loading
Step 3: The cost breakdown
    The Final cost breakdown for this project is as follows. And yes I did it cheap.
Six boxes of deck screws. The original price on each box was $7.50 per box but I got them all when a local hardware store went out of business and auctioned everything off. So I bought three large boxes of various packages of screws for $20.00. That would put the final price for the screws I used at about $5.00.
      1/2 gallon of deck sealer which I also bought at the auction. I bought four gallons for $20.00, so about $3.00 for the amount I used.
      A gallon of diesel fuel which I mixed with used motor oil to treat the underside of the wood and support pieces as a preservative.  About $3.00 (More on this later)
      2 trips in my pickup to get the free redwood, using roughly 6 gallons of gas, or about $18.00 for transportation.
      Finally, I ruined the blades on my planer after hitting a number of hidden screws in the wood, which is a hazard of working with used wood. The blades are double-sided, so I could use the other side, which means only half the blade was worn out. I bought a set of replacement blades for $28.00, figuring half of that for this project is $14.00.
The total was $43.00. Just to be safe I rounded it up to $50.00.That's pretty reasonable for the results that I got. Of course I am not counting my slave labor. But remember, you must feed slaves even though  you don't pay them, hence the BBQ grill.
Awesome! The snow photo gets me. Nice work
That is just beautiful!
Own the same saw as you, and from experience none of the saws craftsman makes now match it for performance until you start getting into the 500 dollar range. The old cast iron topped craftsman saws are great and if you watch craigslist or eBay can usually pick one up from 150 to 250 depending on condition and accessories.
I REALLY enjoyed your instructable. It is like watching a work of art done step by step. The nail holes give the wood the impression of telling a &quot;story&quot;.<br>If only the wood could talk.<br>Great job!!<br>Jesse<br>
Thank you! I've been wondering how to do a wooden walk w/o all the digging, fill, gravel, etc. That wood preservative also seems like a great idea! I too appreciate the work you put into the project and to your presentation here. Beautiful!
very nice, liked the comments too, was a lot of work to do the sidewalk but also I think a lot of work to put it up here, so big thanks for that, very, very nice, thanks for sharing.<br>
I was wondering if you could use this idea for a deck? I want to put one in the front of my house... it would be ground level.... what ya think?
It would probably work great. Mine has performed really good so far. And, unlike cement if your not happy with the results you can change it.
I love this project...it is awesome and I was looking for an idea in creating a walkway from the back of our house to the barn...thanks for sharing...you did a really great job!
that looks incredible, well done, the time and effort you must have put into it really paid off imo
wonderfull job , masterpeice work , just the base will be good with a raised simed finishing, save the world
nice performnce
This would look great indoors, now to find redwood in Alaska.
WOW THAT A WORK OF ART!! WELL DONE
Very cool project!
I'm facing the replacement of my old, ugly, cracking backyard path this coming summer. Now you've got me wondering if I should use wood to do the job. I suppose the weather here in Canada is no worse than in Montana...
If the old walk is cement you could just leave it in place and build the wood one on top of it. That would eliminate the cost and work of removing and disposing of the cement. The savings in that alone would probably pay for a large part of the wood. In addition building it on top of an already level surface would make construction that much easier. About the only problem you might run into is needing to add some short posts to help keep it in place so it doesn't slide off the cement.
Hey! Now there's an idea. Unfortunately, the path we've got needs to be wider, some of it needs to be removed completely (so we're already paying for removal), and some pathways need to go elsewhere.<br><br>But, I do wonder if I could use big 2x2 concrete slabs instead of bricks as &quot;anchors&quot; for the wood pathways. I could make modular sections that bolt together, too! Oh, I gotta write this down so I don't forget. Thanks for the inspiration!
I love the recycled beauty of this. The last picture in your final step shows snow on the ground. I'd worry about the surface being slipery when wet or frozen. Did you use any final finishing product besides sealer? Also, did you use any sort of spacer between the wood slats to allow for expansion of the wood?
I started out using a putty knife blade as a spacer but after a while I just eyeballed it. Experts might think that I spaced the wood to close, but I got tired of having to fish stuff out from under the walk that fell through the cracks. If it turns out that they are spaced to closely I will unscrew the boards and shave a little off with the table saw. <br> When the snow first started the surface was slippery but as this winter is going on that appears to be going away. It got so cold so fast that there was never a chance to put anything else on it except the first coat. I am hoping that its enough for this winter.
Nice touch showing all your tools in the same photo.
