3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a thermoelectric lamp
Step 3Cut the candle door
Cut the candle door
Next you need to cut the hole for the candle in the side of the can this should be around 30 - 35mm by about 50mm long. I started by drilling a small hole and worked from there using the tin snips. After this you can drill the ventilation holes all the way around the top of the can. I used a 3mm drill bit for this.
Make sure you sand all the edges so you can't cut yourself on the metal!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
312
Author:scraptopower(Scrap to power)
Always a brew in hand, I like to make stuff.
