3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a thermoelectric lamp
The thermoelectric lamp generates electricity off the temperature difference between the hot candle and the cool heat sink. This we can use to power small devices, like a radio or very bright LEDs.ý You may be able to charge an mp3 player off of it too!
Here's what we'll need:
A thermoelectric peltier chip, the bigger the better. I used a 100W version.
A large heat sink, I used a dell one with heat pipes. The success depends on this heatsink, get the best you can!
An emergency phone charger (we are going to steal the joule thief out of it)
A Small amount of Rock wool insulation, small amounts available from garden centers.
A small tin can with a lip around the top. (Heinz beans will do)
A coke can.
Thermal heat compound
Some heavy duty foil, about 30x30cm
A foot of thick copper or steel wire, for the handle.
2 25mm long M6 Bolts
4 40mm long M5 Bolts
1 50mm long M5 Bolt.
The bolts don't need to be any exact size, just use whatever is available, almost any will work.
Tools you'll need:
Tin snips
Soldering iron
Pliers (with cutters)
Drill bits
Sandpaper
M6 Tap for cutting the threads. The not essential as you could just use an ordinary nut, but it's neater.
Drill (Drill press makes life easier...)
Glue or Glue gun
You can see more photos of the TEG2 here
Take a look at Anthony Goh's website, who made an awesome looking version of this device :
The video below shows the thermoelectric generator powering some LED's off a cup of how water.
Step 1Drill the holes in the can and fit the feet and central adjustment
You can see that I have drilled 5 holes in the bottom of the can. These are for the feet and candle height adjustment. I fitted little rubber feet to them, this is not essential.
80 comments
1-40 of 80next »
Jan 23, 2012. 6:28 AMgingerely says:
I clicked on this, hoping beyond hope...
Back in the 50's, there was a magazine my brother subscribed to that had the plans to build a power generator used by the Russian populace during WWII for their radios using a kerosene or oil lamp (think wicks and glass chimneys), certain wires combined /\/\/\/\/\/\/ end to end. To insulate the coil of wires going around the outside of the glass chimney, they used potters clay. Once dried or low-fired, the clay and wire contraption could be taken off of the lamp and hidden, so that the authorities wouldn't know you were listening to the radio (also hidden). AND you still had a pretty good light source.
Still trying to find the plans for the Russian powerplant, but I do really like the candlepowered simpleness of this.
Apr 23, 2012. 10:14 PMwannabemadsci says:
Take a look at today's 'innovation' - LED table lantern powered by a tea light:
http://www.leevalley.com/us/garden/page.aspx?cat=2,40731&p=68887
Mar 17, 2012. 6:58 PMPhotogguy says:
Hey,
This might not be the set of plans you hoped for but I found this and thought you might be interested. A friend of mine is heading to the Amazon jungle with his family as missionaries and we're looking about for alternate sources of electricity. I love making things myself so when I read your post I thought I might find the plans and looked about... no success but I did find this museum. I hope you find your plans and hope you enjoy this link.
Grace,
Guy
http://www.aqpl43.dsl.pipex.com/MUSEUM/POWER/thermoelectric/thermoelectric.htm#po
Mar 17, 2012. 7:57 PMgingerely says:
Thoroughly and TOTALLY cool!!! Thank you, thank you!! The kind of metals used to create a current with the help of heat is mentioned which is a great help. This is a bucket list project, of sorts, or a project that was put down in a corner for a long time and interest has come back. (Read: trying to put back together the 1000 pieces of your grandfather's old _____ (insert antique thing here)) Also completely over my head (ha!), but if you run into any pictures of the Russian lamp with the wires sticking out of a coil of clay - sort of a spring slightly 'sprung' with a specific number of pairs ( like 120 of each?) of alternating nickel and zinc (?) wires connected end to end and the clay inbetween as an insulator, then that is exactly what I saw in that magazine. The peasants made it with what they had(I'm figuring it was some sort of baling wire and maybe something torn out of a motor?), altho' the wire that they said they used was available back in the early '70's (and I could get it, but it was pricey, even then). I also had a good source for the clay and a kiln, then. The museum piece shown in the article was commercially produced, I think?
