How to Build a Woodgas Grill and Never Buy Charcoal Again
HomeGreen by
36,235
265
23
Posted
Introduction: How to Build a Woodgas Grill and Never Buy Charcoal Again
A woodgas grill is very efficient is fired up instantly and gives your food the flavor of the wood you use plus the heat is controlled by the simple turn of a knob. It uses wood chunks and very few of them and replaces charcoal so go green and make it taste great to
Step 1: Step One. Build a Woodgas Stove
first you need a woodgas stove. they are simple to make however I will not show how to build it because there are several good instructables already here so build one then on to the next step
Step 2: Gather Needed Parts
after you have your woodgas stove built you need a flame spreader to make the concentrated fire spread out evenly you can make one from steel plate or an old 55 gallon drum lid. A grill from either an old grill or a replacement grill from a store. Blocks or rocks to hold the assembly above the woodgas stove (how many depends on how you build your stove and how tall you want it). if you want a better grill you will need a lid from an old grill or just buy a cheap grill to convert. A thermometer is a nice add on but not required.
Step 3: Make Flame Spreader
I used a metal 55 gallon drum lid (make sure all plastic and rubber are removed) use a cut off wheel and cut slits about 5" long spaced about 1.5" apart starting at the outer most edge. cut slits 5" long and spaced 2 to 3 " apart near the center but not all the way to the very center. then cut some slots at the bottom of those half way between the outer and inner ring
Step 4: Add Thermometer and Handle to Lid
if you want you can skip this step but if you want to add a handle on top (if there isn't one already) I just zap screw it on then drill a hole and install a thermometer
Step 5: Assemble the Components
place a block for your stove to set on then two stacks of blocks to hold the grill assembly. There should be a 4" to 5" gap between the flame spreader and the stove. place the stove in the center then place the flame spreader on the supporting blocks. place grill directly on the flame spreader (there should be just enough of a gap so the food never touches the flame spreader). Now place you're top on and your done
Step 6: Fire Up Your Grill
Follow instructions on the particular woodgas stove you built but here is the basics. Take wood chips/chunks just below the top holes of the stove. Pick something like hickory apple wood cherry etc (make sure wood is dry) place cardboard kindling etc on top (never use fluid of any kind to start up the stove or the flavor of the starting agent will be present on the food!!!). once lit start the fan on the unit and once the fire is going good use a variable speed control to adjust the heat as needed.
Step 7: Stuff I Have Cooked on It
mushrooms potatoes cabbage carrots and chicken
Step 8:
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    24 Comments
    very nice - are you UK based? I have a design project just starting to make something 'like' this but taking some new ground - perhaps you'd like to be involved?
    Awesome work. From what i can see in the pictures it looks like the way you built your woodgas reactor is similar in design to the MIDGE camp stove, is that right?
    it's actually my own design of the large woodgas stove but there is a baffle in the bottom and the fan is internal to protect it
    i will definitely try to do that for you
    I would love to know more about your design too. I tried searching for plans similar to yours, but nothing that I was crazy about. Thanks, Al
    I'd love to know more about your design.
    Since your is your own design,please go ahead and post it too,as I haven't built a stove yet,and might as well have the whole schebang match.
    Very cool. so is the fan directly beneath the pyrolysis/reaction chamber or vented in?
    the reaction chamber is a 4 1/2 quart and a 6 1/2 quart stainless catering pots. the inner pot has holes every centimeter on top and every inch on the bottom. the larger pot has a 3" square hole in the bottom. 4 large bolts hold both together without the need for welding. the base is 8" stove pipe with 8" angle flanges one on the bottom and two on top to hold the pot in place. there is a round piece of tin held just under the reactor assembly with a hole in it and it is held with angle brackets. the fan is mounted on the round piece. then a vent hole is cut into the base for airflow. i built it this way so it would stand up taller to a more usable height
    That sounds awesome. I plan to make a woodgas stove for my house this winter I like the idea of putting a fan in it. Thanks
