3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a simple robotic arm from Lego Mindstorms NXT?
Today, I will tell you how I built my robotic arm from Lego Mindstorms NXT.
In fact, I wanted to build a robotic tripod for my camera. I found out, that it's more difficult then it looks. After some experimenting I build this simple robotic arm.
I you want to build it too, you need:
- Lego Mindstorms NXT kit
- a computer
- time...?
There are only two rules you have to follow while building ANY robot:
1. rule: KISS (Keep it simple, stupid!);
2. rule: "The triple-F" rule a.k.a. FFF (Form following function!)
Step 1Constructing the base
  • last photo ←
The base is probably the simplest part of the robot to build. It's just a platform from the robot to stand on. You have to make sure, that it's long and wide enough. The center of gravity must be somewhere on top of the base, if possible, in the middle. Else wise, the robot will fall.
The base (in our case) are just a few beams that support the robot. More advanced robotic arms have motors in the base. These motors than move the arm, without moving themselves. Usually, the base has a motor that rotates the arm, but my arm rotates itself.
You can be much more creative with the construction of the robot then I was.
172 comments
1-40 of 172next »
Apr 9, 2011. 3:49 AMjwoo2023 says:
man! I have a NXT 2.0 not a 1.0
`_`
Apr 15, 2011. 9:32 AMzmxninja says:
me 2 :(
u can still do just change programming
Aug 26, 2011. 2:55 PMzmxninja says:
pretty simple to correct all u have to do is use the weird longshortturnlittlepiecethingymaajigy for claws if u gmd lol u probally wont understand what im sayig. just basically make a few subs for pieces
Apr 20, 2011. 10:34 PMjwoo2023 says:
no its just that the parts used are different, sound sensor, gears, claws...
well not claws because we have the angle thing.
Aug 9, 2011. 1:10 PMelectro centaur says:
There are no detailed instructions
Jul 10, 2011. 11:08 PMklarsen3 says:
where do you get that little thing that powers it and has the controls on it
Jul 25, 2010. 11:58 PMTheKnerd says:
Good job! Although you could change your code to allow the arm to move when you press the touch sensor, instead of having to "tap" it.
Apr 20, 2011. 10:36 PMjwoo2023 says:
he doing taps to make it precise so he doesn't knock the ball off the stand.
Jul 3, 2010. 12:53 AMjwoo2023 says:
Is this a 1.0 or 2.0? becoz i have 2.0
Apr 9, 2011. 3:51 AMjwoo2023 says:
just noticed the sound sensor! its 1.0! T.T
Mar 15, 2011. 6:34 PMlowe says:
This is very nice, good job
Feb 13, 2011. 7:48 PMaxeman911 says:
how did u program the nxt so whenever u tapped the push button the arm moved i can never get that?
Feb 13, 2011. 7:50 AMFuzzyBearGeek says:
I was going to buy one with the money I saved to buy one but I decided to save more money to buy one.
Feb 8, 2011. 11:59 AMmasterchief1257 says:
was it hard to program
Feb 9, 2011. 11:54 AMmasterchief1257 says:
same here
Jan 6, 2011. 6:31 PMbutterfly grower says:
this is cool!
Dec 20, 2010. 12:04 PMthe_artificer says:
how can you make this thing, theres no instructions on the mods
May 8, 2010. 7:11 AMhakemsaeed says:
nice tutorial
my robot
http://www.instructables.com/id/Nxt-telefreak/
thanks
Apr 25, 2010. 11:55 PMwasimnisar says:
Please can anyone send me code for this robotic arm i am working on this from 4 years.on( wasim018@hotmail.com).plzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Apr 8, 2010. 6:01 AMphoenixgrace1 says:
LOVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mar 7, 2010. 4:33 AMfarzaan_123 says:
wow Cooooooooooooooooooooooooooooooooool
Jul 11, 2008. 7:58 AMthe_burrito_master says:
I want the lego nxts *sob so bad *cry
Feb 15, 2010. 3:00 PM444fox says:
It will cost $325 with taxes and shiping
Aug 28, 2009. 10:59 PMtanmanknex says:
My school has 8 Lego mindstorms kits! We can make stuff for our tech class!
Mar 3, 2010. 5:33 PMdombeef says:
 What school do you go to?
Feb 1, 2009. 7:04 PMmettaurlover says:
on the up side, the old mindstorms was MUCH nicer to work with... i know because i've used the old one and have an NXT. they're just a pain to work with because you can't chain the wires to make them longer and the wires are stiff. also, the motors are much larger than the old sets.
Dec 2, 2010. 10:05 AMJimmacle says:
If you know what you're doing (like me :P), NXT is very easy to work with. Also, if a website called mindsensors.com sells really cool stuff for RCX and NXT, including more flexible cables.
Dec 2, 2010. 12:02 PMmettaurlover says:
1)You necro'd this comment
2)Thanks for the link, but my problem was more that the wires were brand new and I didn't know that they were exactly the same size as a large phone cable.
Feb 19, 2009. 2:40 PMmettaurlover says:
i only have the NXT, but have used the old kits.
May 1, 2009. 2:51 PMraykholo says:
same here i had the ris in school and i liked so i bought the nxt they re both good in their own way
May 1, 2009. 9:32 PMmettaurlover says:
NXT has more control but can connect to less types of peices.
Feb 28, 2009. 9:33 AMpyro1324 says:
I do not have nxt but i'm planning on getting it soon...
Jul 11, 2008. 10:03 AMTeacherOfTheWays says:
agreed *cry*
Jul 11, 2008. 11:04 AMthe_burrito_master says:
yeah... *sob*
1-40 of 172next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:roksraka
