3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a heliostat parabolic reflector
How to build a <strike>heliostat</strike> parabolic reflector
Turn a flat sheet of anything flexible into a parabolic reflector.
Step 1Prove it to yourself
prove it to yourself
Download this template and print it on cardstock, add something shiny cut it out and tape the edges together, don't cut all the way to the center. The template is Deltacad 6 format
89 comments
1-40 of 89next »
Mar 20, 2012. 10:46 PMdrmattyg says:
I wasn't able to reproduce your math. Here's what I worked out, I'd be interested in your derivation: https://docs.google.com/document/d/19uwcK3_8pTK7NEc2ifPoZrFViOP3_v-oYplNIviHVEg/edit
Mar 25, 2012. 3:43 PMdrmattyg says:
Ah, I see now that you were approximating for shallow parabolas. Given the ability to use, e.g., wolframalpha.com to do complex integrals, and the fact that it has a closed form, I don't see any reason to use the approximation, but it all comes out the same in the end.
Mar 24, 2008. 7:39 PMookid says:
How come I can't open this file? I have an IMac and the parab16 wont open. also the "dxf" file shows up as a bunch of letters and numbers and lines. Please help a newbie out as I'm not good with this stuff. maybe a PDF file or something like that
Jun 20, 2011. 11:52 PMperalta says:
Hello,I always use the dxf viewer to view dxf files. You can google it, or you can visit http://www.autodwg.com/dwg-viewer/ to download a free trial version to try.
Mar 6, 2011. 2:08 PMdylanwinn says:
Use Inkscape.
Aug 8, 2010. 2:02 AMvallesan says:
hi well i use Windows XP but i convert the DXF file to EPS and CorelDraw just click on donwload RAR file on this link http://vallesan.deviantart.com/art/How-to-build-a-parabolic-174064501
Aug 10, 2009. 9:15 PMmacrumpton says:
Here is a free online media format translator that should help: http://media-convert.com/
Apr 15, 2009. 8:20 PMphaserlaser says:
you need adobe illustrator
Aug 4, 2010. 11:54 PMvallesan says:
Hi TOOL USING ANIMAL I took you design and convert it to a Corel Draw 14 and EPS ..so anybody can download it from here : http://vallesan.deviantart.com/art/How-to-build-a-parabolic-174064501 if you don't agree let me know i will erase the file .. thx in advance ........................ Aqui esta el archivo convertido a CorelDraw14 y a Vectores en formato EPS .. por favor hay que distribuir cocinas solares para que c deje de contaminar y talar arboles : http://vallesan.deviantart.com/art/How-to-build-a-parabolic-174064501
Apr 29, 2010. 9:10 PMArdnoc says:
in your example calculation I think you have the petal count and focus transposed.
nice instructable!  using this for the mirror on a solar cooker.
Thanks
Sep 23, 2006. 9:21 PMspinach_dip says:
People call that stuff "street spam" and when it's not election season, it's no more illegal to harvest the neat corrugated plastic than it is to pick up litter on the side of the road (which it exactly what it is).
Yea, of course there's an exception for elected officials and those who seek public service to pollute, but you can go shopping with a clear conscious. after the election law deadline.
I've used this stuff to hold the insulation away from the under eves vents in my attic.
Here's another use:
http://www.iamanangelchaser.com/products/street_spam_lounger/street_spam_lounger.html
Jun 22, 2007. 3:46 PMSacTownSue says:
Thanks for the link. I love the lounger. I don't have room for it but can use it for insiration. I think this would be a great instructables challenge to start the day after the election.
Nov 28, 2009. 5:59 PMshadowswizard says:
A freeware program for those that haven't found a way to view and print .dxf files:
http://www.irfanview.com/
Irfanview has a Paint plug in so it's very easy to cut, paste and print sections of that paraboloid.
Nov 15, 2009. 11:15 AMcactii says:
 In the rain hey... That explains why all the signs are blurry. ;)
Apr 23, 2009. 6:21 PMstrmrnnr says:
Just wondering if you have ever used this with a photovoltaic cell. What kind of an effect do you think it may have on the output of the cell? Do they have a Max. designed for standard direct sunlight? Might be able to turn a cloudy day into a sunny day, for the cell anyway. Just wondering.
Aug 10, 2009. 9:11 PMmacrumpton says:
I saw a video on youtube where a fresnel lens was focused on a pv cell and the cell was under water to stop it from bursting into flames.
Jul 9, 2009. 10:18 AMmatroska says:
I've never tried, but readed about photovoltaic cells. Apparently (and obviously) you'll get more energy out of it (compared to no reflector) but it will shorten the life of the cell. I haven't tried but it sounded logic to me. Instead, I plan to use a stirling engine (coupled to a dynamo), which looks to me more efficient.
Jul 9, 2009. 10:15 AMmatroska says:
"Nothing like dumpster diving in the rain." That's a new favorite quote for me!
May 13, 2009. 6:41 PMradon222 says:
If I print out this template at some other size, how would I figure out how far out the focus is? I want to make a reflector for a wifi transceiver and I need to know where to place the transciever. When I printed it out on 8.5x11" paper as large as possible using a crapy dxf viewer, I was able to get it to print it on 2 pages at 8.75" in diameter so there must be a way to calculate the focus distance from that...
Apr 23, 2009. 9:08 PMstrmrnnr says:
Go to Wal-mart and get a couple of those full length plexi glass mirrors for $10 and cut it into 1" strips to line the inside. You'll get some reflection then.