This is one of the most beautiful walkways I've seen.<br><br>Not just only for the finished result, but for the whole concept. And it is instructables like this that prevents this site to drown in sloppy and crappy instructables. Thank you =)<br><br>Wounderful descriptions<br>Clear and good photos<br>Scavenged wood<br>DIY-sealant with comparatively low poisonous effects (and the motoroil is already used once before. Reuse yet again!)<br>Safety<br>&quot;Function over estetics&quot; where parts does not show: I vote for that one!<br><br>Even the comments so far is of good quality!<br>This is what internet is for!<br>Good job!<br><br>PS. You even made me want to move from our apartment and get a house so I've got a reason to do something similar :)
I forgot to mention that it really shows that you were thinking about next steps all the time.<br><br>The time and effort put into this must be incredible, and it shows!
this is beautiful! very nice job
Love it!!!! The wood you can get in Montana is great, I love the design!!!
That's the kind of project I like to see. I had some initial concerns about using the motor oil/diesel mix for treating the wood (especially considering redwood is naturally rot/bug resistant) but your comments have put those fears to rest.<br><br>We don't get redwood out in the midwest but I'd sure like to try a project with some. It's a gorgeous wood, and as long as it's sustainably harvested I'm all for using it. I'm glad to see it recycled so well in your project.
uh, wow!
Beautiful wood sidewalk!!! I wish I could have friends and family throwing away this kind of lumber. Here in the oil country part of Texas we only get pine, cedar and ugly pressure treated where oak, redwood and other beautiful woods are a hard commodity to get a chance to reclaim. Just a note; if you have more kickback as your saw gets older you might need to re-align it with the miter slot as it tends to kick out of square (parallel) witht the slot. Besides that, you made a very very beautiful piece of functional art that you should be very proud of!!!
I have the same table saw. Still works great!
Beautiful! It makes me wonder if large &quot;stepping stones&quot; could be made out of discarded pallets. We find a lot of pallets made out of oak up here in the NW. New Project!<br><br>Thanks!
It looks gorgeous, a very elegant solution. I'm guessing Redwood ages rather like Oak, so it should last well.<br><br>A couple of suggestions I'd offer to anyone else embarking on such a project.<br><br>The enemy of wood in any exterior installations is moisture, and certainly here in the UK you'd need something more than &quot;sealer&quot; to protect your wood. What you buy here as &quot;sealer&quot; won't go NEARLY far enough. I'm sure this project is fine for the author's particular situation but the best solution will depend on many factors including the particular type of wood, the prevailing climate, and there may be chemical toxicity laws to consider, it's always wise get good advice on the correct treatments for the particular wood you use in the country you live in. It might also be a good idea to install a damp proof membrane to act as a permanent barrier between the wood and the ground, in this case it may not be necessary, but again it might be worth the extra effort. If you DO install a damp proof membrane you will need to consider ventilation also. you will need some means to ensure air can circulate underneath the wood so that there are no &quot;dead spots&quot; that could cause water to collect and damage your beautiful work..
Did they ever try putting several inches of gravel down for drainage? Gravel does a good job of keeping things out of the water provided it doesn't get to deep. Since my walkway is not attached to the ground if it rained to much it would float away. Of course I could use that as a selling point &quot;Sidewalk also serves as a flotation device in high precipitation emergencies.&quot;
I forgot to mention that redwood is naturally resistant to rotting. It does eventually but it lasts a lot longer than most other woods. Its similar to cedar in that way. It does turn gray with exposure so the purpose of the sealer for me is mostly to try and retain some of the color longer and to make it a little more dirt resistant. If you were only concerned with longevity, pressure treated wood is probably the best. Its injected with a preservative under high pressure so it penetrates deep into the wood. Do they use creosote in the UK? That is an excellent preservative but its is believed to be a carcinogen so its restricted here now. They still treat power poles and railroad ties with it but home use is discouraged. In fact I don't know if you can even buy it anymore. It also smells really bad.
I use a stone sealant called &quot;511&quot; for most of my wood projects as well. It has worked better on my projects than most others. It's pricey but it works great.
I remember seeing a commercial an epoxy-like wood treatment. From what I remember, It basically soaks into the wood, then hardens, making the wood impervious to water and rot. I believe it said the wood becomes almost like a very hard plastic. I don't know much about it, but it looked like it might be good for this type of thing. *shrug*<br><br>Beautiful sidewalk, BTW. Almost looks too nice to be an outdoor sidewalk.<br><br>Everything looked cleaner in 1987. I think you need to tie those bushes to a truck, yank them out, and plant new (smaller) ones.<br>
I think I know the treatment you are referring to, it's even useable on rotting and damaged wood (if we are talking about the same stuff) It's probably a bit pricey for treating a whole walkway, but it would keep the water out. Not sure how it works with the UV either, but certainly worth looking into if you are starting a project in warmer and generally wetter areas.
Things always look messier in the fall. I put off cleaning up so I could get the project done first. Now I have a garden cart full of frozen solid leaves buried in the snow. Winter came on fast this year. The really annoying thing about this area is this snow could be here until March. <br> The bushes are on the south side so they provide a lot of shade for the house in the summer time, so they do have some positive things going for them.
