Introduction: How to Build a K'nex "Titan"
Picture of How to Build a K'nex "Titan"
While sitting at home and staring at my piles of pieces I had the idea of building a humanoid creature out of K'nex. After many trials I succeeded in producing my first hominid, Zyrael (the smaller one). After the build was done I looked for others to compare with my building style and found none.
I have decided to share my building stratagies with others so others can build their own Titans.  The tallest titan I've built so far is about six feet tall, and they can be complicated.
In this instructable I will outline strategies that have worked well for me.
Step 1: Planning
Picture of Planning
Before you start you should consider your goals.  There are some important stability issues in the design:
Taller = less stable
More joints = less stable
Few peices = pops apart often
Too many peices = collapses under its own weight
(Three to four feet is the heighest that a Titan of mine has supported its weight unaided.)
There are several things that vary from one design to another, such as the number and placement of joints, the thickness and legnth of the limbs, and the overall look of the titan.
Step 2: The Torso
Picture of The Torso
The torso usually defines the look of a Titan.  It should be light but strong (the legs will have to support all this weight) and the torso size in relation to the arms and legs can change the look from apelike to humanlike
I use geometric structures to increase the strength and keep the weight low. I have considered including a mass damper in the torso, but haven't tried it.
Step 3: Arms and Legs
Picture of Arms and Legs
The larger the size of the titan, the thicker the legs need to be. The arms to not follow this rule, and need to be light.
The length of the limbs should be proportional to the torso.
Step 4: Joints
Picture of Joints
The reason that Titans can move like people is beecause their joints mimic a person's.
the simple hinge joint is triangular and allows the the piece on the bottom to rotate freely.
 For the knee joint of my larger titan i needed something more durable. I created a sliding/ rotating joint.  Please see the picture.
Step 5: Thats It
Picture of Thats It
With these skills and techniques you can build your own Titan, possibly to be bigger than yourself.  Use some creative talent and try to create your own designs.
I would appreciate an instructable for any innovative design improvements that anyone comes up with.
Now hop off the computer and build a Titan!
*As an added bonus I included a hand design.
novalord742 (author)2010-12-02
@TigerNod:
Zyrael is the name of the titan, and yes it is based off hebrew
TigerNod (author)novalord7422010-12-02
Allright, cool. Does it mean anything, or is it just a normal name?
novalord742 (author)TigerNod2010-12-07
it's just a cool sounding name i created by combining "Z", similar to Omega in greek as the final letter, "Tyr" from Tyrant, and adding "ael" to show that this titan is of good alignment.
Some serious thought goes into the names I invent.
TigerNod (author)novalord7422010-12-10
Cool. I'll remember that.
Btw, I subscribed to you.
RMConstruction (author)2010-09-06
Interesting build... That would make a nice target!
TigerNod (author)RMConstruction2010-12-02
A nice target? No way, it's way too good to be shot at. This is a very interesting humanoid?
RMConstruction (author)TigerNod2010-12-02
True, but it would have its uses pushed as a target.
True. But personally, I'd choose something less complicated and easier to build for my daily target practice.
900TH COMMENT! And true, this is a little 'holey'.
TigerNod (author)2010-12-02
Very nice. Maybe I'll build this sooner or later.
What is that 'Zyrael' in the description? It sounds Hebrewic.
~KGB~ (author)2010-08-25
nixe
About This Instructable
1,129views
0favorites
License:
More by novalord742:How to build a k'nex "Titan"
Add instructable to:
