3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a river raft frame
Step 7Putting the frame together
You have now made all your pipe cuts and you are ready to start connecting your rails, fittings, and cross bars.
Slide how many fittings you plan on using onto each rail. Lay the rail on a flat surface and estimate where you'll want your fittings and then tighten the hex screw.
When one rail is complete do the exact same thing with the other rail. It helps to line up the second rail next to the completed rail. Tighten the hex screw in each fitting.
Make sure the fittngs are tightened on a flat surface to ensure the cross bars will line up with each other.
Now separate the two rails and insert the cross bars into the QuickFit clamps. Once all the cross bars are in place go back and tighten the hex screw.
You now have a raft frame. You can measure your cooler and or dry box to determine where the cross bars need to be located. I usually at this point crab the cooler or dry box and adjust the bars based on the actual fit of the cross bar. Make sure you leave just enough room to get a strap between the cooler/dry box and the cross bar.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dlskayak
