2. We well be working with electricity that is going to be around water. Please keep this in mind as you build it as I will not be responsible for turning you into a light bulb.
3. I will be walking you through the steps that I did with the parts I used. That being said this is not a one size fit all instructable.
4. This is my first instructable and mean comments will probably make me pout.
Remove these ads by
Signing UpStep 1Some goodies to gather.
3/8 drill bit
ý
Hand full of drywall screws
Old sewing machine pedal
Old drill
Some wire nuts
Silicone caulk
ýcarriage bolt and nuts
12 lazy Suzan ( I bought mine at target for eight dollars.)
Extension cord receptacles
I'm a professional potter and I don't think your project, as shown, will have enough mass to overcome the friction of the hands on the clay. Try it, but don't use to much clay( 2-3lbs). Good luck
I'll post whatever I end up with.
Thanks so much for posting this!!
Hopes this helps.
Tip, old power tools, keep for parts, somebody will always need a part, instead buy the new junk tools.
As an Aspie, I have almost a photographic memory for information.
see http://www.instructables.com/group/aspies/
I put the following on
http://www.instructables.com/id/100-Homemade-Lathe/
Motors
Start collecting power tools, for example, a electronic speed controlled electric drill. Remove the noise making speed reduction gear box, but ensue you retain the cooling fan, or replace it with other means of cooling.
Without the noisy gearbox, use a pulley system to reduce the motor speed, and increase torque.
I did this once on an older B&D, by cutting off the front casing of the drill, keeping the handle part and motor casing.
The trigger on/off/speed-control became just a speed control, I wired in a separate switch.
But always remember, this modification destroys the safety of Double Insulation, so find a way to add a earthing wire, and use the motor with a RCD safety device
I used this drive motor, and various pulley system, to test home built odd ball generators for wind power.
Use such such a motor for a SMALL lathe, such as for ornamental pen making, and dolls house furniture.
Somebody, Anybody, Everybody, please feel free to create an instructable on such a motor. Try finding a way for universal mounting, so it applies to lots of different projects, with a very versatile speed/torque range.
