Step 9Oar mount options
Now you need to decide what type of oar mount sytem you want to go with. You can go with an oar lock or a pin and clip system.
Pros vs. Cons of Open Oarlocks:
Pros: Oars slide easily up and back down the oarlock when pulling oar in to avoid obstacles. Easy to re-position mid-rapid if "popped out" of oarlock. Ability to feather blade (when not using oar rights).
Cons: More expensive. Oar can be completely released from oarlock if enough force is applied. Has more "play" which can be noisy.
Pros vs. Cons of Pin and Clips:
Pros: Holds oar and blade very securely. Less expensive. Hard to lose oar if oar stirrup is used. Quiet System.
Cons: Oars can be difficult to pull in when approaching obstacles. Hose clamps can damage oar shaft. Feathering blade is not possible.
Add Comment
