3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a treehouse
This particular design requires two or three trees (or branches) in close proximity. It was made over the course of several weekends using new, pressure-treated wood for the support structure and floor and an old fence was recycled for the sides. The roof is a camouflage-pattern tarp. It's not weather-proof, but it stays pretty dry inside: a three-season treehouse, but best for summer! It was made with my 4, 6 and 8-year old children in mind, but has been a hit with visitors of all ages.
Step 1Pick your trees
Pick your trees
There are definite advantages in using more than one tree for your treehouse - the treehouse can be bigger, and you have to use less bracing. The tree(s) you see here (behind the magnolia!) are a very tightly grown group of three trunks - they all touch at the base, and splay out somewhat as they grow upwards. At the height of the treehouse - about 9 ft (2.7 m) off the ground - one pair of trunks are still almost touching, and the other one is about 4 ft (1.2 m) away. This means the design has been based on one for a close-spaced pair of trees, rather than for a group of three. The trees are Garry oaks, and they don't grow much further north than this (southern Vancouver Island), so they grow pretty slow here. A solid gnarly collection of old trees, each about 1 ft in diameter at 9 ft up.
Start by figuring out how high you want the treehouse. 9 feet is exciting for kids but not scary. You can of course go higher, but you'll have to take more account of movement.
83 comments
1-40 of 83next »
May 22, 2012. 10:51 AMpedrozacharias says:
this how-to was really easy to follow. cool stuff. The attached images showed my finished product. Kids are having a blast!
Just need the basket with the pulley now, and perhaps a zip line.
All fun stuff. Thanks,
May 16, 2012. 7:00 AMzilcho says:
That is a legit tree house
May 16, 2012. 2:09 AMDusk Shadows says:
this is great my dad keeps on saying he will make a tree house he never does
Apr 12, 2012. 9:20 AMHollyMann says:
You have some very lucky/fortunate kids to have a dad to make them so many awesome things! I love all your instructables - esp the bed - this one and the rubik's cube drawers! AMAZING!!!!!
Jan 6, 2011. 2:42 PMplanetsideplayer14billion says:
I have 10 aceres. about 2.5 is forstry. I have 2 forts. 1 in the trees and 1 on poles me and my sis have wars. im still upgrading my forts with rails, shelves, airsoft gun turrets, ext
Nov 27, 2011. 1:45 PMmitchblahman says:
that sounds absolutely incredible man, kudos to you
Jan 6, 2011. 2:43 PMplanetsideplayer14billion says:
And i keep a dune buggy under it
Feb 16, 2012. 12:56 PMthickeven says:
what about grenades
May 22, 2011. 10:32 PMWinter-_- says:
yikes. So many posts with people telling you off about how you did something or even someone just grumping about you "hurting trees" it has to be anoying- but im so impressed wih how each of your comments back are kind and to the point! :)
Its just so nice to see that even when others are being rude to you (and thats crazy as it is seeing that your posting a free gide and if they dont like it they can move on) your not lashing out.
Looks to me like your kids have two things to be proud of, a wonderful treehouse, and a dad who acts like a kind and levelminded adult. <3
May 12, 2011. 1:44 PMcghale says:
I'm at this point and am wondering the same thing as andrew...how do you attach the 2x4s to the platform? Deck screws or something more substantial?
May 10, 2011. 8:59 AMcghale says:
For a house like this, what would the maximum safe width be? (i.e., between two trees) Working on this design now...
Sep 28, 2010. 12:57 AMRicardo Furioso says:
More bolts, in slots, please.
Three per tree in each board are recommended.
Two would be better than what you have.
The problem with your application is that the trees in high winds can exert a HUGE horizontal torque force on the bolt heads that could bend, tear out, or shear them.
What we did in our very similar situation was to drill several holes (just a bit bigger than the bolt diameter) next to each other in the boards.
ooo
Then we chiseled them out into slots.
(___)
Then added a bolt with a BIG washer in the middle of each slot.
(_O_)
This design allows the trees to move in high winds independent of each other without snapping or bending the bolts.
Also the bolts should NOT be tightened. The washers should be able to rotate. This allows the bolts to move side to side in high winds, and for the whole structure to "give" a little.
If you think of the tree as a huge lever, and the distance the wind can move it both ways, you start to understand the amazing forces at work here.
We love your treehouse.
Come to think of it, we love all of them.
Sep 29, 2010. 11:07 AMRicardo Furioso says:
Whooops.
You're right about Step 4.
Apr 20, 2010. 10:37 AMcowmanpoke says:
 in step 4 when you bolt the wood to the tree, are you drilling all the way through the branch? i'm confused about how that wood is staying on
Sep 28, 2010. 1:07 AMRicardo Furioso says:
Honestly think you might rethink the length of your bolts.
A foot, yes 12-inches, would be recommended.
