think of, that you have a lot of.
Leave each layer to dry overnight, and then cut a new layer (with the grain going 90degrees different from the previous layer) and repeat until you have a sheet that is four layers thick. since i highly recommend using double layered cardboard, it's technically 8 layers thick, but whatever. the point is make it beefy, you don't want to be putting your foot through the bottom of your kayak cause you were lazy and only did a few layers......
7 comments
Sep 4, 2009. 1:05 PMfresnelman90 says:
140 bottles of beer on the kayak, 140 bottles of beer!!
Sep 3, 2009. 9:37 AMjujitsu-mam says:
In step #7, I think is much better if you use books instead of bottles. Many people has a lot of books at home, but bottles...
Tell me if i'm wrong, maybe I miss something u
Sep 3, 2009. 10:20 AMdgrundel says:
That's exactly what I was going to say. Books are an excellent option, because they are heavy but because the weight is distributed over a large surface area, they usually don't dent the card board. Another good option would be to put a sheet of plywood or similar over top and then weight it with anything you want. The plywood will do the weight distribution work. Pretty much anything with a large surface area would be good. :)
Sep 3, 2009. 3:18 PMkissiltur says:
I think the answer is books... in bags! Put them in carrier bags, no worries on adding extra glue to the covers of your heirloom Pratchett collection. The bonus is you have handles to lift the books off again, rather than risking dinting the cardboard when you pry them off. You must have really dried the bottles before you put them on the cardboard. That's a step I would worry about. Glorious idea and instructions, though. Thank you.
Sep 4, 2009. 11:01 AMjujitsu-mam says:
Hehehe, I think the same. The bags are a little but useful detail!
Sep 3, 2009. 8:56 AMRustyOlive says:
I think I'd have a slight problem with this step.... hahahahahaha
Sep 3, 2009. 8:26 AMsp33dstix says:
Love the weights you use
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:msd8