I still think its a great cabin light, for off-grid use and could be so DIY.
BTW, My mother had me pack up all of the brothers stuff when they were getting ready to move. I saved my brothers old comic books. I thought that his old science magazines were way more interesting, but I saved the comics. Did he thank me? Of course not and profitted greatly later :P. In my own mind, the science mags would have been worth Way more in the grand scheme of things! I just wish I could remember their name then I could find the article!
How exciting for your friends! They will come back with wonderful stories, for sure!
Feb 9, 2012. 10:52 AMsolomonhorses says:
Awesome Instructable! The russian ww2 generators were copper and steel wires, or any 2 different metals, in V shaped junctions, one type of metal joining to the other, and the hot and cold junctions were the Seebeck effect. They radiated out from a candle or lamp, and were hooked up to old style low power am radios. This Peltier chip is awesomely more power, though! Thanks
Dec 30, 2011. 3:22 PMwaynemov says:
great idea. well done
Nov 13, 2011. 11:34 AMWhiteTech says:
Im getting slightly mixed up. Wiki and other sources say Peltier chips are for cooling and Seebeck are for generating electricity, unless the Peltier is reversible?
Sep 25, 2010. 6:05 AMdasimpson1981 says:
the best idea would be a copper plate on the hot side of the peltier heat this with the candle use heatsink paste also to best transfer heat on the cold side flat bottom can somthing like that filles with ice cubes and salt salt some how helps the ice be colder i dont know i feel you should see better results from this
Sep 12, 2011. 12:36 PMjrosiek says:
Ever put multiple ice cubes in a glass and have them seem to freeze together? The salt lowers the freezing temperature of the water. When you put plain water in your freezer it turns to Ice at 32 F, after the water has changed states from liquid to solid, the "ice" gets colder to what the freezer is set to, like 25 F. When you add salt to the water, lowering its freezing point, it allows the water to transfer the 25-31 F ice temperature.
Jul 19, 2011. 5:22 AMkaran13 says:
i jouel thief important if i just want to ligh 2 or 3 leds
if yes can u explane y ,
Mar 25, 2011. 6:02 PMmartzsam says:
So, pretty much, this is something like this, with a heat-sink on one side and a heat source on the other, hooked up to a joule thief?
Mar 26, 2011. 10:19 AMmartzsam says:
Epic! This ible is sooo freakin simple its gonna make my brain explode. Nice job!
Oct 14, 2010. 4:06 PManestho says:
is heating one side better than the other in terms of produced voltage?
Sep 22, 2010. 2:07 PMlikewho says:
I found a great source on eBay for top quality TEG modules designed specifically for power generation. I previously tried a standard peltier module with minimal success and very limited service life. The TEG module works much better and has been operating trouble free for months. Here is the link
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310173260016&ssPageName=STRK:MESELX:IT
Aug 2, 2010. 9:01 AMFrankenPC says:
Fascinating! Thanks for the Instructable post. Side note, this is how space craft like the Voyager power their electronics. They have a nuclear power plant which heats up a bunch of Peltier junctions.
Jul 24, 2010. 8:57 AMyatsuha says:
hello everyone I have decided to build this project for my physics class and i have most of the supplies but i have a few questions that I would like to ask as for the rock wool insulation does it have to be that or can it be some other type of insulation. I ask because im going to garden shops and hardware stores big and small and they all know what it is but the either want to sell a lot or they don't have any. As for the thermoelectric peltier chip you said that “bigger the better” then I read on and you also said “it didn't have enough power to charge my phone.” I was thinking about it and if 100 watt pelter chip didn’t charge yr cell then maybe I should get something bigger. I got a 400 watt chip but now im worried because is that to much power for my cell if so would it work if I split the power in to different electrical devices all at the same time to lower the wattage that goes to each one or can a candle even generate that much power. The aluminum patch is that just from a pop can or did u use something else. Is the joule thief necessary or could u hook up the chip to an outlet. By the way if you could reply the sooner the better because I do have a dead line im working with. Thank u
Jul 25, 2010. 1:21 PMyatsuha says:
Thank you for responding as quickly as you did and for the information you have given me. I have a few more questions for you as for the joule thief could I just make one off an instructable such as http://www.instructables.com/id/Make-a-Joule-Thief/step5/Try-it-Out/ instead of buying a emergency phone charger and taking it out. All I would have to do is just switch the battery out along with the led and replace it with the peltier chip and a output port. My heat sink is designed in a way that it would be a little hard to drill hole in it and I was thinking of replacing the aluminum foil for a foam material that is sticky on both sides so it can stick to the heat sink and the lid of the can do you think that would be effective.
