3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a simple Plasma Rifle aka Electrothermal Rifle
In this Instructable we will show you how to build a simple electrothermal rifle that can shoot bbs using the plasma burst from a capacitive discharge. This design is easily scalable. If you use a higher voltage or larger capacity power supply you will be able to fire the projectile faster. Using only 1 camera as a power supply will launch the bb out at very low velocities. This project uses high voltages and can shoots bbs at dangerously high speeds. We take no responsibility for damages caused by this project. Check out our other inventions and projects at our site WillCorp .
Here is a video of our high power plasma rifle in action
Step 1Constructing the plasma rifle
We'll show you how to build a small low powered plasma rifle using only common everyday items like a disposable camera for the power supply.. The rifle uses pressure produced by the several thousand degree plasma produced by a capacitive discharge to launch a projectile across the room. It transforms electrical energy into kinetic without any motors, gases, explosives or anything else. A great way to amaze your friends. Or have a mini war. Warning high voltages required for the capacitor bank may cause shock.
Simply watch the embedded video for instructions
74 comments
1-40 of 74next »
May 26, 2012. 11:45 AMkingofthespazs says:
can some oe tell me what the compasitor looks like how to discharge the current to the steel wool and how to insulant it would liquid rubber work
im still a newbie to wire a i keep getting burn wounds
Sep 6, 2009. 10:34 AMTheDoci says:
I trid to bould a bit mor powerful version of that and it dosent work it discharges the 200 µF 330V caps but it dosent vaporiz the steal wool. can you pleas help me? Its a cool project!!! But it dosent work for me :( it just dosent work so pleas help me!!!!!!!!!!!!
Oct 19, 2011. 3:26 PMhajaslan says:
if i was you i would put a bit of flashh cotton infront of the wool so wen the wool heats up it ignites the flash cotton and that becomes your actual propoltation or watever u wana call it.. lol
Oct 2, 2009. 8:10 AMmattinator16 says:
try using aluminum.
Sep 26, 2010. 4:23 PMHightechk says:
or uranium/ plutonium lol
kidding
Feb 5, 2012. 3:09 PMluig says:
actually that sounds like a great idea, both metals are chemically very reactive, however they are toxic and unless u have plans to poison the area u fire in, dont use it but still a good idea for extremes.
Aug 20, 2011. 3:27 PMmushroomhunter says:
If you used Uranium-233, which can be extracted from vaseline glass, the pellet would not only fire at 2000-3000 FPS, but it would explode on contact. please kids, don't try this at home.
Jun 6, 2011. 6:28 AMPyro Fiend says:
I don't say a video.
Sep 23, 2009. 1:04 PMimshanedulong says:
Does the steel wool stay so it can be reused?
Dec 30, 2010. 7:27 PMmetrogdor22 says:
Sorry, no. Once you burn steel wool, you can't do it again. You can do the same thing by touching a 9v battery to steel wool, except here, it's expelled outwards.
Jun 27, 2010. 12:11 AMGSXRPARTNEEDER says:
clean your work area!!!
Sep 3, 2009. 7:00 AMfirefighter1333 says:
500/ 600 FPS???!!! IM SOOOOOOOO GOING TO MAKE THIS IN RIFLE SHAPE!!!
Sep 3, 2009. 7:01 AMfirefighter1333 says:
or pistol...!
Aug 15, 2009. 7:54 PMCrail says:
so... What do I do if I can't understand anything in the video?
Aug 6, 2009. 10:46 AMpyrotech25 says:
awsome.
Jul 23, 2009. 8:00 AMGamer917 says:
i really want to make one of these and put it inside a halo plasma pistol toy and the switch to fire the bb would be in the trigger of the gun
Jun 23, 2009. 7:20 AMkjjohn says:
how far would this shoot with a 940uf 400volt capacitor bank (75J of energy)? I am using a shaped projectile (iron rod modified into a bullet)
May 7, 2009. 8:59 PMraedonchar says:
I'm planning on using this as a step in my Rube Goldberg machine for a class project. Would it be possible to charge a 160v, 220uf capacitor by plugging it into an outlet (or would I need to build a charger circuit) and then using that to short the steel wool? All I really need it to do is knock over a contained domino.
Jun 22, 2009. 11:08 PMmad magoo says:
raedonchar: DON'T use an outlet to charge a capacitor! Seriously. Wall voltage is really dangerous, and capacitors don't really charge on AC (Alternating current--it's what your house power is, look it up on wikipedia), they just do sme freaky tesla ( again, look up tesla on wikipedia, he was an engineer) stuff. It is much safer to build a battery-operated charging circuit and use that. I hope this helps!
May 19, 2009. 9:07 PMmzw says:
Hi. i'm doing this for a science project at school lol ok so i used a standard bic pen, ripped off the tip, drilled 2 1/16th inch holes at the back etc. i also have capacitors that i got from used disposable cameras. how much steel wool should i use? i got the finest steel wool and everything, but whenever i connect the electrodes there is just a spark. please help?
Feb 13, 2009. 2:02 AMmilamber says:
nice ible me and one of my freinds are doin this on the weekend with slight variation and a masive cap bank power suply were planing on making somthing with a 70cm barel also a designed a cartridge for it look
Apr 30, 2009. 1:23 PMbylerfamily says:
Not a bad idea...
Jan 3, 2009. 1:46 PMItsTheHobbs says:
So, basically the steel wool is the "gunpowder", that's lit by an electric charge? That's pretty neat, very original
Jan 9, 2009. 7:34 PMXellers says:
This is actually not an original design, it has already been done many times.
Mar 11, 2009. 10:31 PMKilla-X says:
I still never got an answer from the maker of this instructables... Whats the schematic here to connect the flyback up right... I'm having problems getting the caps to discharge >_> what pins are what on your 4-way screw chamber!
Nov 30, 2008. 9:41 AMteapotking says:
could this be used to create a full auto paintball gun or would there be issues with corrosion/paintballs bursting in the barrel from the heat/paint shorting out parts that shouldn't?
Dec 26, 2008. 6:14 PMThe Red Button says:
LMAO ROFL COPTAH HAHAHAHHAHAHAHHAHHAHA YEAH RIGHT
Jan 23, 2009. 12:26 PMteapotking says:
jeez i was just joking, i could kill myself doing that, and i'm only 15, so i don't particularly want that to happen.
Mar 7, 2009. 6:37 PMKilla-X says:
If you go on youtube there's a guy who made a ETG that can rapid fire...
http://www.youtube.com/watch?v=VwcAtd-H2MA
Jul 7, 2008. 3:47 AMDrWeird117 says:
0% plasma, yet 100% pwnage
Feb 11, 2009. 11:18 PMThe 4th Doctor says:
There actually is some plasma in there
Feb 12, 2009. 12:09 AMDrWeird117 says:
Where?
Feb 12, 2009. 1:55 PMThe 4th Doctor says:
it arcs it least a bit in there making a bit of plasma for a very short time its not shooting any plasma but it does make an amount
Feb 12, 2009. 4:28 PMDrWeird117 says:
Huh...
Feb 12, 2009. 5:40 PMThe 4th Doctor says:
eh forgets it
Jan 30, 2009. 3:41 PMpyrohaz says:
Hey, what did you use for a trigger?
Jan 23, 2009. 10:44 PMDrWeird117 says:
\/\/here I)035 the plasma come from?
Jul 29, 2008. 1:18 PMAnarchistAsian says:
nice, favorite, +4.5
Jul 12, 2008. 6:12 PMshoestring92 says:
i dont have a voltage meter, and dont know how to charge the capacitor whats the easiest way, and how long does it take?
1-40 of 74next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:geckowil
