Step 15Next Steps
Except for the siding. Oh, and the fascia. And the soffits. Not to mention any trim you want to add. And if you want to do any work or have lights you will need to do the electrical installation which requires a completely different permit and series of inspections. After all that you can then insulate and finish the interior.
The good news for me is that you have now built or at least have an idea of how to build a garage from the ground up, which is the limit of my involvement. Good luck with the rest of it. The electrical is the only real challenge. Keep your eyes peeled for another Instructable detailing the electrical process. But don't hold your breath.
The photos below show the completed project from the front, back, and a show of the interior in all its messy glory. In the corner by the windows is a built-in workbench that may be the subject of a future Instructable, it is sturdy as a tank and cost about $10 to build out of scrap lumber.
Thanks to all my friends and family who helped throughout the garage project. I could have done it without you, but it would have sucked a lot. And would probably have fallen over on my head. Twice. Thanks also to the patient inspectors who answered my questions and put up with our shenanigans.
Thanks
Maybe I should write that process up...
Yes I'd like to see any additional work you've done.
I'm planning the same sort of garage thing, but I want to insulate the roof and walls. We get no ice here in So Cal, but it gets roasting hot in the summer. I have been told to make sure to use a moisture barrier and weep screens at the bottom of the walls to avoid mold problems.
On another note, was there a reason you chose this type of roof construction over what is called Type 5 which has a central beam and provides more open rafter space?
I'm in the research phase, I'm right on the fence between trying to build one myself and just buying a Tuff-Shed brand garage as I don't have a bunch of framing experience.
Thanks again
Using the moisture wrap and screens are a good idea, I just didn't feel it was needed on our install. Time will tell, and at least I know where to find the builder for rework.
I chose this type of roof construction because of low cost, ease of build and permit approval. Getting a plan approved and passing inspection is easy with pre-fabbed trusses but takes a lot more work on a hand built roof as you describe. I just didn't have the confidence in getting a ridge beam hoisted 20+ feet in the air. Those LVL beams are heavy as heck, and getting them in position at the peak would require a crane that I did not have or desire to rent. An attic with more storage room is possible with that type of roof, but I am able to store a fair amount of stuff in the trusswork so I can't complain. The main reason I would go that route would be to allow an insulated ceiling in the main garage room, and a separate attic with access hatch/ladder. That would allow the garage to be cooler in summer and warmer in winter. However, the attic would be hot as all hell and limit what you could store up there.
Framing is pretty easy if you can measure and mark wood, make consistent square cuts to length within 1/8" of desired, have access to a pneumatic framing nailer, and if you have fairly straight lumber. Sizing and design of the door and window openings and headers can be an area where experience is helpful. That said, building it yourself is more fun than a Tuff-Shed any day, at least once you are finished.
Do you have an idea how much it would cost to build a commercial lube shop? Let's say 3 bays, 1 waiting area, 1 restroom, 1 office and 1 break room?
I think I could really use your help as much as possible. If you think you could help, e-mail me at nyotasandja@hotmail.com
Thanks a lot!
To answer your questions, I don't know how much it would cost, I don't think you can do it yourself, and thanks for reading.
-Jon