Ah, yeah, leaves, snow. I remember them well. Endlessly raking, carting, shoveling, plowing. I'm going on two years now in south Florida, and I'll be a happy guy if I never see another leaf pile or snowflake in my entire life.
Gravel would certainly help, but for many woods the moisture laden air above such a drain would be enough to promote fungal infestation and rotting, hence my comment about ventilation.<br><br>It sounds like the Redwood is very similar to Oak in the aging process (I'm not really familiar with Ceder either). The silver grey oxidation layer inhibits the fungal growth and rotting. As long as you can keep it out of STANDING water there's no reason it shouldn't last for dozens and possibly HUNDREDS of years with no treatment what so ever. Pressure treated wood is definitely a good option. <br><br>I'm still not clear what you are referring to as &quot;Sealer&quot; but to effectively seal against the oxygen in the air and the UV that fades the colour you might require some kind of varnish. If you bought &quot;sealer&quot; here in the UK you'd end up with a watery substance that wouldn't really do anything useful in that direction. You're certainly right to want to preserve that lovely rich colour as far as possible. We have a &quot;Diamond Hard - Floor Varnish&quot; that I've used for things other than floors, but which might suit such a project if you were doing something similar here.
As regards the sealer I used --- It looks like the company has quit making it but I did find a link to the sealer that I used, if you want specifics there is a link to a PDF data sheet at this web site. <br>http://www.valsparmro.com/products/Specialty/Premium-Water-Sealer.html
Is your finished wood slippery when wet? <br> <br>My experience on boats is that all finished wood is dangerously slippery with a bit of H2O. Ceder could be left unfinished for a nice nonslip surface.
What I have found with this particular sealer is that the surface is not slippery with water but instead feels sort of rubbery. What actually is slippery though is snow and ice. The snow doesn't stick to it and that make its slippery, it sweeps clean with a broom but if you have snow on the bottom of your shoes you have to walk carefully. I am hoping that after it weathers a bit it will get rougher and that problem will go away. If not I might have to do something else like gluing a light scattering of fine sand on it.
put another coat on with sand mixed into the poly/varnish. or you could get expensive and buy traction compound, also known as walkway compound. When I was working on airplanes, we used to go through gallons of the stuff on top of the C-130's we worked on, and even through the heaviest New York winters, I didn't slip once up there (luckily)
Nicely done. A friend with many, many tools has an electronic device for finding nails and screws in his &quot;used&quot; wood before his planer finds them. Also, I once read an article that urged allowing only the tips of the sawblade to come through the wood. The author claimed this produced a smoother cut and if your fingers tangle with the sawblade, it is only a flesh wound, not severed bone. It seems like a good strategy in the absence of guards.
I don't know if you're referring to the table saw or not, and I'm no professional by any means, but I read exactly the opposite when I was looking for a new table saw recently. The reason being that a saw blade set to cut higher than the height of the wood provides less backwards force for kickback. The majority of the teeth are engaged in upwards and downwards force, coming up through the wood and then back down. If the blade is set so only the tips of the blade come through the wood, you've got a lot more teeth putting backwards force directly on the wood.
but, like you said, a lower blade setting would have less chance of severe injury if there's no guard.
I was referring to a table saw. What I read was an article from <u>Popular Science</u> in an issue from back in the late 1950's or early 1960's. I have had a radial arm saw for quite a long time. But, for a while I used the home built table saw described in this <a href="http://www.instructables.com/id/A-Precise-Table-Saw-from-an-Electric-Hand-Saw/">Instructable</a>. I kept the blade low and never had any kickback problems, unless the wood contained too much sap or a piece had internal stresses that caused bowing and binding as it was cut. Even then I remember using a screwdriver in the kerf once or twice to function as a riving knife and prevent binding on the blade. Most of my safety precautions involved using pusher sticks as often as I could and always keeping my hands several inches away from the blade. I am only trying to share something I found helpful, not to sound like I have the only way to do it
With all this talk of power tools, it's worth just pointing out something that I'm sure everyone here knows by heart but which might be useful for those who've found this article from elsewhere.<br><br>&quot;Before we use any power tools, let's talk about shop safety. Be sure to read and understand the instructions and safety rules that come with your power tools. And remember, there is no greater rule than to wear these, safety glasses.&quot;<br><br>I don't think I even need to provide a credit, because everyone KNOWS who I'm quoting, and I certainly couldn't say it better. All the safety gadgets in the world are no match for a thorough understanding of the particular quirks and foibles of YOUR tool.
Norm!
About This Instructable
124,708views
349favorites
License:
Bio: The name comes from the First Star Trek movie, that pretty much says it all.
More by Vyger:Gnarly wood projects with Weird wood, Broken glass, LED's and Epoxy. Turning a Trashed Mobile Home into a Shop A Guide for Buying LED's on E Bay ---- Part TWO
Add instructable to:
