The premise is simple. Make holes in a bowl and shine a light behind it to make stars on the ceiling.
The completion is quite a bit more complex, due to some pesky laws of physics that I'll explain in the next few steps. The end result is a curious looking device that will definitely get lots of remarks, especially when you turn it on.
Unfortunately I didn't think of making an instructable for this until after I had completed the project. It was a gift for a special someone and I didn't want photographic evidence being accidently discovered on my computer or her camera. I'll try my best to be comprehensive and thorough with the pictures I've taken.
This instructable makes minor assumptions that you have basic soldering skills and knowledge of how to use hammers and typical hand tools.
Please vote for me in the Get The LED Out! Competition! Voting ends on June 21st!
Step 1: Materials and Tools
Materials:
-Metal bowl
-3W white LED
-Wood dowel, 1 inch diameter
-Steel sheet metal
-Pop rivets
-Rubber sheet
-Self-tapping screws
-Batteries and holders
-Switch
-1.5ohm resistor
-wire
-M3 screws and corresponding nuts
-Map of constellations
-Masking tape
-Non-gloss black paint
-Thermal Grease
-Metal washers
-Fibre washers
Tools:
-Center Punch
-Hammer
-Vice
-Drill
-Pop rivet gun
-Wrench
-Pliers
-Screwdriver
-Hot glue or otherwise
-Jigsaw
-Hacksaw
-Printer
-Scissors
Optional Tools for the well-equipped:
- MIG, TIG, Arc or Oxy Ace welding tools
- Bandsaw
- Metal cutting press
- Bending press
- Nibbler
- Press break
Step 2: All-Important Science
In our case, the lensing effect doesn't make a visible change to our lights, since the source is round and the projection is round, through a round hole. The one important thing that must be kept in mind when choosing your light source is this; a wide light source makes a wide projection, and a small light source makes a small projection. We want tiny pinpoint stars, so we want the smallest brightest source possible. The diagrams in this step visualize it for us.
Putting a normal lightbulb inside the bowl will not have the desired effect, so a high powered LED must be used. Also, only 1 LED can be used, or else more than one projection per hole will appear.
Step 3: Making the Constellation Bowl
Place the dowel in the vice, gripping it very firmly. This piece is going to be the resting piece, and will be destroyed in the process, so don't use expensive wood or something you want to keep.
Print and cut out your constellation chart. You may need to try a couple times printing at different sizes until you find one where your constellations will all fit reasonably well on your bowl. Tape them down with masking tape. Place the bowl on top of the dowel so that the inside of the bowl is resting on the dowel and the outside where your constellation paper is is facing towards the ceiling. Place your center punch on the star, and hit it with the hammer. Practice until you make a hole that is roughly 1mm of open diameter. The surrounding will be slightly dented, and the hole won't be round, but don't worry.
The reason that we hammer from the outside is because the opposite side of the metal will be extremely sharp, so having the sharpness on the inside is better and safer in the end.
After you complete your constellations, feel free to make as many random stars as you'd like. I made enough stars that theres lots to see and the constellations are well hidden, but not lost completely. This part is purely up to you, and you can add more later if you want to.
Step 4: The Skirt
You will need to punch four holes around the rim of your bowl that will let you screw it down onto your base. Punch these holes larger than star holes, as big as you need so that your screws can pass through without threading.
Also, the inside of the bowl needs to be painted with black paint. Reflections off the inside can reflect out the opposite side and create strange shapes on your ceiling and walls.
Step 5: Constructing A Base
Filling the bottom with rubber or painting the inside black is a good way to make sure there are no reflections inside the device. Filling any gaps in the sides or bottom is also crucial, as any escaping light will be visible on your ceiling and walls.
Cut, bend and drill four small brackets that will let you mount your bowl onto your base. Attach them to your base with rivets so that they line up with the four holes you made in your bowl edge.
Your LED needs to be bolted to the bottom of the base, so drill two holes that line up with the notches on the LED that you purchased. Put a tiny bit of thermal grease under the LED so that it conducts its heat into the metal base. If your base isn't made of metal you might want to put the LED on a metal plate in the bottom of your base.
