loading
loading
Picture of How to Build a Cargo Cycle Truck
I was inspired by this bike which is much more beautiful than the one I built. I built the bike in Haiti, with a minimum number of tools and ingredients. I would have posted this a couple months ago, but was delayed because as I was taping the stencil on the frame, Haiti was struck by 7.3 magnitude earthquake. Costs for this bike were $25 for the bike, about $10 for steel, and $5 for welding rods. With the seat tube change the frame is 17'' tall, I'm 6'2'' and it's not uncomfortable to ride and a friend who is about 5'6'' took a 20 mile ride on it recently and fared okay.
Step 1: Buy a bike
Picture of buy a bike
Find an old 20-inch BMX bike.  I bought one on the street in Port Au Prince for $25 (I think I paid twice as much as it was worth). Try to find a bike that already has good brakes. My bike has a coaster brake in the back and cheap caliper brakes up front.
Step 2: Start building
Picture of start building
Find or buy tubing to build the cargo rack. I used ¾ inch x 1/16 square tubing.  I bought 20' of it for $7.50, I ended up using about 25'.
Remove the cranks. Cut out the seat tube in order to weld it on top of the frame to extend the seat tube so that the bike will fit a whole person.
Step 3: Extend the seat tube
Picture of extend the seat tube
Cut a 12'' long piece of square tubing and slide it through the top tube down to the bottom bracket. Then slide the seat tube onto this piece.
Step 4: Seat tube gusset and main rack supports
Picture of seat tube gusset and main rack supports
Cut a diagonal gusset that goes from the seat tube to the top tube in order to reinforce the seat tube.
Cut two pieces of square tubing to 56'' then clamp them to the sides of the bike frame.
Step 5: Weld
Picture of weld
a simple 80 amp arc welder is enough for the job, I used 55-75 amps for this project. My father in law takes a turn (yes we do not have proper safety protection, yes we both got sunburned from welding this, since then I got a full face welding mask).
weldyrack4 months ago
This was just the sort of bike I was looking for! I joined this site, partly for help, and partly to comment on your build. Very practical, simple and helpful. I've found a frame and forks on EBay for £12, which I've ordered. I hope to make mine electric, due to my age! If you see the Lorri, Biba, Donky and ODK bikes, you know you have done the right thing. Compact, with the weight down low. Well done.
buddytym9 months ago
Beautiful build. I love that you used parts and tools that are available around the world, and are not too income restricted. Little bike trucks like these solve so many issues all over the globe. Thanks for sharing!
NHRider2 years ago
Great Job, turned out well.
bertus52x115 years ago
 Nice concept! Would use a larger frame though!
@ bertus52x11 -- I like the idea of the smaller frame; it makes mounting/dismounting MUCH easier. I currently use an extra-large framed Raleigh MT 20 like it's a large parcel truck and I have a heck of a time getting on/off when it is fully loaded. I have to lean the bike and sometimes spill my cargo.
@depp.ben -- Have you thought about also raising the handlebars? From the pictures, I imagine you kinda leaned forward. Is this an issue? Other than that I LOVE this instructable!!!! I'm gonna start hacking my daughter's 20" bike as soon as she outgrows it! Thanks so much!!
What is the maximum/optimal/useful load?
What are the difficulties when driving (shimmy...)?
depp.ben (author) 5 years ago
The frame size isn't bad, with the seat tube extended like it is it's a 17'' frame. The handle bars can be adjusted forward. Ideally I would build different handlebars with more sweep.
