3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build a wood fired hot tub
Step 12Decorate the heater
Decorate the heater
Here you can go to town with decorating you burner with bits of scrap or by cutting out shapes in the sides of the tank. You should also add some legs to hold the thing the correct height off the ground.
Depending on what you are doing to decorate it you may want to wait before you weld the two halves together because if you're making deep or awkward cuts with the angle grinder you'll run the risk of cutting into the coil.
To get an idea of the ideal height, think about where the top water level will be when nobody is in the tub. You want the top inlet from the heater to come in an inch or two below this level and make your legs the correct height to account for this.
1 comment
May 23, 2011. 3:01 AMKelticpaddler says:
I may be teaching you all to suck eggs, but may I suggest you use 3 legs instead of 4?
A "fouth" leg makes it wobble, and it's a pain trying to level a 4 legged stool, table etc.
Stunning projetc Veloboy, well played sir
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:veloboy(I'm building a strawbale house)
