Step 10Tested Variation
iImage Information
When I originally made these planters I was forced to use the smaller 7" tall barrels. I had concerns about the limited root space, so I constructed an extension out of plastic netting and hanging peat moss basket material (sorry but I don't know exactly what it is called). I cut the basket material into a square and rolled it into a 6" diameter tube. I then used the plastic netting as a frame to wrap around and support this tube. The plant was feed through the planter box as normal but I positioned the tube above the plant roots and filled it up with dirt. This gave the potential for a 12" root base. Or should I call it root top? They worked wonderfully, but I like the appearance of the new design better. I am not going to add strawberries to the new design due to the ending of the season, but this fall we plan to try a butternut squash plant on the bottom with an herb planted on top.