Jan 5, 2010. 11:53 AMProteus says:
nice project , congrats =)
Could you measure the power output for us? You said you could charge a small Mp3 player, would you say it's around a 1W?
Thanks
May 22, 2010. 4:55 PMkill-a-watt says:
Maybe add a funnel on top and a pipe as a chimney?  The heat would rise off the heat sink and create a draft in the pipe. You could also insulate the pipe to keep the heat in longer for more air velocity. That would move more air through the heat sink, increasing the cooling capacity.
I thnk Dell has a patent for this.
Apr 10, 2010. 2:59 PMknektek says:
i used a hot air concept instead of direct heat. Red is warm and blue is cold air. The black thing is the peltier unit. The blue thing above the peltier unit is a water container (made from metal). the circles are air holes.
Apr 16, 2010. 1:56 PMknektek says:
The heatsink for this one is a bit large, i plan to use a smaller water container. since electricity is produced because of the temperature differences, could'nt you use liquid nitrogen for fun? Or dry ice and liquid co2?
May 14, 2010. 12:23 AM--= Excogitate =-- says:
 Dry ice would work great, but I would go so far as to make a stand alone dry ice powered version.
Mar 27, 2010. 7:59 PMstatic says:
An instructable that should allow anyone who chooses to do so duplicate your project.  While audio from the radio and light from the LED are tangible evidence power is produced, it would be nice to see measurements that indicate how much power this can produce.
Feb 6, 2010. 8:24 AMGerardTV says:
Guys please understand. Most peltier modules are rated for cooling not power Generation. You can use them for SEEBECK EFFECT but they will probably burn out as the solder will melt if temperature gets to high. Seebeck modules are designed or should be depending on who you buy them from for power genertion. Lots of features TEg modules have that allow them to withstand
 large TEMperature Differences. DT is critical Hot side less cold side. The more DT you have the more power is produced. Thermoelectric-generator.com
 has allot of info for this technology. If you have specific questions you can ask me . email at info@espressomilkcooler.com we have been in the Thermoelectric field for 20 years.
Mar 27, 2010. 7:46 PMstatic says:
Understood. While I someday purchase some of the smaller less expensive module for experimenting with cooling and flea power, electrical power production, but I'm not going to invest much into it at all. I'm convinced my money best spent for photovoltaic and wind for electrical power production at the dwelling scale. Not to mention the TE modules generally require the consumption of a fuel to produce electrical power.
Jan 12, 2010. 6:38 AMnetgrazer says:
Restaurants often have those candles with a spring-powered push-up mechanism under them, you'd never have to readjust the height with those, just change them when they run out.
Also, wouldn't aerogel be the ideal material for pretty much everything on the hot side? Unfortunately, it's still a bit tricky to make, I believe (especially the supercritical drying part sounds complicated). Maybe some ready-made aerogel could be shaped to the right dimensions, but it is awfully brittle.
Feb 19, 2010. 4:43 PMcdousley says:
isnt that like 1000 dolars a square inch
Feb 19, 2010. 5:24 PMnetgrazer says:
That is a bit steep, I admit. I you know someone with a setup to make it, it might be feasable. It's not like it's a space-age technology, right? Oh, wait...
Aerogel granulate is quite affordable, but I wouldn't know how to harnass its isolatory properties. United Nuclear sells it.
The spring-loaded push-up candle holder still seems like a really good solution to the distance regulating problem, if I may say so myself.
Feb 22, 2010. 6:44 PMcdousley says:
Wow ive been misinformed that would work good along with a seebeck genarator instead of a peltier an a spring candle
1-40 of 80next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
312
Author:scraptopower(Scrap to power)
Always a brew in hand, I like to make stuff.