Step 6: The Light Circuit
Construct the circuit as shown below. The LED I used was a 3W hex base LED running at 3V and around 1A. The value of R will change depending on what LED you use, and you should be able to calculate the required value using the LED calculator at http://linear1.org/.
Your switch can be mounted anywhere. I put a nice big toggle switch on the front.
Step 7: Stargazing Time!
I tried to photograph the effect, but without a SLR or tripod capturing the effect well is nearly impossible. The photo does it no justice.
I gave mine to my girlfriend as a birthday gift, and she absolutely loved it. Lying in bed with the Planetarium at your feet is a lot of fun, pointing out the constellations and gazing in wonder. No doubt anyone who recieves one as a gift will be extremely impressed that you made it yourself.
Things to change/improve:
-The result would look better with an even brighter light and even smaller holes
- Having several light sources would allow for more stars with fewer holes, but the ability to have identifiable constellations is lost.
- Adding a wall power adapter would make for a very nice nightlight.
EDIT
Another great add-on would be to add a low-RPM motor on the inside and have the bowl rotate on the light very slowly, just like the actual night sky. I thought of this while building mine but the noise and mechanical issues made me drop the idea pretty quickly, but someone could definitely find a way to do this.
I hope you enjoyed reading my first instructable, thank you very much for reading.
Visit Our Store »
Go Pro Today »
I did my own based on your design, only a few changes, power source from the wall socket, small things like that.
I used a 3w Blue Led, it gives u more of a star effect i think, it's less "light" but more defined dots. Also, adding a LM317T is great to get constant controlled current is a good idea. Also, instead od rivets, just bolts and nuts, so you can open it an fix it just in case.
My little niece loved it, i really appreciate your idea Matt.. keep'em coming.
Then, I bought one of those http://www.prlog.org/11168760-star-sky-projector-lamp.jpg
Anyway, it was worse then I expected.
I like the way you did yours, and I'll do one this weekend. I'll buy the LED's tomorrow. Great Instructable! I'm planning to include a blue light inside the box also, so that if I want a "calming" and "relaxing" light, I could use it! :D
I'm working on a similar project, and I'm trying to determine the best light source. I noticed through the comments, you said that your final photo was a long exposure, and the stars were about 2" diameter -- that implies these aren't super bright on the ceiling.
Is the end result bright enough to function as a decent night light? You did mention using it as a nightlight, but how does it compare to a traditional lightbulb-based nightlight?
If you look at the science of Step 2, you will see how I explain big and small light sources, and the effect they have. Ideally you want as bright as possible, as small as possible, and the light-producing portion of the source (ie filament, LED internals, or a frosted bulb) to be round. A normal bulb with a straight line filament will little straight lines on the ceiling instead of stars.
The stars aren't particularly bright, but this is only a 3W LED. A higher power LED, or adding more holes makes more light.
As a nightlight, it might be good for a child, but won't do much to prevent you from stubbing your toe on your bed frame. All the light is aimed at the ceiling, not the floor, making navigation difficult. If your eyes are even partially adjusted then the reflected light off the ceiling would probably work well enough to find your way to bed.
Feel free to ask any more questions. Hope I helped you out.
I picked up a 1W cluster of 6 high intensity LEDs at the local Fry's; not without a great deal of skepticism, either.
Oddly enough, using a colander, it lit up the living room pretty well. My wife didn't think it was enough light to function as a nightlight for a fearful child, but it did the job I wanted. Plus, the colander is metal, and has huge holes in it, so a smaller dome, with a black interior and smaller holes will likely do a better job.
Functioning as a nightlight, I'm going to add additional lights elsewhere, but probably only with standard 5mm LEDs.
Thanks again, and once I have something worth showing off, I'll post some pics!
Hope it all works out.
Thanks for the tips on hole size, too. I'll keep an eye on that. Some experimenting will be necessary!
AWESOME GADGET
A PIC and a stepper motor would probably be a more realistic solution, for both a realistic or unrealistic rotation time.
I use PICs myself, but sometimes a good old analog or mechanical approach is much more practical than programming a microcontroller.
great project.
I was wondering, how big are the stars and far from the ceiling can the bowl be before you can't really see them?
is each star something like a 2" dot at 3 yds from the bowl? thanks, Anthony
With the bowl on the floor they're still quite visible. I don't have a ceiling high enough to test any more than that.