Why?
Because that treehouse may outlive all of us.
Because kids will be in it.
Because kids will invite their friends.
Because whole scout troops or classrooms full of kids might descend upon it (both have happened to ours).
Because adults have a habit of frequenting treehouses along with refreshing adult beverages that make them do silly dangerous things. In groups.
So.
I beg you to grab your socket and ratchet set, remove the 4-inch bolts, and replace them with big fat 12-inch galvanized lag bolts.
They're cheap.
It may sound like overkill, but the wind forces on treehouses are staggering, and if a storm weakens them, the next kids who venture up there could be in serious danger.
It is one thing for a kid to fall out of a treehouse.
It is another to have the treehouse fall or fail with a kid inside.
Thanks for considering this.
ricardo
Sep 28, 2010. 10:08 PMRicardo Furioso says:
Congrats on the gale survival.
I suspect you're right about the failure.
I hope you are.
We found huge cheap lag bolts at Home Depot.
Putting a bolt through the trunk shouldn't compromise it's integrity. You'd need to predrill it, and the great percentage of the trunk—excluding the live cambium which comprises the outermost layers—is dead wood anyway.
http://www.ces.ncsu.edu/depts/hort/consumer/factsheets/trees-new/text/tree_anatomy.html
Putting two or three bolts in a tree trunk vertically is a good solution if you do not have access to a custom fastener fabrication shop.
And it works just fine if you loosen the bolts annually to allow for growth and space between beams and trunk.
Aug 4, 2010. 11:53 PMWerner111 says:
I would have added another bolt in for each tree, but it looks good :)
Jul 27, 2010. 9:37 PMandrewbhorton says:
How do you secure the top of the bracing to the platform? Beneath it, on the outside, inside? I'm 15 and I have no idea what I'm doing... but decided that I really want to make a treehouse.
Jun 13, 2010. 10:54 PMRicardo Furioso says:
Please. Bungee cords and kids do not mix well. I have a close friend who's an eye surgeon. He begged me to eliminate bungee cords from my life because he's seen so many people--especially kids--who have lost their sight from bungee cords. I love your treehouse. Come to think of it, I love all treehouses. Thanks for sharing yours.
Sep 30, 2009. 6:37 PMblackjimmy says:
Nice! And well done for going with a proper treehouse instead of a crappy 'house on stilts'. I don't see the point of them.. they are to treehouses what margarine is to butter; tasteless unexciting unnatural imitation for people who are afraid of a little fat! I don't think people should worry about a few bits of metal going through a tree either.. it won't do much harm as long as you don't go crazy. Bolts are much better than nails for strength and for the tree. Tree's can survive having half their branches being cut off, being half burned, lightening strikes (well sometimes).. they just carry on growing, especially if you're talking about a big, well established tree, which most of the time you are with treehouses. Most people don't build in rare-specimen trees either so don't see the problem really.
Mar 30, 2010. 12:41 PMstarwing123 says:
Although a lightning strike will blow the bark off of ones side. The tree in the front of my house got hit by lightning. The bright flash of lightning just rips bark and a bit of internal wood to shreds
Mar 28, 2010. 10:55 PMElvenChild says:
 I built a tree house at my neibhors once just for the sake of it being there
they had a small wooden fence right by a tree and it just so happened a branch and the fence ran paralell so I  just added a bunch of boards there as the floor
added a door and after I added a tarp for the roof I was finished
ION (in other news) I can't stop listening to nox hej dunarol
Mar 28, 2010. 5:25 PMfullhouse says:
Very nice Structable! bet Dad and Kids love it!
Mar 28, 2010. 5:22 PMfullhouse says:
Very cool ladder idea!
Mar 28, 2010. 5:12 PMfullhouse says:
in my experience building decks on homes. If you are using PT decking that has a high moisture content, I would recommend placing the decking boards tight together when assembling the floor. Now for my reasoning , as the deck boards dry out from being pressure treated they tend to SHRINK up,therefore makeing the gaps alot larger. It only takes a few weeks of summer sun to do this. Placing them right next to each other once they dry out will give adequate spacing. This is only my opinion from my own experience.
Mar 28, 2010. 12:30 AMGegelooz says:
(removed by author or community request)
Mar 28, 2010. 3:19 PMnoobiefied says:
 u sir need to think beneath the onion skin. By building a tree house you are preserving the tree that is there to let the tree live on and prosper! If people that build "tree houses" did not care about trees then they could have just CUT DOWN THAT TREE and built a column supported "building"! Makendo Great job!
Mar 28, 2010. 7:25 AMlukeea says:
Who cares if it damages the tree? Plant another one if you're that concerned.
Thanks for the instructable makendo. I hope to build an awesome tree house like yours for my kids someday.
1-40 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
212
Author:makendo
I'm probably off making something. Most likely a sandwich.
