3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to build an 8x8x8 LED cube and control it with an Arduino
Step 3Assemble the cube
Assemble the cube
How to solder all the layers together to make a cube:
The hard part is almost over. Now, carefully place one layer back into the jig, but don't use too much pressure, we want to be able to remove it without bending it. This first layer is the top face of the cube. Place another layer on top of the first one , line up the leads and start soldering. I found it easiest to do corners first, then outside edge, then inside rows.
Keep adding layers until you are done. If you pre-bent the leads then make sure to save the layer with straight leads for last. It is the bottom.
I had a little too much space between each layer so I didn't quite get a cube shape. Not a big deal, I can live with it.
2 comments
May 11, 2010. 9:14 PMtechtable says:
 are those the ring lord pliers?!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:R-
