Step 4Sand and Paint
Sand all of the corners and wood putty all screw holes.
Drill a hole large enough to fit the power cords and AV cables through the back middle of the tv base. Also drill a hole where the left marquee spacer touches the top panel and marquee box. (see pictures) This will be used for the back lighting power cord. Lastly, drill a hole through the far left side of the steering wheel base to fit the controller cords.
Using a small roller give it two coats of black paint.
After that dries, use a detail brush to hand-paint the flames on the sides and under the seat. I would recommend making a cardboard template of your design so that it can be easily recreated on all sides. Then free-hand a personalized license plate on the back.
Attach the marquee box using long bolts, washers and screws, threading the power cord through the hole you drilled earlier and securing tightly.
Add Comment
