3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build an 8x8x8 LED cube and control it with an Arduino
There are a lot of LED cubes on Instructables, so why do another? Most are for small cubes consisting of 27 or 64 LEDs, rarely larger since they are limited to the number of outputs available on the microcontroller. This cube will be 512 LEDs, and will only need 11 output wires from the Arduino. How is this possible? By using the Allegro Microsystems A6276EA LED driver.
I'll show you how I made the cube itself, the controller board, and finally the code to make it shine.
Step 1Materials
Materials
All parts you'll need to build the cube:
1 Arduino/Freeduino with Atmega168 or higher chip
512 LEDs, size and color are up to you, I used 3mm red
4 A6276EA LED driver chips from Allegro
8 NPN transistors to control the voltage flow, I used the BDX53B Darlington transistor
4 1000 ohm resistors, 1/4 watt or higher
12 560 ohm resistors, 1/4 watt or higher
1 330uF electrolytic capacitor
4 24 pin IC socket
9 16 pin IC sockets
4"x4" (or larger) piece of perfboard to hold all the parts,
An old computer fan
An old floppy controller cable
An old computer power supply
A lot of hookup wire, solder, soldering iron, flux, anything else to
make your life easier while making this.
7"x7" (or larger) piece of wood used to make the LED soldering jig
A nice case to display your finished cube
My Arduino/Freeduino of choice is the Bare Bones Board (BBB) from www.moderndevice.com. The LEDs were purchased off eBay and cost $23 for 1000 LEDs shipped from China. The remaining electronics were purchased from Newark Electronics (www.newark.com) and should only cost around $25. If you have to buy everything, this project should only cost around $100.
I have a lot of old computer equipment so those parts came off the scrap heap.
52 comments
1-40 of 52next »
Feb 27, 2012. 6:42 PMmegaduty says:
Well done R-!
Feb 8, 2012. 6:21 AMWilliam Ackley says:
I applude your fantasitic effort! I have built several 4x4x4 and they are so hard to get square! I can only imagine what a n 8x8x8 must be like, I think no Matter WHAT anybody else says YOU ARE A WINNER to the max!
By Hawkings chair it was a fine accomplishment.
Good show,
Villiis Iohnes ab Oakmeadow.
Dec 14, 2011. 5:04 PMjonodan says:
Oh and thanks to R- for getting the mind cogs turning :)
Oct 3, 2011. 3:34 AMfryddog says:
Your tutorial looks pretty awesome so far. But before I give it a go, do you know what I can use instead of the led drivers. They appear to be discontinued everywhere.
Nov 20, 2011. 9:52 PMmickjc75 says:
Check out the TPIC6B595, these are similar (Hi current sink capability, output latch ect..) only they do not have constant current output so you will need series resistance on each column. They are commonly used in LED moving message displays.
Sep 28, 2011. 5:20 AMpfred2 says:
Intelligent build. Well documented. I have to give you a patch!
Now I am wondering what this all would have be like built it into an infinity mirror.
Aug 14, 2011. 7:59 AMbibor168 says:
Thanks for the detailed instruction on how to build an LED cube. I eventually managed to build one of these things my own and it works fantastic. Thanks alot again. I used eight 8bit shift registers and changed the code a little, but in the end it works like your prototype does.
May 29, 2011. 10:35 AMkully3xf says:
Hey! I'm workin on this project and i have everything assembled and finished, but when i send the code to the arduino it completes but the cube just stays lit up. every led is lit no matter what code i run to the arduino any idea what might be wrong?!?
Feb 25, 2011. 5:57 PMMechtek says:
Is it possible to light one led at a time with this cube?
Feb 3, 2011. 2:58 AMraaymaan says:
This looks really nice, well done.
Just been skimming through and I wondered why there are two codes? Do they both go to the arduino consecutively??
Feb 7, 2011. 2:33 AMraaymaan says:
Ok so I figured it out! Matrix.pde wouldn't verify with arduino but it will with a program called 'Processing'. It looks identical to the arduino GUI but I cannot state the major differences. http://processing.org/download/
Compile matrix.pde for a very easy way of making your own animations!
Jan 9, 2011. 12:15 PMprcrow says:
What are the 9 - 16 pin IC sockets used for?? I can't seem to find them on the circuit diagram. I assume it is used to connect to the leds,but not sure how that works.
