At Techshop I built my own quadcopter using the laser cutters and some of the other tools and equipment available. One day though while driving around with the quadcopter in my truck another box rolled over on top of the quad and broke the main frame apart. That is was inspired me to build some sort of transportation / storage box for it.
This instructables outlines the steps I took to build my own storage box for the Elev-8 quadcopter. This is by no means the one and only way to build a storage box. This is just something I came up with one day using AutoDesk inventor to design all the parts and and make sure everything would fit together. You will probably need to modify my dimensions to fit your quadcopter.
Step 1: The Design
I used Autodesk Inventor as it was easy to dimension everything that way I needed and it also allowed me to perfectly align all the mortises at the right angles.
I have included the .dxf file for the box using 3/4" plywood. This file is designed for 3/4" wood, so it will need to be modified if you plan on using anything other than 3/4" material.
Elev-8_Storage.dxf102 KBStep 2: Running the cut files on the CNC Shopbot Router
I broke up the job into 4 files. The first being the safe holes for the screws to better hold the material. The second being the marking holes for the screws in the box. The third being the interior cut outs. The last file was the exterior cut profiles.
Step 3: Cleaning and finishing parts
Following this, depending on your preference you may want to add a round over on some of the edges. Please keep in mind of which edges will be butting up against another. You only want to round over edges that will be exposed once assembled.
Step 4: Assembly of the Box
The easiest way I found was to lay the base up on a table and use a square to keep a side straight while I drilled and screwed it in place.
The spacers simply get hammered into place and screwed in from behind to hold them in place. I added a little bit of weather tape at the spacer to keep the wood from scratching the quadcopter.
Step 5: The Top
I chose to vinyl wrap (faster than painting) two boards cut to fit the top of the box.
Add hinges and your choice of hardware and that's it!
I used a handle for each of the top halves and one larger handle for the main body to carry the hole thing.
Step 6: Enjoyment!
I want to point out that this box is definitely not the lightest out there. I build mine heavy duty so that I can pile stuff up on top of it without having to worry about the quadcopter inside.
Please feel free to comment any ideas or suggestions you may have below.
Visit Our Store »
Go Pro Today »
Possibly a bigger box needed, and some way to turn it on with the box still closed and another control channel to operate the box. Would be cool though!
I could also see having some retractable wires to guide the quad into the slots for landing in the box.
You might need to make the whole assembly a cylinder for that though, so no matter which way it is facing when it lands gravity will do the right thing to line it up.
