How to Build an Arc Reactor Mark 1 Style
11,014
15
Posted
Introduction: How to Build an Arc Reactor Mark 1 Style
HI
Ok lets get started,
Info:
I spend 3 day's building this arc reactor ..well not whole day's, I made this during the week in my spare time after work, I work in a hardware store and stumbled on a "how to make an arc reactor tutorial " video last week and it fascinated me so during work hours I was wandering around in the store looking for materials that might come in handy on building this arc reactor.
How to get started:
1st I looked up some ironman images of the arc reactor
2nd I looked for materials that might be useful, the things you should look for are:
- LED'S blue or white color
- a glass or plastic see-true ring
- some plastic rings although metal would give it a nice reality touch but keep in mind that this will make the object heavier
- electrical wire
- cardboard
- 9v battery or 12v depending on LED'S
- cardboard
- black and silver paint
- all the basic tools such as scizors, superglue <--- very usefull, etc
3rd I made up a plan in my head on how I could bring theese parts togheter ( that's right I dont draw everything down cause its a waste of time. aslong if you are motivated and going 100% for it
you won't need to draw up plan).
step 4 try and put everything together without glue, see if it looks good then construct it !
I build it into 2 parts the outer ring and the inner ring, I fitted them together.
so what you should do is building a solid circle shaped platform to place the LED's
then add the inner ring to the outer ring and place both on to the LED platform making sure you don't harm the wiring of the LED's, see if you can make 2 wires escape below to power up the battery and there you go all done!
NoTICE that I don't go in to detail with the inner and outer ring's
I do this because I want you to be creative it's not an exact copy of the movie version I added my own style and it worked perfectly it lookes cool and thats the meaning of it all
If you cant find the right metal pieces you want just make them in cardboard, paint them black then use a dry painting brush and use some silver paint stroke the paint onto a piece of paper so you get a minimal amount of silver on your brush then, paint the cardboard object.
the combination of black and a little silver will give the object a cool old rusty metal look verry realistic! this technique is called Dry-brushing.
So what are you waiting for get started!
Step 1: This Is What It Look's Like When Its Finished
its complete
Step 2:
video(this I filmed with a cellphone so sry for the resolution)
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
2 Comments
Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
can i ask why there appears to be one segment that does not light up in the fourth picture?
