Introduction: How-to Build a Planter Stand From Scrap Wood & an Old Rim...
Picture of How-to Build a Planter Stand From Scrap Wood & an Old Rim...
He is a project that utilizes an old wheel rim & scrap pressure treated wood from building a deck...  I'll show you the steps involved in building the stand that the planter is sitting on...
Step 1:
Picture of
What we have here is some scrap treated decking lumber & an old steel rim from a car...
Step 2:
Picture of
First we sand the areas that the wood will actually contact the rim, with a coarse sandpaper... Then give the rim a good wipe with a rag to remove any sanding dust... (Tip #1 - You should start the job with wiping down the areas that you'll be sanding with a wax & grease remover...)
Step 3:
Picture of
You can see the narrow strips that have been sanded... I then apply PL400 construction adhesive to bond the first piece of wood... (It's not mandatory to use PL400, just choose a quality construction adhesive that is suitable for the materials being used...)
Step 4:
Picture of
After cutting the board to length to fit inside the rim, I then cut it half to help fit the contour of the rim... I then press down firmly into the adhesive...
Step 5:
Picture of
I continue with the PL400 and I place the cut ends together to keep a uniform look around the rim...
Step 6:
Picture of
The next plank is done the same way and you will see that I'm putting the rounded factory edges together...
Step 7:
Picture of
After I get just past the halfway point, I take an inexpensive cargo strap and tighten against the wood pieces... I set this rim aside, and let it harden overnight...
Step 8:
Picture of
The next day I undo the strap and finish filling the rim with wood pieces... Once again I put the strap on and set it aside to harden overnight (or whatever the instructions for the adhesive tell me to...) On this particularly sized rim I needed to add a 1" size strip to finish it off...
Step 9:
Picture of
You will end up with a rim like this... I apologize for not having pics of the top, but what I did was to cut a piece of old paneling to be used as a template to cut the top boards... Once done, you lay out (3) boards, put the template on top, draw around it with a pencil, and remove your template... You then take your (3) boards and cut along the pencil line with a jigsaw... What you're left with are boards that fit the contours of the rim... (Tip # 2 - The part of the centre of the rim that is closest to the outside of the rim, is the side that these boards are attached to...) Follow the procedure described above to prep this area of the rim for bonding the boards to it...
Step 10:
Picture of
This is the finished job with (2) coats of stain applied... (Note that I drilled a hole in the centre of the top to allow for drainage of the planter itself...)
Step 11:
Picture of
This is just showing you the finished product beside what I started with...
Step 12:
Picture of
This shows the planter stand and its intended use...
Step 13:
Picture of
The old address sign was then re-done to compliment the new planter stands...
I hope you enjoy building your own planter stand, it's a fun and fairly easy project & looks great when it's all done...
putternut (author)2013-06-23
Wow, this is a planter stand that looks like it will hold up, ingenious! Thank you!
Beast Lee (author)putternut2013-06-23
Thanks putternut, and you're correct it will really hold up...!!!
redfoxtrystman (author)2013-06-22
Love it thank you
Beast Lee (author)redfoxtrystman2013-06-22
You are most welcome... It's a fun little project...!
About This Instructable
5,495views
36favorites
License:
More by Beast Lee:How-to build a planter stand from scrap wood & an old rim...
Add instructable to:
