3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a dog house w/ air conditioning
This is my first instructable!  yee haa!
This instructable will detail the dog house I built this summer.  This dog house was built for two itty bitty fragile dogs as a safe haven from the bigger dogs and features:
-an air conditioner
-electrical outlet
-exterior conduit electrical
-large "people" access doors
-small "doggy" window and door
-treated lumber stilt foundation (no termites allowed)
"Rough" (some say lazy I say rough and efficient) construction methods were utilized, but dog house is durable and easily supports myself (190lbs).
Step 1Designing and costing
The first step was designing the dog house.  The dogs using this house are very small so the major factor in this design was my size.  This dog house is about as small as possible while allowing space for me to get inside and perform maintenance (filter changing, clean up, dog beds, etc.) or hide.  These design sketches have pretty minimal dimensioning and consist of random presentation views, so they should be easy to tweek.  If planning on going much larger, stilt (column) supports should be added in grid-like layout at least every 6ft in length and width directions.
Also included in this step was my cost analysis.  This dog house cost about $300 (including the air conditioner) and 3 gray hairs.
24 comments
Sep 3, 2010. 12:41 PMtedcapote says:
Good for you doggy you've just got an air conditioning system on your house lol
Nov 13, 2009. 5:24 PMshooby says:
Air conditioning??? Come on, it's a dog.  The passive cooling effects of a shaded space is really enough.  If not, then a quick shave would settle the difference.
Jun 30, 2010. 3:53 AMknotmedude says:
NEVER shave a dog. Their coats protect them from the heat, naturally. Make sure they are brushed to get the loose hair, but never shave them.
Dec 20, 2009. 8:10 PMconrad2468 says:
some people love their dogs....
Dec 9, 2009. 9:00 AMmrcrumley says:
GO HOME, CAT LOVER!
Mar 29, 2010. 2:35 AMwarzhammerz says:
 A good idea would be to have a detachable roof so you can maintain it easier.
It could slide in some how!
Jan 23, 2010. 8:08 PMSGT FISHER says:
my dogs(5) have a 3x3x6 "dog house" with ac also, which BTW is keep in the garage, with their 4x8x1 foot deep hay bed, in the winter we use brood lamps for heat, much safer than heat lamps they can get very very hot, to the point of igniting wood! be carefull. we try to keep teh lamps above there heads when standing, so  they cant burn themselves, gotta take care of teh pups! great job!
Jan 8, 2010. 12:18 PMrwhorton says:
I also had a heat lamp setup for my dogs.... one of them knocked it down, it burned the doghouse, my yard (as well as three other neighbors yards) broke the kitchen windows (it was on the back porch next to the house) and caused minor smoke damage in my home.
Be careful of heat lamps!!!!!
Dec 4, 2009. 7:14 PMevix says:
Just laying the PVC on the ground...   tsk tsk
Go to home depot, get a romex connector and a gfci.
Switch the plug for the gfi, and hard wire the ac to the 'load' side.
but hide the cord in some pvc or flex tube... Its your dog.
His safety should come before... AIR CONDITIONING! lol
Nov 28, 2009. 3:55 AMSquash says:
Nothing really to do with this type of dog house but just a note.  I did not think of this before I started working with animals but you should NOT put blankets, foam, padding, etc., in an outdoor dog house during the winter.  Some cities, it is actually illegal to use things such as this in outdoor dog beds.  What happens is that they get wet, refreeze, then all the dog has is a frozen bed to lay on which means frostbite.  Please pass this on to any friends/family who use these items.  Straw and straw bales is best for insulation and a warm bed.  Also, thank you to everyone who adopts and saves an animal from a shelter!
Nov 1, 2009. 2:16 PMYerboogieman says:
We build a dog house for my Doberman Ely. We had a heat lamp, a foam pad and a few blankets in there for him. At first he didn't like it so he would drag the stuff out side and sleep on it. The reason we had him in a dog house is he couldn't get up the stairs anymore. 13 is pretty old for a doberman. Everybody but people in uniform he liked for some reason..
Nov 1, 2009. 2:53 PMbrandon borick says:
your call a $300 vet bill
or a .05 cent 22 round
your call
Nov 1, 2009. 3:06 PMYerboogieman says:
We used a .30-06 for a blind cat. But he died while i was in Vegas of natural causes and my dad called me about him. He died at 3:21am on a wednesday on the 14th of august. Softest floppy ears you would ever feel.
Nov 1, 2009. 9:21 PMbrandon borick says:
dam that would vaporizes it
Oct 31, 2009. 9:51 AMdevious69 says:
I did something similar a few years ago.  I used 1.5" Styrofoam sheets for insulation.  I also used a thermoelectric A/C unit to keep power costs down.  That unit had no internal thermostat so I had to improvise using a Honeywell T775 thermocouple.
www.flickr.com/photos/bkirk1969/sets/72157601506871790/
Oct 31, 2009. 11:39 AMlunchboxslayer27 says:
a chilly 79 degrees? that seems quite warm
Oct 31, 2009. 7:07 PMdevious69 says:
You bet it is.  HOWEVER, when it's 110 outside, 79 is is very refreshing, especially under the internal fan - that's a 31 degree difference.  The pug knows, he spends all day in there.  We only keep our home AC at 76 during days in the summer but that's mainly a power thing.  If the thermoelectric AC could do more than 30 degrees differnetial I'd set it lower, but a 30 degree differential keeps the AC running all day.  I may try to upgrade the peltier element this spring to a higher wattage unit to get a little more out of it.
Oct 30, 2009. 5:13 PMiPodGuy says:
If you are running AC in it, wouldn't you want to insulate it as well?
Oct 31, 2009. 8:07 AMmarinermcv says:
Cool Dog (sic) wheres the Dogs flatscreen TV ?
Oct 30, 2009. 7:08 PMled235 says:
 THIS IS COOL!!!!
IS THAT AN IPHONE I SEE IN THE PIC FOR STEP 9!?!!?!?!?
ONCE AGAIN, GREAT STUFF!!!
Oct 30, 2009. 9:07 PMBartboy says:
Basically the same for heating....
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:dirtyseaotter
former engineer going back to school
