3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a rain water collector
In this instructable, I will show how I made a rainwater collection system to water my garden. This helps to conserve water and make good use of a free and renewable resource.
Note that this involves using many different tools and proper safety precautions should always be taken.
Step 1The beginning - installing the posts
To begin, I laid out a 55 gallon drum on the ground and dug a hole on either side in the spot that the poles (4x4 pressure treated lumber posts) were going to go.
239 comments
1-40 of 239next »
Mar 26, 2012. 10:51 AMDanCrocker says:
Maybe reduce the angle a bit? You wouldn't need much to ensure a flow to the front. Just a few degrees.
Mar 26, 2012. 10:41 AMDanCrocker says:
Something like this LobosSolos?
Mar 26, 2012. 10:32 AMDanCrocker says:
Again, not meaning to be critical here but I think I would have used nuts and bolts with large washers to distribute the load instead of lag bolts - which would have a tendency to sag over time given the weight. But then, I am no engineer. ;p)
Mar 26, 2012. 10:29 AMDanCrocker says:
Hadn't thought of that. Good idea.
Mar 26, 2012. 10:27 AMDanCrocker says:
An alternative to using lag bolts would be to drill all the way through the post and use nuts and bolts with large washers under the bolt head and nut. These could be tightened as needed as the wood ages.
Jul 3, 2011. 10:01 AMZaryn says:
Why two pieces of 2x4 instead of one piece of 4x4?
Jan 5, 2012. 7:01 PMFoehammer358 says:
It's quite a common trick. 4x4s are much more expensive than 2x4s, and 2x4s are more common. In this case it might be to sandwich something in between them.
Sep 4, 2011. 12:43 AMsunshiine says:
You really spent some time on this ible! Thanks so much for sharing your hard work!
Jun 3, 2009. 4:47 AMHandsome-Ryan says:
Are you not concerned with algae growing in the clear tubing?
Jul 1, 2009. 12:32 PMyoshhash says:
woah- why is this particularly an issue with clear tubing? I have a greywater system with some clear tubing, this did not occur to me either. I bought it only because that was all they had at the store I went to. Yes, very nice instructable. I really like how you tipped the barrels to take advantage of the built in threading- this is a particularly sore point with me, I would love to see an instructable on how to install leakproof spigots on a curved surface. I have a method, which I will soon be posting, but I'm still waiting to see if it holds- want to see what others have been trying.
Apr 22, 2010. 10:59 PMPaladin says:
 Yeah, maybe go with the black poly tubing instead. Excellent instructable though!
Jun 16, 2011. 4:12 PMmjtc98 says:
Or 'retrofit' your clear tubing with a little paint :)
Jun 16, 2011. 6:29 PMPaladin says:
Nice idea, but not too many paints will stick to the clear tubing and remain flexible. The black poly pipe is cheap.
Feb 5, 2009. 8:25 PMDiscojess says:
This is amazing. I've been planning to put a system in, this one is very attractive. I was also wondering about the air hole situation, so, as you have it, the air I'm assuming just escapes through the gutter? Also, if you drilled a hole in the top of the bottom barrel, would it then squirt out of that hole once the top barrel starts to fill, since the pressure will be coming from higher than the hole? maybe some kind of a hose that goes from the air hole to above the highest barrel... this is awesome.
May 19, 2011. 1:22 PMjeffeb3 says:
Upright barrels is a good idea. Keep in mind, that no matter what the shape of the container, the final pressure of a gravity powered tank is proportional to the depth, assuming no resistance in that hose. So a vertical system could possibly be much more pressure.
For your implementation, you can just add a hose from the top-back of the bottom barrel to any place in the top barrel (it doesn't have to be in the upper bucket air pocket). This will serve two purposes 1) allow water to fill in the upper part of the bottom barrel; 2) increase the amount of flow from the top barrel to the bottom.
Great instructible, I know it's old. I'd be interested in you updating it with a follow up.
I plan to buy a couple barrels, and then convince my wife to let me do something like this.
May 10, 2011. 10:00 AMtarchambault says:
I stumbled upon this project a few weeks back, and since then i have convinced the garden club and my children's school to install this in our community garden.
We had the barrels donated to the school and plan on getting it built within the next week!
This is just such an excellent idea! Thank you for sharing it!
Mar 16, 2011. 8:06 AMtyoungman says:
just wondered why you angled the barrels. what little water you gain on one end you loose on the back
Mar 12, 2011. 3:09 PMgarden goddess says:
Pretty neat construction project! Our system is simpler compared to that...it works really well for our layout.
Jan 7, 2011. 12:44 AMmikesnyd says:
awe come on man.. where is the gutter and debris gaurd on this small roof lmao. great little build man!!
Jan 7, 2011. 12:40 AMmikesnyd says:
maybe not a decoration but maybe a sealer could be used on the roof of yours. unless it all is already treated wood.
Sep 11, 2009. 5:08 PMplumber4 says:
Here is a tip that was suggested to me years ago while installing a wood fence around our garden. I found it very useful. Try digging smaller diameter holes and using pea gravel instead of cement. The pea gravel is a bit more expensive (which is why i suggest using smaller holes, you use less gravel). but has a few advantages over cement. 1. Better drainage - this also means longer life of the wood posts. Place a few inches of gravel in the bottom of the post hole. This allows for better water drainage. Your posts will take much longer to rot and will likely outlast the structure above ground. 2. Strong yet easily removed - Posts that are set in pea gravel can be removed without digging and with little effort. Posts that are cemented in are pretty much permanent or at least very difficult to remove. If you decide to move, you can easily take your water harvesting system with you. 3. Less work - mixing cement can be a lot of effort. If you are not not familiar with mixing, it can be very difficult to get the desired mix. 4. Time saving - The time saved by using gravel is well worth the few extra bucks that you may spend on gravel. Also, you do not spend any time cleaning up the cement mess. After getting your post true, fill the hole around it with a few inches of pea gravel at a time. Pack the gravel down with whatever you have (i use a small section of thin lumber or a 2x4. Keep doing this until you are a few inches from the top of the hole. Then use earth to fill in the rest. Tamp the earth down and its set. This ends up looking better than cement as well. Of course always be sure to dig your post holes far enough past the frost line. In Lower Michigan, 42" is the depth to dig to.
Jan 7, 2011. 12:28 AMmikesnyd says:
I never thought of using pea gravel as the base before. I like it. I would do one thing a little different. I do some fiberglassing and usually have a bit of polyester resin laying around so its nothing to me to soak the ends of my posts with a quick coat of resin. No fiberglass needed. Once soaked they don't absorb moisture. And man does your wood last.
I have never in my life dug a hole more then 36" and never had a problem... but thats for decking and such. I usually only have done 24" and use concrete. For a fence being more linear (unlike the box we are making here) and having to deal with mother natures winds 42" would be cool for the pea gravel method.
Apr 23, 2010. 12:29 AMLobosSolos says:
You can also put the concrete in dry.  As it rains it sets up and you don't have the issue of the concrete pulling away from the post as it cures.
May 26, 2010. 3:49 PMbecca-boo says:
Technically, water is not a renewable resource. Water is not created (like trees and other renewable resources) but recycled. But Im just busting your chops, this thing is amazing! My dad was looking for a way to create his own rain barrels and this is just the thing! However, i must agree with Donron, It seems there is no way for the air to escape once the barrels begin to fill with water. (of course it is very possible i missed a step where you mention to drill an air escape hole or the barrels are already equipped with such a hole) None the less, this idea was brilliant.
Dec 3, 2010. 2:32 PMwmcross123 says:
Where do you get the barrels?
Aug 20, 2010. 8:09 PMBeeRich says:
Actually, water enters and leaves cellular systems all the time. I like this project.
May 27, 2010. 12:56 PMbecca-boo says:
 Oh, I see. ha ha. I guess I did miss that step.
May 3, 2010. 7:26 AMdonron says:
 hello.i think that your barrels will never be full of water.this is because you didnt put them horizontally.in the upper part of the barrel there is no way of air going out and it will just stay there decreasing the water holding capabilities of your barrels.if you put them in the same way but with the openings of the tubing in the upper side they get filled properly.
Apr 29, 2010. 7:34 PMmarkallan says:
Are you sure the stand-ends will hold the weight of the barrel onces they are filled with water?
Thanks.
Mark
Apr 26, 2010. 8:15 PMjeveda12 says:
hey you getting your barrel only half way full, you should load the watter from the back.  rigth?
just a sugestion . i will do my like that.
thanks
Apr 25, 2010. 4:05 PMginamarina says:
wouldn't you still want a diverter on this in case the barrels fill? Otherwise where will the excess water go?
1-40 of 239next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
129
Author:iPodGuy
Just your average handyman.
