Step 8Open up the tank
You need to make sure there is no more gas in the tank. Open the valve all the way and leave it for a few days. If your gas bottle has a pressure reducing valve or quick release nozzle fitted, remove this also because it will not let all the gas out.
Use a heavy monkey wrench and hammer to remove the gas tap and valve gear on the top. You may need to insert a heavy steel bar through the handles to get more leverage and stop the gas bottle from rotating annoyingly while you're whacking it. It would be prudent to use a wooden mallet to hit the wrench with to avoid sparks and do this operation outside in a well ventilated space.
Fill the tank with water to remove any traces of gas and empty it before cutting it through the equator with an angle grinder.
Add Comment