Apr 23, 2009. 12:01 AMbazalaz says:
save the dxf file to your desktop then convert it to pdf using anydwg
Apr 22, 2009. 11:59 PMbazalaz says:
google dxf to pdf converter or go to http://anydwg.com/dxf-to-pdf-ex.html they have a free trial that will convert to pdf for acrobat reader
Aug 23, 2008. 8:24 AMfishhead455 says:
FLATULATIONS--Not sure if you guys already know this but here
http://home.arcor.de/ernst.willand/amsi-model.html
is how I figure the curve for my trough collectors. Carefully constructed these will turn water to steam in a pipe quickly...so I use engine oil. Build a small trough and heat water quickly.
Thanks to Homohabilis for starting this thread.
Jan 18, 2009. 3:43 PMcuchulain92 says:
I would be SERIOUSLY interested in details of how you made trough-shaped collectors. I've thought about building a heliostat (that is, a steam engine powered by solar heat) for years!
Jul 2, 2008. 8:21 AMwanzewurld says:
I've been thinking along these lines for a couple of weeks recently and for a few years off and on. I was wondering what I could do with an old(er) ~8 Ft. satellite dish receiver. All I could come up with as a coating was aluminum foil which would cut the efficiency down and re-mounting it on a squared "Y" mount. Then it would be a matter of clock driving the vertical main mast and rotating the dish from one side. That would give control over azimuth and altitude. I was thinking along the lines of using a cone as a pulley or belted drive which would give varying tracking to adjust for the hours of daylight and approximately the same thing to adjust for daily altitude changes on relative sun position. It seems unwieldy but should work in theory. Any feedback on this? Adding to the "heating water" and running a sterling engine I read years ago about a long parabolic reflector heating a long tube but the heat transfer liquid they used was Tung oil. I'm trying to research that but Tung trees seem to have fallen out of favor since my childhood; they grow well in this section of the country though and make beautiful shade trees. They make a sort of "Fruit" that was once the basis of almost all oil-based paints. A "nut" was a bit smaller than a tennis ball and left a bruise if you were unfortunate to be standing at the right place at the wrong time! I'll furnish an E-Mail address in the near future for anyone caring to correspond and collaborate. Wayne
Jul 19, 2008. 10:36 AMpaladin42 says:
would like to apply this to my batch collector to help focus the sunlight. what angle is most effective for heating my water tank. also can i use this to possibly lengthen the amount of time in the day in which the sun will hit my collector. my thought is as the sun goes down the reflector will focus and intensify the waning sunlight. any help is greatly appreciated.
Sep 22, 2008. 9:22 AMfishhead455 says:
The angle is always--your latitude plus 15 degrees. (Example: if you live at 30 degrees latitude the angle will be 45 degrees).This in the correct alignment to take advantage of the planet wobble between the relative positions of the sun in summer and winter.
Aug 23, 2008. 9:34 AMalex-sharetskiy says:
hey, that's not tape, you just blurred it out in photoshop! Great instructable though!
Aug 23, 2008. 11:55 AMalex-sharetskiy says:
oh ok
Jul 5, 2008. 12:18 AMcraftthefuture says:
Thank you!! I've been looking for a way to do this (easily) for three seasons now! And without figuring out the math! I'm just not built that way. There's this amazing spanish video on youtube that shows that you can cook anything in the cooker (fried, baked, boiled, canned, and even popcorn)! Enjoy: http://www.youtube.com/watch?v=9lvIJStLdYk
Hopefully I'll post my replica before September :)
Jul 2, 2008. 8:25 AMwanzewurld says:
I see that I seem to have an E-Mail address at this site so someone please send me something - anything so I can see if it works. I don't see any way of sending anyone else E-Mail but haven't explored my "Inbox" yet. Perhaps they have an address book there. Wayne
Jun 14, 2008. 3:00 AMnuke-em says:
Totally agree with macrumpton. The picture could be written in an easier format.
May 10, 2008. 6:54 AMlittlegandhi1199 says:
for mine, instead of using signs i used reflective duct tape, i don't know what it is called and i put it on my dish, one problem though is that i accidantly put more tape over a lot of spots and so now the focus point is really hard to find oh well, GREAT INSTRUCTABLE!!!!!!! thanks
Apr 26, 2008. 4:26 PMlittlegandhi1199 says:
I don't exactly understand the equation Can someone help me out please
Mar 30, 2007. 3:43 PMARVash says:
I wonder what would happen if you put a solar panel in the middle of this XD.
Apr 24, 2008. 10:25 PMTheMadScientist says:
depends what you mean by solar pannel, well, not really,but back to the point, you could use the solar collection to turn water into steam and drive a sterling engine to generate power....
Sep 23, 2007. 12:49 PMTruik says:
Most solar panels would generate more electricity but would also burn out more quickly. There are a specific solar panels especially designed to have "more than one sun" and they are meant to be set up with reflective mirrors for generating more energy but they are also more expensive. I wouldn't burn out a regular solar panel attempting to tweak more out of it with a parabolic dish. Especially this one. I'm sure it would damage it quickly.
1-40 of 89next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
258
Author:Tool Using Animal
I'm a graduate of the University of Central Florida with a degree in Mechanical Engineering, I am currently working on my Master's. Otherwise, I enjoy building things, designing the things I'm going ...
more »