Another comment they are discontinuing the A6276EA chip, it looks as if the TB62706BN/BF chip is a suitable replacement., do you see anything wrong with using it?
Oct 24, 2010. 10:00 PMPiplx_22 says:
Gday,
Just wondering, a few people have asked about which NPN transistors to get... there are so many options, just wanted to get the correct ones (newark part# maybe??)
Also - I bought 1000x 3mm Blue LEDs from ebay. They are 10000 MCD, 465-470 NM, 3.4-3.6v. Do I need to adjust anything to use these LEDs?
Cheers,
Pip
Jan 8, 2010. 12:20 PMghostunit12 says:
 Hi, could you tell me what are the blue wires coming out of the arduino for?
Jan 12, 2010. 2:52 PMdarkwolfpack_232 says:
what did you use for NPN transistors what numbers
Nov 22, 2010. 7:21 PMpkrouse says:
Looks like a great project to try! I see LEDs on ebay rated at many different voltages. What voltage LEDs did you use? I'd hate to have to alter the circuit any, and heaven knows I don't want to buy LEDs with resistors and solder all those in too!
Has anyone, other than the author of course, finished this project yet?
Oct 22, 2010. 12:49 AMDeep C says:
If I went with common cathode, I think I could just modify the schematic from the other one using NPN transistors instead without modifying the code. I understand electronics pretty well, But I'm just learning arduino code and would like a jumping off point. I think that would be the only modification necessary. Anything anyone else can see I'd need to change?
Nov 8, 2010. 2:28 PMArikel says:
Other than grounding the transistors instead of using 5V, you will need to find a new LED Driver. The one listed will not provide power.
Oct 23, 2010. 2:54 AMDeep C says:
Someone else had a different way of wireing it if I remember correctly it used only 1 output for the eight layers I'lltry to find it and post a link or schematic
Oct 18, 2010. 4:35 PMMechtek says:
Is there anyone here who could help me understand the code better? I love my cube but really wish I could add my own effects. Thanks in advance!
Aug 13, 2010. 6:48 AMkupa1416 says:
El servicio npn PUEDE C1008 voi un probarlo i les digo Como FUE
Jun 17, 2009. 10:01 AMVHawk says:
Its easier to go to the Sunled USA webstie, sign up and get free samples of the LED Grids.
Jun 18, 2009. 1:31 PMZorink says:
What product are you referring to? I couldn't find anything like that, unless you mean the dot matrix displays.
Jun 9, 2010. 2:28 PMHe11uvaCook says:
I looked also and saw nothing like a grid of LED's that wasn't a matrix (clock-style) display. Don't waste your time on this site. Better prices and a larger variety of products exist elsewhere.
Also, this is an awesome project to put together! Kudos to the author. However, though the original [ i ] pics were large, they were certainly blurry. A macro setting on the camera might have helped this. Furthermore, more specific information about which parts to use (i.e. the type of NPN) should have been included. If such things don't matter, then it should be explicitly stated.
Thx!
May 11, 2010. 9:07 AMskajam66 says:
 Hi,
you mentioned that you bought your LED's direct from China. Can you point me in the direction of a supplier? I'm in Japan and LED's cost $1 each....
Cheers,
skj
May 11, 2010. 9:14 PMtechtable says:
 are those the ring lord pliers?!
Jul 20, 2009. 10:57 PMPAKIS-RULEZ says:
BRO CAN U PUT A HI RES PICture for the circuit thanks in advance!! the pic is blurry iam buying the parts to make this thing.
Feb 16, 2010. 7:48 PM13r1an says:
click on the [ i ] on the upper left of the picture to view it in the original resolution.
Jun 18, 2009. 8:04 AMmrnoname says:
im just wondering but, cant you use 16 output wires if you use binary to code their position?
Dec 22, 2009. 9:36 AMgeoslim13 says:
in other words a lot of wires
Jun 25, 2009. 1:11 PMvlad_tepesch says:
a complete (and readable) circuit diagram would be nice
Nov 10, 2009. 6:35 AMdigitalyzer says:
Yep, nice readable circuit diagram would be nice. I also can't quite figure how adressing of LED works. And that leaves me puzzled about doing correctly connection of LEDs in cube.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:R-
