What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
Using 3" deck screws, attach the four 2 x6's perpendicular to one of the other 2 x 6's. Make sure they're spaced so that when you put it up in the tree, the perpendicular joists will miss the tree! With someone's help, put the contraption up in the tree, center it, and tie it down.
More bolts, in slots, please. Three per tree in each board are recommended. Two would be better than what you have. The problem with your application is that the trees in high winds can exert a HUGE horizontal torque force on the bolt heads that could bend, tear out, or shear them. What we did in our very similar situation was to drill several holes (just a bit bigger than the bolt diameter) next to each other in the boards. ooo Then we chiseled them out into slots. (___) Then added a bolt with a BIG washer in the middle of each slot. (_O_) This design allows the trees to move in high winds independent of each other without snapping or bending the bolts. Also the bolts should NOT be tightened. The washers should be able to rotate. This allows the bolts to move side to side in high winds, and for the whole structure to "give" a little. If you think of the tree as a huge lever, and the distance the wind can move it both ways, you start to understand the amazing forces at work here. We love your treehouse. Come to think of it, we love all of them.
I'm pretty comfortable with the bolts as they are for this little treehouse, but overengineering is no bad thing either. Better than putting extra bolts though would be to use bigger ones; this page explains why really well (and also points out that 1/2" lag screws are insufficient!). Anyway, thanks - and I can confirm the treehouse is still standing :)
ooo
(___)
(_O_)
You're right about Step 4.
